Question about Brother MFC-8440 All-In-One Laser Printer
Drum Service Message
I replaced the Drum with a new one and the "Replace Drum" service keeps coming on. I powered the printer off, the message went away but after printing couple of pages it came back, any ideas?
Thanks,
Jay
  • Anonymous Nov 28, 2007
    change drum soon
  • Brother Master
  • 1,113 Answers
Yup reset counter, must open front door and press set button then arrow to replace drum and yes, press set/ok.
Posted on Oct 21, 2007
Call service
You may have gotten an incorrect message and removing and replacing the drum is a step in right direction. But if you continue to get the same message I am afraid you will have to replace the drum - they do wear out.
Aug 19, 2015 | Kyocera FS Office Equipment & Supplies
Drum error dr-420
Sir/Madam
he following error messages will continue to appear if the drum counter was not reset when you replace the drum unit with a new one.
  • Replace Drum
  • Drum End Soon
  • Drum Near End
  • Drum Stop
To clear these error messages, you need to reset the drum counter,
Or Visit official Brother Printer website For Brother Printer Troubleshooting Page Url Below:http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/002800/000037/faq002837_000.html?reg=us&prod=mfc7340_us_as&c=us_ot&lang=en
Or
Still Having Problem then follow Us On For
Brother Printer Support
Jan 14, 2014 | Brother Office Equipment & Supplies
Xerox 4250 photoreceptor error
I have a Xerox 4250. After the ink cartridge ran out I replaced it with a new one and got the "replace photoreceptor cartridge" message. Reinserted the cartridge and it stayed. Called Xerox and they couldn't explain. I turned the machine off and on and the message changed to "replace photoreceptor cartridge" but an additional message of replace Smart Drum came up. I replaced the Smart Drum and it is working fine now. Note: I really don't think it was time to replace the Smart Drum. But the nearest authorized service provider was 3.5 hours away and this had to be cheaper than a service call from that distance.
Jun 25, 2012 | Xerox Office Equipment & Supplies
Replace drum soon
You can disable this message. Turn on while press Menu.
You have enter in "service mode"
Put code 10
Put code 31 (after WSW)
scroll right until last digit
change to zero
press menu
put code 99
And ready!!!
Jan 25, 2009 | Brother MFC 6800 All-In-One Laser Printer
Ricoh ap4510 - Maintenance Kit Issue
For the message to be cleared you should enter the service menu and reset the replaced elements
Jul 28, 2008 | Ricoh Aficio AP4510 Laser Printer
Changing the drum
I fixed the problem (following the user's guide).
1. After reinstalling the new drum unit into the printer, keep the front cover open.
2. Press "Clear/Back" on the machine
3. Press "1" and when the LCD shows "Accepted", close the front cover.
May 14, 2008 | Brother DCP-8040 Copier
'DRUM CARTRIDGE END OF LIFE' MESSAGE
The back right of the drum has a small 20mm F80mA fuse that you need to replace to reset the drum counter.
(fuse blows to reset the drum life setting)
May 09, 2008 | Konica Minolta magicolor 2430 DL Laser...
Error message
9,037.45 Yellow Ink Stick Count Fault
your 04,021.42 here are the possibilities.
arrwup.gifPrimary Causes The troubleshooting table lists parts and wiring referenced in the troubleshooting procedure.
Table 1. 4,0xx.4x Troubleshooting Reference Table Applicable Parts
Wiring and Plug/Jack References
Electronics Module, PL 5.0
Right Side Wire Routing (2/2), Figure 3
Printhead, PL 2.0
Electronics Module, Figure 6
Drum Assembly, PL 2.0
Electronics Module Power, Figure 7
Drum Heater Relay Board, PL 5.0
Right Side Wire Routing (1/2), Figure 2
Drum Temperature Sensor, PL 6.0
I/O Board (2/2), Figure 10
arrwup.gif Troubleshooting Procedure Table 2. Process Control Error Troubleshooting Procedure Step
Questions or Actions
Yes
No
Test the heaters.
Run the Service Diagnostics Monitor Heaters tests with all heaters On.
Do the heaters function properly?
Replace the Electronics Module ( REP 5.0.5).
Go to Step 3.
Check the harness to the failed heater.
Is the harness damaged?
Replace the harness.
Replace the failed component.
Jan 06, 2008 | Xerox Phaser 8500N Printer
"Replace Drum" message won't go away
pls install the drump properly if it is in correct position that mean printer need to be service.
Sep 27, 2007 | Panasonic KX-FLB801 All-In-One Laser...
Brother MFC-8440 All-In-One Laser Printer Logo
405 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
