Question about Sunbeam 4214 Iron
Auto Shut Off is causing the iron to not heat up
My iron will get hot and then the auto shut off will interfer with it while ironing. What do I do??
  • 50 Answers
Try cleaning the lime out of the steam system. Lime buildup may be interfering with thermostat. Most likely is thermostat is wrong/broke and you should consider just buying a new one
Posted on May 26, 2009
Premature shutting off
Have you try with lower heat setting?
It seems like it might be thermostat or thermal fuse that is not working properly.
Apr 21, 2008 | Rowenta Effective DX1700 Iron with Auto...
My iron doesn't get hot
<div class="solution-text"><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution"><span><span>Hi,<br /><br />Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.<br /><br />Electric Iron not Heating Up or not Working Right <br /><a href="http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not" target="_blank">http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not</a><br /><br />heatman101 </span></span><br /></span></div><!-- /solution text --><!-- helpful bar -->
Aug 26, 2010 | Sunbeam 4237 / 4238 Iron with Auto...
Iron with auto shut off will not restart, why?
The thermostat is the problem, I used aew3656's solution posted elsewhere, and took care of the same problem on my steamer, just take out the damaged thermostat and use it as a sample to get a new one from any electronics supply store, BTW dont forget to buy thermal grease, it helps dissipate the heat so your steamer won't overheat, and the thermostat wont't go off every 2mins.
May 25, 2010 | Homedics PS-200 Iron with Auto Shut-off
Black & Decker Steam Xpress AS250 Iron with Auto Shut-off: my iron won't heat up. the green light comes on b...
heatman101
May 18, 2010 | Black & Decker Steam Xpress AS250 Iron...
The iron will not get hot
heatman101
Mar 02, 2010 | Sunbeam Steam Master 4220 Iron with Auto...
I have a Rowenta Pro. Iron, model DE-86.1A with auto shut-off. It sticks on auto shut-off. I have to move it around for it to heat up, as indicated by the sensor light on the top.
I believe that is how the safety feature works.
Once the iron detects no movement for a certain period of time (the iron assumes you have finished ironing) the iron will shut of the heating element.
One you have moved it around, the timer should prevent it from auto shutting down for a period of time.
Jul 22, 2009 | Rowenta Irons
Black & Decker Iron - Steam Advantage - won't turn on
Just open your flat iron and locate the face plate contactor that has a soot burn causing the filament not to heat,use a sand paper to clean the contact from soot burnt,this the common problem of a flat iron...
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 10, 2008 | Black & Decker Steam Xpress AS250 Iron...
Auto shut off on/ wiill not heat
Hi! Ensure that the unit is tightly plugged into a working outlet.
Some units are equipped with our patented Motion Smart Auto Off technology. Moving the iron will cause it to begin to reheat.
Jan 12, 2008 | Rowenta Power Duo Iron
Auto shut off
either the element is faulty or the switch you turned to give the diffrent tempreture has solder, if it is lose then your iron can repair if it is the element then you have to buy a new iron.good luck.
Sep 06, 2006 | Tefal UltraGlide plus 1656 Iron
Sunbeam 4214 Iron Logo
307 people viewed this question
Top Sunbeam Irons Experts
Wayne Fellows
Wayne Fellows
Craig Butler
Craig Butler
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
