Question about Compaq Presario-Notebook 700 Series, 2500 Series, x1000xx Series, R3000 Series LCDs Displays - 33700 (337005001) CD-ROM Drive
PXE-E61 problem occured when i opened my laptop Compaq Presario 2500, it appear PXE-E61: media failure system boot, as check the bios setting no hard drive found,what wi i do to fix it?
    Brigadier General:
  • 10,406 Answers
Your disk-drive has failed.
So, your computer tried to boot itself over the Ethernet network,
by "broadcasting" a request for booting. When either the network-cable was _NOT_ connected, or when _NO_ computer responded to the "broadcast" message, you get "PXE: media failure".
Take your computer to a qualified technician,
to remove the "dead" disk-drive,
to replace the disk-drive,
and to reinstall Windows.
Posted on May 27, 2009
Pxe-e61: media test failure, check cable
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. Next - to check if the hard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an USB mass storage device and you cannot open the various folders and files on this drive, then this confirms the hard drive is faulty. Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Sep 22, 2012 | HP Compaq Presario R4000 Notebook
When I turn on the PC the following message appears and my system goes turn off... For Realtek RTL8101E/8102E PCI-E Ethernet Controller v2.13 PXE-E61: Media test failure, check cable PXE-M0F: Exiting...
This error occurs when the BIOS finds no hard disk drive to boot from, and tries and fails at booting thru the network jack (PXE Boot is a network boot used in large corporations, usually to image a system.)
Reseat the hard disk drive in the system, then reset the bios defaults and see if the system will boot normally. You can also try running diagnostics (Fn + Power on a Dell)
Most likely scenario is that the hard disk drive has failed and you will need to replace it.
Jul 15, 2011 | Computers & Internet
My laptop does not work it says PXE-E61:Media
Put 'Hard Drive C:' before 'Network' in the boot order
(If the hard drive does not appear in the boot order, that's why the PXE network boot agents start)
Note : Check that the hard drive is seen in the BIOS setup
Cause:
PXE (pronounce Pixie) is an agent used to boot on to the network
It's using the DHCP protocol to localise a server where the image of the OS is located
In order to PXE boot press F12 at startup or configure the boot order in BIOS to display 'Network' before 'Hard Drive C:'
If, for any reason, the hard drive is not seen the computer will attempt to boot on the network controller.
That is caused by the hard drive is missing, unplugged or failed
Jan 11, 2011 | Acer TravelMate 4062LCi Laptop Charger...
Wile I am trying to boot it up it goes in to a loop
Hello.
That error message usually refers to a hard disk failure. Your hard disk cable could be loose or faulty. Or, your hard drive would need to be replaced.
I'd suggest to check the cable and run your system's hardware diagnostics (often F2 or F12) when your system boots.
Hope this helps.
Nov 26, 2009 | Compaq Presario M2000 Notebook
Boot error PXE-E61: media test failure, check cable followed by, PXE-M0F: existing Broadcom PXE ROM followed by, Operating System not found
Hard drive has been coruppted. Hold alt f10 on statup to format and reinstall. If that dont work you may need to try install from cd's provided when you purchased laptop. If that dont work buy new hard drive and restore from cd's. Good Luck.
Nov 23, 2009 | Acer TravelMate 800LCi Notebook
When I try to boot up my Compaq Presario 2500 laptop I get the following error message: PXE-E61: Media test failure, check cable Operating System not Found. I have tried changing the boot sequence in the...
Boot sequence isn't enough. You have to turn OFF (disable) the boot from network. The error your seeing is result of the network boot rom not finding PXE server to boot from. Again, be sure to disable boot from network.
Jun 06, 2009 | Compaq Computers & Internet
PXE-E61: media test failure check cable
"PXE-E61 Media Test Failure, System won't boot"
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration(F10)
This Will Solve this problem
May 25, 2009 | Compaq Presario-Notebook 700 Series, 2500...
PXE-E61
  1. Go to Bios Settings
  2. Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
  3. Save The configuration(F10)
May 25, 2009 | Computers & Internet
When turning my laptop on i get a message media test failure
You see this message when the laptop trying to boot from a remote server using the network card. If you didn’t see the PXE-E61 message before, it means that the network card was listed after the hard drive in the boot order (you can set the order in BIOS) and the laptop booted directly from the hard drive. Now, when the hard drive has failed, the laptop cannot detect it and tries to boot from the next available device – the network card. Your laptop is not configured to boot from a remote server using the network card, that’s why you are getting PXE-E61 Media test failure error. You have to replace the hard drive and reinstall the operating system.
Jan 19, 2009 | Dell Inspiron 1501 Laptop
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
Compaq Presario-Notebook 700 Series, 2500 Series, x1000xx Series, R3000 Series LCDs Displays - 33700 (337005001) CD-ROM Drive Logo
384 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
