Question about Faber Diamante Wall Hood
I HAVE A FABER RANGE HOOD AND THE FAN IS NOT WORKING
It has lights that work and the fan has power into it as you can hear the buzzing noise in both speeds, but the fan is not working
My problem is that i cant find a serviceman to fix as they dont know the brand ???
  • 46 Answers
Sounds like motor is burned up! I have never seen that brand myself? hoods cab be relitivaly cheap i would leave out the service man and replace the hood...just check pricing then make up your mind! but if you found someone really willing to, what you have can be fixed!!!
Posted on May 26, 2009
  • Todd McCormick May 26, 2009
    sounds like motor is burned up! I have never seen that brand myself? hoods cab be relitivaly cheap i would leave out the service man and replace the hood...just check pricing then make up your mind! but if you found someone really willing to, what you have can be fixed!!!
Medium Fan Speed not working
Switch is probably faulty, or wire / connection to switch. If switch and wiring test ok trace wire from that button back to wherever it goes and look there for fault.
May 12, 2014 | Faber TEND30SS300 Decorative Collection...
Faber model inca hc 72. The fan makes an odd noise. It still works. it is 11 years old.
your hood probably needs a service call to examine the motor, please visit http://faberonline.com/service.html to find your local service #, thank you
Jan 30, 2014 | Faber Inca HC SS Stainless Standard Insert...
Faber range hood fan stuck
Can you start the fan while holding the motor? If it runs fine while not in the hood, then likely the fan is rubbing against something that is not letting it get up to speed. If the motor does not run when removed from the hood, then there's something wrong electrically - a start capacitor, bad motor, etc. Try to verify the fan is not rubbing on something first.
Jan 21, 2014 | Faber Kitchen Ranges
Parts -- # 133.0073.597
i need the same part. where did you order it from? thanks.
Jan 19, 2014 | Euro-Pro Faber Axia Isola Plus Kitchen...
Carol LeBlanc
please follow this link to find a servicer: http://faberonline.com/service.html
Nov 25, 2013 | Faber Inca HC SS Stainless Standard Insert...
The switch has stopped working - it has been established that there is power but the switch does not turn on fan
hello dana... the problem is most likely the switch but it could also be the fan motor. to be sure you could rig up power to that motor separately and see if it works. Joe
May 30, 2011 | Faber Kitchen Ranges
I've replaced both lights in my Faber (Classic) cooker hood but though the extractor fan works the lights dont and they're powered by the same source. The light switch is on and the flap close switch is...
Probably the transformer is blown on the hood, please write info@faberspa.com if no in North America or go to : http://faberonline.com/service.html
Jan 27, 2011 | Faber (272607) Kitchen Hood
Fan Not Working
Sounds like a motor problem...but not necessarily. Cut power to the unit. Expose the motor assembly. Turn the fan by hand...if it is jammed or hard to turn...replace that motor. Not that? There is likely a motor connector. Get a test light at the hardware store. Disconnect the motor and then probe the wires coming to the connector from the power side (with the power on again) to see if the tester glows. Yes...bad motor. No, find the bad connection. It is possible that this unit uses a multi switch...if that's the case, there will be three wires coming out of it...One is power in...the others go to the light and the fan. Then, the switch will be the culprit. Hope this helps.
Dec 05, 2007 | Faber Cristal HC 598041 Kitchen Hood
Kitchen Ranges Logo
704 people viewed this question
Top Faber Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Faber Kitchen Range Expert? Answer questions, earn points and help others
