Question about Dell Studio 15 Laptop
Disc stuck The disc will not come out, i have a slot drive and so i cant use the paper clip trick. When I hit the eject button nothing comes out and i tried going into my computer and eject it manually and it still wont eject.
    Scholar:
  • 62 Answers
The problem seems to be with your Drive. Just try and remove it out from your machine and then open it up.
If it is still under warranty i suggest you take it to them for a new one, or you can aswell try the paper clip trick but now instead get a longer thin metal pin type of object that will get in more.
Then try and remove the CD out with a supporting Screwdriver incase you need to pull it out.
Posted on May 26, 2009
How do I remove the back of my Gateway ZX6971-UR30P. I have a cd stuck in the disc drive and the door won't open.
Have you tried to use a straightened out paper clip to eject the disc. You should see a small hole next to the eject button on the disc drive, just push the paper clip in that and the drive door should open.
Sep 11, 2013 | Gateway ZX6971-UR30P 23-Inch All-in-One...
Cd stuck in E: drive on my HP TouchSmart 300 PC
You will have to manually eject the disc. take a straightened paper clip and find a little hole near the slot where the disc goes in. Insert the paper clip and it should eject the disc. If there is no hole, you may need to access the disc drive by removing the back panel and/or disc drive faceplate.
Apr 12, 2013 | HP Touchsmart 300-1003 Amd Athlon Ii X2...
Dvd is stuck in my ACER laptop how can I get it out
The Acer 5610 has an emergency eject hole to the right of the eject button on the right side of the computer. Find a paperclip and unfold it (or small allan wrench), push the end of the paper clip into the hole until you feel pressure. Press firmly and the optical disc tray should come slightly out of the machine. Grab and pull the tray out (gently). This should work even without power to the drive on any machine tray optical drive, if the tray mechanism is undamaged.
For a slot-loading optical drive, it's a bit trickier. You can try sliding another object into the slot and using it to pry or lift the stuck disc. The safest option is to use another optical disc or credit card sized item and double-sided sticky tape. Put a piece of the tape on the item and then remove the paper from the other side of the sticky tape. Slide the item into the drive with the sticky tape towards the stuck disc (down for most computers). Once far enough into the drive, lower your item and press the tape firmly onto the stuck disc. Lift up and try to pull the stuck disc up and out of the drive.
I hope this helps.
Oct 26, 2011 | Acer Aspire 5610 Notebook
Disc jam
Hello there,
To manually remove any disk from your ROM tray, simply use a paper clip or any straight wire that can reach up to at least 2 inches long.
1) straighten paper clip.
2) look for the manual eject hole which is usually located near the eject button.
3) insert the pin/clip and push firmly to eject the tray.
Hope this helps.
Apr 14, 2010 | Toshiba Satellite Pro L300 Notebook
My son just put 2 dvds in ps3 and now they are stuck?
Try to press the Eject Button for 20 seconds and i think that will do a force eject
the other way is the paper-clip! Straightend a large paper clip, then with some needle-nose pliers created a tiny L-shaped hooked (about 3/16 or 1/8 of an inch). Inserted the hook side of the clip into the disc slot along the edge. Carefully moved the clip around until I located the hole in the disc, then gently pulled the disc out. Piece of cake, took about 2 minutes!
Nov 28, 2009 | Sony PlayStation® 3 (60 GB) Console
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
My disc drive won't eject.
If there is CD/DVD stuck inside:look for a small hole on the face of the drive and insert a paper clip, and press a bit, the drive will open.
If that does not do the trick, look for an icon on the systray (where the clock is shown) . It represents a square inside which there is disk.The tooltip (bubble) should read Optical Drive Power (on or off). If you click on it it shows a two item menu Power On Power Off with a tick mark near one of them. Click Power ON.
Hope it helps.
Sep 07, 2009 | Gateway Computers & Internet
I got a cd stuck in the cd/dvd drive for my gateway laptop- i dont know the model. tried to hit eject button and ejecting through computor and it will not open. what do i do?
All CDs & DVDs have a tiny hole on the drive tray.
Get a paper clip, straighten the paper clip and insert it into this hole and push the paper clip in gently, the tray will release and pop out, then you can remove your disc.
You can do this without the laptop being powered up or powered down.
Feb 21, 2009 | Gateway M305CRV Notebook
I cant open the disc loader on my laptop
Look closely on the front of you cd drive for a small hole, about 1mm in diameter. This is the emergency eject button. You'll have to use a needle or a paper clip, push it in slowly, increasing pressure when you hit the button inside. The spring will open the drive just a little, then you can just pull it out. Hope this helps!
Dec 27, 2008 | Computers & Internet
CD stuck in ps3 horrible noise cant get out HELP!!!
I had the same symptoms. The reason to my problem was that my 2 year old has pushed *three* disks into the console. I got them out through the following, admittedly pretty weird, approach: I hit the eject button, while gently prodding with another disk into the slot (at a slight upward angle). I could feel the disks inside the console rotating or vibrating as I was *gently* touching them with the fourth disk and hitting eject repeatedly. Somehow, the gentle prodding made one of the disk come out a bit, so I could pull it out easily. (I was pretty surprised when a second disk came out, and then a third.)
Nov 22, 2007 | Sony Playstation 3 (PS3) Console
Dell Studio 15 Laptop Logo
256 people viewed this question
Alun Cox
