Question about Canon PIXMA MP520 InkJet Printer
Paper wont feed propaly
The paper is feeding wonky! the roller is on the right is pulling the paper to the right but there is nothing to pull the paper on the laeft side so it is not feeding and I cannot print anything. Brand new printer has worked last 4 times of printing. Help! Thanks I have the same problem with a Canon MP520, of pulling the paper in on the right and not the left. It just started happening and I have been through the cleaning procedure a few times and it doesn't look like anything is jammed. What else can be done. I need to print bad!
  • Anonymous Mar 15, 2014
    when printing the paper won't feed into printer makes all the noises but just doesn't pull through
    Problem Solver:
  • 11 Answers
It sounds like the motor on the left side went out. If it's a brand new printer your best bet would probably be exchange it at the store or see if the manufaturer has a warrenty. If it's an older printer I probably wouldn't try to get it repaired, printers are getting cheaper these days and it probably wouldn't be much more to get a new one.
Posted on May 26, 2009
    Problem Solver:
  • 5 Answers
Have you tried flipping your machine over and shaking it? Sometimes it only takes a little "something" to fall into their and block the paper feed so the machine ends up dragging one corner down instead of the whole page.
Posted on Oct 16, 2009
2 Suggested Answers
SOURCE: paper wont feed propaly
Toss the canon. Mine last two have died like that... one after 1.5 years, this newest 4300Pix after only a few months. Starts to feed the paper crooked, seems like there is a jam, but never one, no paper jammed. Product control is terrible with most printers now.
Posted on Oct 22, 2007
How to replace pickup rollers
This should help. Good luck !
Cassette (Tray 2) paper pickup and feed rollers
To remove the paper pickup and feed rollers
1 Remove the cassette.
2 Locate the two rollers on the bottom of the paper pickup unit (above the cassette). The pickup
roller is the smaller roller, and the feed roller is the larger roller.
3 Pinch the tab on the end of the cassette pickup roller (callout 1), and pull the roller out.
4 Pinch the tab on the end of the cassette feed roller (callout 2), and pull the roller out.
Figure 6-24 Removing the cassette pickup and feed rollers
Note Always replace the cassette pickup roller and the cassette feed rollers at the same time. Also replace
the separation roller (located in the paper cassette) when replacing these rollers
Aug 14, 2014 | HP Color LaserJet 4600n Printer
When the printer pulls a sheet down it grabs the right side of the sheet (as you face the machine) leaving the left side up, to warp the sheet and make a grinding noise trying to pull the sheet in. Of...
Solution: Cleaning The Paper Feed Rollers (Windows) iP1600
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the printer properties.
  2. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  3. Remove all sheets of paper from the auto sheet feeder.
  4. Confirm the following message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. Thisactivation will take about 90 seconds. Do not perform other operationsuntil this operation has finished.
  5. Confirm the following message, and click 'OK'.
  6. After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  7. Confirm the following message, and click 'OK'.
    Note: The following message is displayed when the paper is fed and ejected.
  8. Click 'OK'.
Roller Cleaning is completed.
Jul 02, 2008 | Office Equipment & Supplies
Mp495 Pulling one side before the other causing it to jam
The roller maybe sticky and cause the paper not to feed evenly. Clean the rollers with methylated spirits.
Mar 04, 2012 | Canon PIXMA MP495 InkJet Printer
Paper rollers wont feed paper from paper tray
Pull out a paper cassette, lift up the printer and under you see paper feed roller (it is rubber), just clean roller with cloth and water or alcohol
Sep 03, 2010 | Samsung ML 1710 Laser Printer
The paper twists and causes a jam on every print
sounds like something jamed in the rollers like a pin etc
Jan 05, 2010 | Epson Stylus R265 InkJet Photo Printer
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Riso tr1510
Take one of those flat plastic rulers and push it through all over.. so that any forein ripped paper whatever, clears the way.. The paper is supposed to buckle on entry.. That's how it's designed. It could be a timing issue.. when the paper is fed in it buckles against the timing roller.. the roller turns only when its supposed to. Each sheet stays buckled against the timing roller until it turns, that's how the machine draws only one piece at a time. It's could be the feed clutch.. There's a little magnetic clutch that actuates the feed roller to pull the paper in. when this feed clutch gets weak it barely works or it slips and doesn't pull the paper in at the right time. I've replaced these often on my equipment.. but I've also found that static electricity plays a big role. If your area is too dry, the paper sticks together increasing the resistance, pulling either multiple pages or just too much resistance for the feed rollers.. screwing up the time.. Make all adjustments to the feed rollers first to ensure it's not a huge problem before you start looking for a clutch. Essentially if the paper doesnt make it into the feed roller on time it is a timing issue.. but it's starting from the feed rollers.
Feb 03, 2009 | Sweet Beginnings Cabana Stripes Crib
Lexmark z2300 printer won't pull in paper
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 03, 2009 | Lexmark Color JetPrinter Z23 InkJet
Paper won't feed
Pull out the paper tray and push the paper feed roller towards the machine. Try to turnaround the paper feed roller by hand. Reinsert the paper tray.
Nov 02, 2007 | Brother MFC 420CN All-In-One InkJet...
Something probably fell into that tiny pinch of an area where the paper goes. I have found everything from a Tostito crumb to a chip of drywall blocking my paper feed. Flip your machine over, poke it if you have to, and shake it around til the little bugger falls out.
Sep 22, 2007 | Lexmark X1270 All-In-One InkJet Printer
Canon PIXMA MP520 InkJet Printer Logo
411 people viewed this question
old marine
old marine
