Question about Compaq Computers & Internet
Ids give me the source code of intrusion detection system? how apply the ids??
  • 489 Answers
There are several IDS packages available. Search on SourceForge.net to find both executable versions and source code for intrusion detection systems. Some of them give information on how to set up and configure that particular IDS. You can also find honeypots for a different variation of network protection.
Posted on May 26, 2009
Codes351/420/442/455 what do they mean
(M) Check Engine Light ("Malfunction Indicator Light" or "Check Engine") will illuminate during engine operation if this Diagnostic Trouble Code was recorded (depending if required by CARB and/or EPA). MIL is displayed as an engine icon on the instrument cluster.
P0351 (M)
Ignition Coil A Primary/Secondary Circuit
Peak primary circuit current not achieved with maximum dwell time.
P0420 (M)
Catalyst System Efficiency Below Threshold (Bank 1)
Catalyst 1/1 efficiency below required level.
P0442 (M)
Evaporative Emission Control System Leak Detected (medium leak)
A 0.040 leak has been detected in the evaporative system. (A faulty gas cap may cause this code). Also see TSB 25-001-02A. Note: The respective Powertrain Diagnostic Procedures Manual will direct the technician to determine if the vehicle evaporative system has an external system leak. Examples of some external system leaks are: a loose gas cap, a disconnected evaporative system hose, or a loose hose connection. Remember that the evaporative system may also have an internal system leak. This internal leak may be caused by an intermittent or permanently stuck open Duty Cycle Purge (DCP) valve. This leak source is considered to be internal because any escaping emissions enter into the engine system and not directly into the atmosphere, unlike an external leak. An internal leak may cause one of the above DTC?s. Possible causes of a stuck open (intermittent or permanent) DCP valve are: 1. Corrosion due to system moisture or possible water intrusion into the system.
P0455 (M)
Evaporative Emission Control System Leak Detected (large leak)
A large leak has been detected in the evaporative system. See TSB 25-001-02. Also, possible faulty or loose gas cap. Note: The respective Powertrain Diagnostic Procedures Manual will direct the technician to determine if the vehicle evaporative system has an external system leak. Examples of some external system leaks are: a loose gas cap, a disconnected evaporative system hose, or a loose hose connection. Remember that the evaporative system may also have an internal system leak. This internal leak may be caused by an intermittent or permanently stuck open Duty Cycle Purge (DCP) valve. This leak source is considered to be internal because any escaping emissions enter into the engine system and not directly into the atmosphere, unlike an external leak. An internal leak may cause one of the above DTC?s. Possible causes of a stuck open (intermittent or permanent) DCP valve are: 1. Corrosion due to system moisture or possible water intrusion into the system.
May 01, 2014 | Jeep Grand Cherokee Cars & Trucks
GMC P2135 throttle sensor code
Trouble Code: P2135
Throttle Position (TP) Sensor 1-2 Correlation
Possible Causes:
Inspect the TAC module connectors for signs of water intrusion. If water intrusion occurs, multiple DTCs may set without any circuit or component conditions found during diagnostic testing.When the TAC module detects a condition within the TAC system, more than one TAC system related DTC may set. This is due to the many redundant tests run continuously on this system. Locating and repairing one individual condition may correct more than one DTC. Disconnecting components during testing may set additional DTCs. Remember this if you review the stored information in Capture Info.If this DTC is determined to be intermittent, refer to Testing for Intermittent Conditions and Poor Connections .This is what's listed for this code.
Dec 24, 2012 | 2007 GMC Yukon Denali
I have a dell and it said that i had a chassis intrusion I dont know what it means nor what to do help
That just means the case of the desktop was opened by someone.
http://phubner.eng.ua.edu/Files/Optiplex%20GX620/advfeat0.htm#wp1124663
Security Chassis Intrusion Detection note.gif NOTE: When the administrator password is enabled, you must know the administrator password before you can reset the Chassis Intrusion setting. This feature, if installed and enabled, detects that the chassis was opened and alerts the user. To change the Chassis Intrusion setting:
  1. Enter system setup.
  2. Press the down-arrow keys to move to the System Security option.
  3. Press <Enter> to access the System Security option's pop-up menu.
  4. Press the down-arrow key to move to the Chassis Intrusion setting.
  5. Press <Enter> to select an option setting.
  6. Press <Enter> again after you update the option setting.
  7. Exit and save system setup.
Option Settings
  • On - If the computer cover is opened, the setting changes to Detected, and the following alert message displays during the boot routine at the next computer start-up:
Alert! Cover was previously removed.
To reset the Detected setting, enter system setup. In the Chassis Intrusion option, press the left- or right-arrow key to select Reset, and then choose On, On-Silent, or Off.
  • On-Silent (default setting) - If the computer cover is opened, the setting changes to Detected. No alert message appears during the boot sequence at the next computer start-up.
  • Off - No intrusion monitoring occurs and no messages appear.
May 27, 2012 | Dell OptiPlex GX620n PC Desktop
Hi! i want to use snort so that i can detect intrusion on my network, can you give me some source code used on windows 7?
1. use the computer firewall settings to prevent any unathorised access. once enabled, only the user of device can log out to another source and no other entities.
2. install anti virus software program for example, northon antivirus would prevent any foreign media from being integrated without permission.
important notes;
1. only trust what the computer user installs, where every material else is an intrusion.
Jul 21, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Port forwarding tg782t to allow remote desktop
your firewall might have an Intrusion Detection System (IDS) which locks your network if programmed to detect unwanted ports. Work on your firewall first. hope this helps..
Aug 16, 2009 | Computers & Internet
Vac code came on 0455
Jun 30, 2009 | 2001 Dodge Stratus
I want coding in java to implement network-based intrusion detection system
Nice try! Find an upper-class student to give you one-on-one tutoring with your homework.
Apr 03, 2009 | Microsoft Computers & Internet
Source code for agent-based intrusion detection for network-based
i cud help u...but u'll have to show me ur code...i'll need to see it study it n then help u...u can send it via mail...ankur.deathscream@gmail.com...
Feb 04, 2009 | IBM ThinkPad T41 Notebook
Request for Help
Hi, Muhammad, It sounds to like you have been infected with a virus and will need to run an antivirus program at bootup. If you are unable to do this yourself then it is not a big job for a computer technician to do for you. Regards mistyman
Aug 14, 2007 | IBM IntelliStation M Pro 6868 PC Desktop
Computers & Internet Logo
94 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
