Question about Car Audio & Video
It will not turn on when properly placed in vehicle
It will not turn on when in the vehicle
    Problem Solver:
  • 6 Answers
If this is and aftermarket dvd unit there is a wire in the hook-up harness usually a pink colored one that will be labeled for the shifter. emergency brake. or park sensor if this wire is run to a constant ground the video will play at any moment weither driving or not.... if this is a factory unit the best option would be to contact a dealer or local stereo shop.
Posted on May 26, 2009
How do i install my power steering return line
With the engine cold, loosen the steering reservoir filler cap to allow air into tank. Take the lowest fitting loose and let it drain into a bucket under the vehicle. When finished draining remove Line fitting at reservoir. Remove any brackets holding the line in place and remove line from vehicle. Take the line to automotive supply and buy proper replacement using old line to verify fit. Purchase enough recommended power steering fluid to replace what drained into bucket. Install new line in reverse of removal steps making sure seals (washers and/or "O" rings) are properly installed. Dispose of old fluid safely.
To fill reservoir and line: While filling reservoir with engine running turn steering wheel from left to right until wheel stops. Continue filling and turning until all air is out of system and reservoir is at the proper fill level. Check for leaks.
Mar 23, 2015 | 1988 Cadillac Eldorado
4wheel drive wont engage
First, start checking the fuses an there is also an electrial activaced switch at the transmission or transfer case that may be bad.
95-96
Your control knob should say 2wd, 4auto, 4low.
First, we need to narrow it down to a transfer case issue, or a front axle issue.
Step 1) Jack up the front end and place it securely on jack stands.
Step 2) Verify that the front driveshaft turns by hand. When turning the front driveshaft by hand, the front wheels may or may not turn. Do not be alarmed if they don't turn. This is normal for your vehicle.
Step 3) Start the vehicle and let it idle. Place your foot firmly on the brakes, place the transmission in NEUTRAL, engage 4low, then place the vehicle back in park. DO NOT ENGAGE ANY GEAR!! The lurch as the transmission engages could cause the vehicle to lurch and potentially fall off the jack stands.**If you can turn the front driveshaft, the transfer case is not locking. This could be due to a mechanical issue with the transfer case itself, or an electrical gremlin with the control system. Start a new thread with the results of your checks, and we'll go from there.
**If the front driveshaft does not turn, the transfer case is locking properly and we need to continue searching.
Step 4) With the front wheels in the air, engine idling in PARK, spin one front wheel. The other wheel should spin the opposite direction. If both wheels spin in opposite directions, then the front axle *should* be properly engaged. Take it for a test drive (after safely lowering it to the ground, of course). If the front wheels do not spin in opposite directions, there is a problem with the front axle. This could be due to a mechanical problem with the diff, or a failure of the center axle disconnect to engage the passenger side axle shaft. Start a new thread with the results of your checks, and we'll go from there.
Troubleshooting the CAD on a 95-96 is a bit more involved than I want to get into here, and the problems can vary widely. This'll get you started.
97-01 4-door and 96-00 Sports
Your control knob should say 4auto, 4high, 4low.
Step 2) Verify that the front driveshaft turns by hand. When turning the front driveshaft by hand, the front wheels should turn. (If only one turns, don't be alarmed. One wheel sometimes has more resistance in the brakes, bearings, or CV joints. This is normal)
Step 3) Start the vehicle and let it idle in PARK. Engage 4high. DO NOT PUT THE VEHICLE IN GEAR!!! Crawl underneath and see if you can turn the front driveshaft.
Step 4) With the front wheels in the air, engine idling in PARK, spin one front wheel. The other wheel should spin the opposite direction. If both wheels spin in opposite directions, then the front axle *should* be properly engaged. Take it for a test drive (after safely lowering it to the ground, of course). If the front wheels do not spin in opposite directions, there is a problem with the front axle. Start a new thread with the results of your checks, and we'll go from there.
'01-'03 Sport and '01-'05 Sport Trac
Your control knob should say 2wd, 4high, 4low
The transfer case in these trucks functions essentially like the 1st-gens' 13-54 t-case. (i.e. it uses a lockup collar engaged by the transfer case shift motor) The troubleshooting procedure is very similar, but you don't need to worry about hubs or center-axle disconnects engaging.
**If you can turn the front driveshaft, the transfer case is not locking. The shift motor could be falsely reading an incorrect t-case position, or it could be a mechanical issue with the case itself. Start a new thread with the results of your checks, and we'll go from there.
Step 4) With the front wheels in the air, engine idling in PARK, spin one front wheel. The other wheel should spin the opposite direction. If it does, the system should be properly engaged. Safely lower the vehicle to the ground and take it for a test drive. If the wheels do NOT spin in opposite directions, there is a problem with the front differential or axle. Start a new thread with the results of your checks, and we'll go from there.
Keep us updated.
Dec 16, 2010 | 1996 Ford Explorer
Replace alternator in chrysler town and country minivan
REMOVAL
  1. Release hood latch and open hood.
  2. Disconnect battery negative cable.
  3. Disconnect the push-in field wire connector from back of generator.
  4. Remove nut holding B+ wire terminal to back of generator.
  5. Separate B+ terminal from generator.
  6. Raise vehicle and support.
  7. Remove the right front lower splash shield.
  8. Remove accessory drive belt, refer to the Cooling System for proper procedures.
  1. Remove the lower oil dip stick tube bolt (Fig. 2).
  2. Remove wiring harness from the oil dip stick tube
  3. Remove the 3 mounting bolts.
  4. Lower vehicle.
  5. Remove oil dip stick tube from vehicle.
  1. Roll and remove the generator from vehicle (Fig. 3).
INSTALLATION
  1. Roll and place generator in position on vehicle (Fig. 3).
  2. Install upper bolts to hold generator in place.
  3. Lubricate the O-ring. Install oil dip stick tube.
  4. Install the upper oil dip stick tube bolt.
  5. Place B+ terminal in position on generator.
  6. Install nut to hold B+ wire terminal to back of generator.
  7. Connect the push-in field wire connector into back of generator.
  8. Raise vehicle and support.
  9. Install the lower mounting bolt and tighten.
  10. Install the lower oil dip stick tube bolt and tighten (Fig. 2).
  11. Install accessory drive belt, refer to the Cooling System for proper procedures.
  12. Install the right front lower splash shield.
  13. Lower vehicle.
  14. Install wiring harness to the oil dip stick tube
  15. Connect battery negative cable.
  16. Verify generator output rate.
Dec 13, 2010 | 2001 Chrysler Town & Country
After changing the brakes and rotors the front drivers side rotor and tire wobble. it seems the rotor hasnt locked into place. is there a keeper that holds it into place or am i missing another part? How...
On most vehicles the wheel holds the rotor in place on the hub. I highly recommend removing and re-installing the wheel. There is a recommended torque for the lug nuts - be certain to look this value up and then torque the wheels to the correct specification.
Dec 03, 2010 | 1995 Toyota Paseo
How do i remove the harmonic balancer bolt to replace the timing cocer gasket on a 1999 ford tarus se
If there is no air-compressor and an impact gun to remove the harmonic balancer bolt, then there are two other ways to remove it. Either remove the inspection cover at the bell-housing and use a large flat head screwdriver to wedge between the flex-plate drive gear teeth and the engine block so that the engine is locked-up, and then remove the harmonic balancer bolt with a long breaker bar and a lot of muscle power, or for the more advanced mechanics and only they should attempt this, place a long breaker bar on the harmonic balancer bolt and then brace the breaker bar up against the frame of the vehicle so that when the engine turns over the breaker bar will stop on the vehicle frame, and keep in mind that the crankshaft will turn clockwise or to the right, and when you are looking for some place to brace the breaker bar be sure that nothing else will get in the way or it will be damaged. Be sure that the breaker bar is on the harmonic balancer bolt properly, and place the breaker bar about 1 to 2 inches from the vehicle frame so that when the engine turns the breaker bar will lock up against the vehicle frame, and while holding the breaker bar in place have someone turn the ignition key and give the starter a bump, and be very sure to keep your hand away from where the breaker bar is going to contact the vehicle frame, or your fingers will get smashed by the breaker bar when it turns into the frame so do not attempt this if you are unfamiliar with using hand tools, and the starter should break the harmonic balancer bolt loose easily, so be very sure that your hands are out of the way of getting hurt when the starter motor is used to break the harmonic balancer bolt loose.
Sep 13, 2010 | Ford Taurus Cars & Trucks
Where is the fuel pump on a 1995 eagle talon non turbo
1995-98 Vehicles
See Figures 7, 8, 9 and 10
On these vehicles, is possible to remove the fuel pump and/or gauge assembly by working through the access panel under the rear seat cushion instead of having to lower or remove the fuel tank.
  1. Properly relieve the fuel system pressure, as outlined earlier in this section, but keep the rear seat cushion off and the connector(s) detached.
  2. If not already done, remove the protector.
  3. Disconnect the fuel pump hoses and connectors, then remove the fuel pump from the vehicle.
0900c152800ad8d1.jpg Fig. 7: The fuel pump is located under the rear seat cushion
To install:
  1. For FWD vehicles, place the fuel pump in the vehicle, aligning the packing positioning projections with the holes in the fuel pump.
0900c152800ad8d2.jpg Fig. 8: When installing the fuel pump, make sure the projections are properly aligned with the holes in the pump assembly
  1. For AWD vehicles, perform the following:
    1. Check to be sure the fuel tank packing is not damaged. If it is, it must be replaced.
    2. Place soapy water on the inside of the packing, then install the fuel pump assembly. Do NOT tilt the assembly during installation.
    3. Apply soapy water to the outside thread of the fuel tank. Use special tool MB994180 or an equivalent spanner wrench to tighten the cap to the specified torque. Make sure that the marks on the fuel tank and pump assembly are aligned.
  2. For AWD vehicles, make sure the packing is installed properly, as shown in the accompanying figure.
0900c152800ad8d3.jpg Fig. 9: On AWD vehicles, you need a spanner wrench to tighten the fuel pump assembly cap
WARNING Make sure the pump assembly does not turn together with the cap when tightening the cap. If the mating marks are not aligned, the position of the flat will not be correct and the fuel gauge indicator light and gauge will not work properly.
0900c152800ad8d4.jpg Fig. 10: The fuel pump packing must be properly installed for sealing purposes
  1. For AWD vehicles, check for leaks as follows:
    1. Apply soapy water to the circumference of the cap.
    2. Choke the vapor hose and main hose, apply and internal pressure of 1.5 psi (10 kPa) or less from the return hose and make sure no bubbles form in the soapy water.
  2. Install the protector and attach the fuel pump electrical connector.
  3. Install the rear seat cushion.
  4. Connect the negative battery cable.
Hope this help (remember comment and rated this).
Apr 07, 2010 | 1995 Eagle Talon
Flywheel inspection cover location.
There is a small cover on the bottom center of the transmission. It's held in by 2, 8mm bolts.
To change the timing belt: first place the right side of the vehicle on a jack stand and remove the right front tire. Remove the plastic cover inside the wheel well to expose the harmonic balancer. Remove the serpentine belt (standard 3/8" rachet will set in the belt tensioner to relieve tension). Remove the harmonic balancer (19mm). Place a jack under the engine on the right side of the vehicle, then remove the engine mount from the top of the fender well, (17mm deep well socket and 17mm wrench required) it is not necessary to remove the mount from the side of the engine. Remove the timing cover, (10mm) it has 2 nuts. Loosen the timing belt tensioner, (10mm) then pry it away to relieve the tension. Slide the timing belt off of the cam gear.
To position the new belt, the cam gear has a arrow on it, and the cylinder head has a small dot. Align the arrow with dot, and make sure it is aligned (the arrow must point up). The crank gear has a notch and the engine has a groove to align the notch. Again, make sure the notch and groove are aligned (they again will be up). Place the new timing belt in position around the crank gear, the water pump and belt tensioner and leave the slack at the top. Again relieve any tension from the belt tensioner, and slide the belt on to the cam gear. Place a slight bit of tension on the belt and tighten the belt tensioner. Use the 19mm bolt from the harmonic balancer and turn the engine 2 complete turns and verify that the cam gear and crank gear are in their proper positions and aligned with the dots and notches. After 2 complete turns of the engine, and verifying everything is still aligned, re-assemble in reverse. No further adjustment is necessary.
Note:There is no timing adjustment for this vehicle, and if you are not properly aligned on the cam gear and crank gear it will not run properly.
Jun 19, 2009 | 1991 Ford Escort
No how to put it back in timeing
To change the timing belt first place the right side of the vehicle on a jack stand and remove the right front tire. Remove the plastic cover inside the wheel well to expose the harmonic balancer. Remove the serpentine belt (standard 3/8" rachet will set in the belt tensioner to relieve tension). Remove the harmonic balancer (19mm). Place a jack under the engine on the right side of the vehicle, then remove the engine mount from the top of the fender well, (17mm deep well socket and 17mm wrench required) it is not necessary to remove the mount from the side of the engine. Remove the timing cover, (10mm) it has 2 nuts. Loosen the timing belt tensioner, (10mm) then pry it away to relieve the tension. Slide the timing belt off of the cam gear.
Jun 17, 2009 | 1998 Ford Escort
Timing belt
You obviously need to replace your TPS, and you may need a new belt tensioner as well. On these cars the timing belt setup is not about no 1 cylinder being top dead center. Here are the proper steps to do a timing belt on this vehicle:
Apr 29, 2009 | 1996 Ford Escort 4 Door
Timing
There is no timing adjustment "at all" for a 1999 escort. If your timing is out, your timing belt has slipped and needs to be replaced.
To change the timing belt first disconnect your negative battery cable, then place the right side of the vehicle on a jack stand and remove the right front tire. Remove the plastic cover inside the wheel well to expose the harmonic balancer. Remove the serpentine belt (standard 3/8" rachet will set in the belt tensioner to relieve tension). Remove the harmonic balancer (19mm). Place a jack under the engine on the right side of the vehicle, then remove the engine mount from the top of the fender well, (17mm deep well socket and 17mm wrench required) it is not necessary to remove the mount from the side of the engine. Remove the timing cover, (10mm) it has 6 bolts and nuts. Loosen the timing belt tensioner, (10mm) then use a 3/8" rachet in the belt tensioner to relieve the tension. While relieving the tension slide the timing belt off of the cam gear.
To position the new belt, the cam gear has a arrow on it, and the cylinder head has a small dot. Align the arrow with dot, and make sure it is aligned (the arrow must point up). The crank gear has a notch and the engine has a groove to align the notch. Again, make sure the notch and groove are aligned (they again will be up). Place the new timing belt in position around the crank gear, the water pump and belt tensioner and leave the slack at the top. Again use a 3/8" ratchet to relieve any tension from the belt tensioner, and slide the belt on to the cam gear. Place a slight bit of tension on the belt and tighten the belt tensioner. Use the 19mm bolt from the harmonic balancer and turn the engine 2 complete turns and verify that the cam gear and crank gear are in their proper position and aligned with the dots and notches. After 2 complete turns of the engine, and verifying everything is still aligned, re-assemble in reverse. No further adjustment is necessary.
Mar 29, 2009 | 1999 Ford Escort
Car Audio & Video Logo
112 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
