Question about Photography
Darkroom processing with light on
Hi all
I am wondering if someone has ever tried to fix negatives with the
lights _on_ (I mean, switch the lights on immediately after the acidic
stop bath) ?
From what I know about film chemistery nothing should happen but...
So has somebody conducted some fiable, sensitometric tests ?
Please note that I am referring here to an acidic stop bath (2% acetic
acid, pH about 4.5) that should arrest the activity the developer
remaining in the emulsion. But can the higher pH of a "neutral" fixer
let the developer acting again ?
Thanks for any comment,
Marc
  • 39 Answers
The stop bath stops ALL the developer chemestry. You should have no problemo.
Posted on Jul 10, 2009
I have a john deere 2010. with a generator it is a pos ground when I got it someone put a alternator on it dose this change the ground to a negative
To be sure you can use a test light, touch one lead from the test light to the frame of the tractor and the other lead to the Positive + terminal of the battery if it lights up it is negative ground if not touch the negative - terminal of the battery and if it lights it is positive ground.
One thing to check if it was converted to negative ground is that the switched the wire on the ignition coil.
john-deere-2010-generator-pos-ground-qumruwi2utlvsp5qakcuppif-5-0.jpg Using your test light you need to turn the key to run position, touch one lead to the negative - terminal of the battery and on the ignition coil touch the Bat + threaded stud it should light and means it correct and do nothing. if not touch the Dist - threaded stud and see if it lights if it does move the wires on the ignition coil to where every wire on the Bat + threaded stud is moved to the dist - and every wire on the Dist - threaded stud is moved to the Bat +.
There is a good chance your charge gauge is backwards also , it swings in the direction the current runs and when it was reversed so did the needle on the gauge and in the case it does not mean it is discharging.
Apr 12, 2016 | John Deere 420,1020,2010,2020,2510,2520...
Sony55"KDL55EZ711,I POWER ON and only red (led)turns green. I don't get picture nor sound.Tried flashlight test. Negative. Looked in back for,lighting in darkroom and nothing either.witch board is bad
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 23, 2015 | Televison & Video
Can I scan a negative 4X5 black\white to make a photo
In general, yes, you can scan a negative and make a photo from it. I don't really know your model scanner, my Canon 8400f has a film adapter and a light in the cover, but would have to scan a 4x5 in sections and I would have to piece it together after scanning.
The results I get from scanning negs are very good, as good as I ever got in my darkroom.
Oct 31, 2014 | Canon CanoScan 8800F Flatbed Scanner
What is an enlarger?
As an engine is the heart of a car, so is an enlarger the heart of a darkroom. It is the instrument through which negatives are brought to life. Along with a good lens, it is the enlarger that the rest of the darkroom is built around. A darkroom can have the best plumbing, a great stereo and stainless steel trays, but without a good enlarger and lens, it can be hard to produce quality images.
Jan 17, 2013 | Photography
I need an ignition switch wiring diagram
Hi, Nameisonlytwoltrs what a strange name, by the way, nice novella. The solution to this is simple, most ignition switches for motorcycles/scooters have identifying letters stamped near their connection terminals, B/BAT/+ for power input, I/IGN for the ignition circuit, L/LT for the light circuit, A/ACC for the accessories circuit. Now if your switch has no markings you going to need a 12-volt battery, a test light, and a jumper wire with alligator clips. If your switch has 4 terminals there will be 16 different possible combinations for the process of elimination. Connect your jumper wire to the battery positive terminal and connect/hold the other end to any terminal on the switch. With your test light connected to the battery negative terminal start probing the remaining terminals with the ignition key switched to the on position and observe when the test light illuminates completing the circuit. Move the jumper wire to a different terminal and repeat the process. Keep doing this until you find the right combination that makes everything work.
Good luck and have a wonderful day.
Mar 14, 2017 | 2009 Genuine Scooter Stella 150
I need the wire colers for the radio on a 2003 expedition. Someone cut them and trying to fix the radio
Radio Battery Constant 12v+ Wire: Light Green/Violet
Car Radio Accessory Switched 12v+ Wire: Pink/Light Green
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Nov 25, 2010 | Car Audio & Video
My chevy cavalier back lights wont come on i put new sockets and bulbs...what seems to be the problem and how do i fix the problem myself
Either the back-up switch is bad or needs adjusting. It's pretty much when you put your car in reverse, it makes a switch which makes your back-up lights come on. Not sure about yours, but some are located under the gear shift console when the gear shift is moved it will then make the switch, and some are on the transmission. I would try adjusting the switch first, which the car will have to be in reverse to get the lights to come on. It can be a little dangerous, but make sure the car it secured and someone is helping you. Gear shift in reverse, with someone holding the brakes while the switch is adjusted. It hard to explain this process, but wish you luck in fixing it.
Apr 03, 2010 | 1997 Chevrolet Cavalier
Battery drains down over night,new battery alternator is charging
That means that there is a short or a problem to the wirings to car stereo, or doors. No matter if the radio is not mounted.
Inspect all the wirings to car stereo , doors and internal lights.
If you do not find anything you will need to check amps to door, internal lights car stereo, etc, by doing a draw test on this wirings.
This will tell you where the problem is.
Feb 07, 2009 | 1994 Dodge Shadow
Hitachi 43GX10B power issue
Remove back of TV, plugin AC cord & observe which LED's light / stay lit / go out ..
base your continuing research on what you see...................T.
Oct 30, 2008 | Televison & Video
THOMSON SCENIUM 44RW65US Red light flickers
i have the same problem. i have to switch it off at the mains 5 times b4 it comes on
Feb 08, 2008 | Akai LCT2660 26 in. HD-Ready LCD...
Photography Logo
67 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
