Question about Dryers
NEED TO CONVERT 230V TO 120V
NEED TO CONVERT FROM 230VOLT TO 120VOLT
  • KEN LaPOINT
    KEN LaPOINT May 11, 2010
    Do you want to plug a 120v dryer (gas dryer) into a 240 receptacle? or are you wanting to convert a 240volt dryer to work on a 120v plug?
    Please clarify
  • 952 Answers
You need to buy a power converter to be able to do this. check the wattage requirement for your dryer then get yourself a power converter with the same wattage or higher. Usually, dyers consume around 1000 to 1500 watts.. so you probably need to get yourself a 1500 watt power converter or AVR (automatic voltage regulator) AVRs usually has 220v and 120v sockets...
Posted on May 26, 2009
Need directions on how to pull out the Armature of BOSCH CS20 and convert it to 220volts internally?
Buy a second hand step down trafo 230v to 120v to made it a sheaper project , its not worth for this kind of handpowertools to customize it.
On marketing technical reasons, there are no equivalent components for this model cs20 the armature is look a like a Makita armature some type of bosch tools are comparable with parts in several variations. but little differences on measurements.
Dec 20, 2016 | Bosch Saws
Tip
Incorrect paper size while copy in progress for Canon iR2016 series.
Regarding pick-up error "change paper size"or "incorrect paper size" while copy/print:
These may do the trick:
Point of problem:
Paper Pick-Up Assembly
Problem:
Prevention of incorrect Paper Size Error or Pickup Assmbly Delay Jam (0104) upon Cassette Pick-up
Behaviour of copier:
When making a pick-up setting as from the Cassette and starting Copy, "incorrect paper size" error or pick-up delay
jam (0104) may occur.
Possible reason:
When considerable amount of Paper Lint is attached onto the Vertical Path Roller , the feeding power is
undermined and the paper feeding is delayed, resulting in "incorrect paper size" error or "pickup assembly delay"
jam.
Servicing work:
When the foregoing symptom occurs, be sure to replace the 27T/50T Gear [old type] with the 33T/50T Gear [new
type] and the 29T Gear with the new type simultaneously.
Affected machines are:
iR2016J 120V KQW00838 and later iR2020 230V KRS02060 and later
iR2016J EUR 230V KQX19105 and later iR2020i 120V SRB03779 and later
iR2016J 230V KQY08575 and later iR2020i EUR 230V SRC03634 and later
iR2016 EUR 230V KRB61503 and later iR2020i 230V SRE00245 and later
iR2016J EUR 230V TXK10815 and later iR2016i 120V SRH01205 and later
iR2016 120V KRE05112 and later iR2016i EUR 230V SRJ04494 and later
iR2016 230V KRJ07227 and later iR2016i 230V SRL00298 and later
iR2020J 230V KRM01592 and later
iR2020 EUR 230V KRP16433 and later
iR2020 120V KRR07615 and later
on Apr 12, 2011 | Office Equipment & Supplies
I have two Plx 3102 power amplifiers both are 120v yet in my country we use 230v. I am wondering what components that we can change so to convert then to 230v. these power amplifier use the power swit
You don't need to change any componets as ther are step down transformers that will do the job.
Such as this one on E-Bay: http://www.ebay.co.uk/itm/like/201005282899?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=108&chn=ps&device=c&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0-L&ff12=67&ff13=80&ff14=108
Oct 27, 2014 | Audio Players & Recorders
How to wire a ge 15350 timer for two 120 circuits
1) Copy following links for GE 15350 timer single-pole single-throw 120Volt timer (Made by Tork, same as Tork 1101):
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
2) Use following link to control one 120volt load
http://waterheatertimer.org/images/GE-15306-wiring-250.jpg
2) To control two 120Volt loads:
Use wiring illustration above.
2nd 120V load will have black and white wire, same as 1st 120V load..
Connect 2nd black wire to terminal 2.
Both wires must be same gauge and solid wire. Do not use stranded wire under screw-down plates.
Connect 2nd white wire to terminal X.
Except do not connect more than 2 wires to screw-down terminals. Instead join white wires with wire nut, and then add jumper that connects between wire nut and screw-down terminal.
Jan 17, 2013 | Hardware & Accessories
Wiring diagram for circuit breaker IEC 61009-1 to main supply
Copy following link:
http://waterheatertimer.org/See-inside-main-breaker-box.html
Illustrations include 120Volt single-phase, and split-phase 240Volt..
Mains supply is only split-phase 230volt.
Nov 21, 2012 | Electrical Supplies
Powerfix timer insrution
Powerflix appears to be 24-hour 230Volt European version of 12-or-24-hour 120Volt UPM ET170 timer.
Copy following link to help identify timer buttons and download possible manual.
http://waterheatertimer.org/UPM-timers-and-manuals.html#ET170
Aug 31, 2012 | Ace Hardware Hardware & Accessories
How to convert the aircondition tanage in amp
I assume you mean tonnage. If you are looking for the amp amount to run a circuit to your aircond. here is rule of thumb: 2 ton is a 20 amp circuit (requires two 20 a breakers for a 230volt single phase unit)
3 ton is a 30 amp circuit (230v 1 phase)
4 ton is a 40 amp circuit (230v 1 phase)
5 ton is a 50 amp circuit (230v 1 phase)
all these require two breakers, and both breakers should be joined together.
May 11, 2011 | Heating & Cooling
My 2270 jambs paper from tray one every time. I changed the pickup rollers still no help. All my other trays feed properly even the stack bypass
Hi mate,
Prior to your issue i may enlighten you with this source.
Technical Infomation 0105/0101/0102/0103/0201/0202/0203/0204 Jam Code: Paper lint adheres to surface of vertical path roller
Description
Since a type of paper that can easily generate lint was used, the paper lint adhered to the surface of the vertical path roller and decreased the paper feed performance of the roller, causing the jam code "0105."
Depending on paper sources, the following jams occur.
- Cassette 1: 0105 (registration sensor PS9 delay)/0201(cassette1 retry sensor PS10 stationary)
- Cassette 2: 0101 (cassette 1 retry sensor PS10 delay)/0202(cassette 2 retry sensor PS11 (cassette pedestal) delay)
- Cassette 3: 0102 (cassette 2 retry sensor PS11 delay)/0203 (cassette 3 retry sensor PS1 (cassette pedestal) delay)
- Cassette 4: 0103 (cassette 3 retry sensor PS1 (cassette pedestal) delay)/0204 (cassette 4 retry sensor PS2 (cassette pedestal) delay jam)
To prevent this, a vertical path roller to which paper is hart do adhere was used for the following machines (the color of the roller was changed from black to gray).
- iR2230 120V THF03592 and later/120V TW SHD00033 and later /220V CN SHC01553 and later/230V EUR THG02606 and later /230V THH00339 and later
- iR2270 120V SLH28893 and later/120V TW KJN00097 and later/ 220V CN KJL00763 and later/230V EUR KGL54733 and later/230V KGM03613 and later/230V CA SLF02281 and later
- iR2830 120V THK01045 and later/220V CN SHE01035 and later
- iR2870 120V SLG13303 and later/120V TW KJR00054 and later/220V CN KJP00589 and later/230V EUR KGD13135 and later/230V KGE00333 and late/230V CA SLD00411 and later
- iR3530 120V THL01319 and later/120V TW SHK00085 and later/220V CN SHH00829 and later/230V EUR THM01596 and later/230V THN00209 and later
- iR3570 120V SKV61037 and later/120V TW KJU00760 and later/220V CN KJS00928 and later/230V EUR KFW21901 and later/230V KFX02555 and later/230V CA SKT01761 and later
- iR4570 120V SKU23728 and later/120V TW KJX00122 and later/220V CN KJV00690 and later/230V EUR KFQ15439 and later/230V KFR02186 and later/230V CA SKQ01030 and later Field Remedy
When the symptom occurs with the machine without the foregoing serial numbers, replace the vertical path roller.
Kindly rate me !!!!!!!!thank mate.
Sep 23, 2009 | Canon imageRUNNER 2270 Copier
Amcor split air conditioners
This should work find both being 230volt The best is to have it on its own breaker. Thank you J
Dec 19, 2008 | AmcorAire UCHW-H12AF2 Split System Air...
Have to change power input from 120V/60Hz to 230V/50Hz
ok " check the net for plug and power converters that plug in to
Singapore receptacle
Had a set for Europe worked great
Jan 22, 2008 | Miele CVA2660 Stainless Steel Coffee Maker
Dryers Logo
754 people viewed this question
Top Dryers Experts
