Question about Sony XM-1252GTR Car Audio Amplifier
Got a 12"kicker L74ohm sub and sony xm-D9001GTR mono amp
What i would like to know is the sony amp good to power the kicker L7
the sony amp puts out 550 rms at 4ohms and 900 rms at 2ohms the
amp is 2ohm stable .the L7 is a 4ohm dual voice coil when wired in parallel it goes down to 2ohms and when wired in series it goes up to
8ohm load right now i have it wired in series at 8ohms powered by a
sony xm-1252gtr 2 channel amp bridged in mono the amp puts out
340 watts in bridged mode the amp is also 4omh stable in when bridged
in mono its sounds good the sub is in a 1.30 cubic feet enclosure in regular cab truck just want to know if any of these two amps are ok for the L7
  • juan_penaloz May 26, 2009
    i want to know about the sony xm-d9001gtr mono amp is a good
    amp to power a kicker l7 4ohm sub because the amp is rated at
    1300 watts at 2ohms and 950 watts at 4ohms rms or is it to
    much power for the sub
  • 655 Answers
Hello juan_penaloz,
The Kicker L7 has an RMS power range of from 50-750 watts and a maximum power handling capability of 1,500 watts so your Sony amp will power it OK. A more powerful monoblock like the Alpine MRP-M1000 or the Kicker 08ZX750.1 would provide even more power and could operate safely at 2ohms.
You have the voice coils wired properly for the Sony amp. It's OK to have the sub impedance higher, but you definitely do not want it lower than the 4ohms the amp is rated at in bridged mode.
Hope this helps.
Posted on May 26, 2009
Which amplifier i should use with JBL CS-1205T
this sub woofer tube has a rms rating of 275 watts... try using a kicker or orion 600 watt mono amp to run this. the brand name is what tell you about how good an amp is for instance the names i just mentioned rate their amp by standard play frenquencies where as other lower brand names rate their amps by the max out put on certain subs at certain frequencies which may lower their impedance and create more power although you will never play your sub at those frequencies. as for the max power of your sub of 1100 watts that is more than like only at a certain frequency so always only double your rms rating of your sub to find max power handling.
Jan 29, 2011 | Sony Xplod Amplifier XM-SD51X - Class D...
I have 2 12" L7's
the kicker l7 will handle all that amp will put out .. bridge the amp and hold on
Feb 09, 2010 | Lanzar VIBE266 Car Audio Amplifier
Only one voice coil is working on my L7 10" sub? All connections look good. 2 2ohm subs wired to 2ohms with a Kicker zx1000.1 mono amp. why?
If the tinsil wires all look good then chances are you broke a lead in the coil, the only way I know of to fix this is to order new voice coils and a new spider and replace them..
There are places on the web to order parts, you just need to take good measurments of the parts and relay them to the stores.
Nov 19, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Sony xm-D9001GTR mono and kicker 4ohm dual voice coil
its a good amp but dont power ur amp at full put it at about half power
May 27, 2009 | Sony XMD9001GTR Car Audio Amplifier
Kicker sub wont work
Im guessing that it is possibly blown... either you ran too much power to it, or it was hooked up wrong... you should unscrew the sub from the box and look inside to make sure that it is connected correctly.... positive to positive, negative to negative,,, if they so much as touched then the L7 could very well be blown.... smell the magnet and if you smell a burnt smell... it is blown... maybe turn your amp down a little... its possible that it is also in protect mode because you are running too many watts to the amp. Feel free to ask if you have any other questions.... Please rate! :D And good luck... i really hope its not burnt out. that stuff is not cheap.
Dec 29, 2008 | Kicker Car Audio & Video
Price check
that is 2 12 hitting 150 db you got to know what you are doing
Sep 14, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
2006 12" Kicker L7 4 ohm
first whats the range in terms of WATTS that your 12" sub can handle in 4 OHMS ? second , lets check the AMP , POWER ACOUSTIK 1800 WATTS , Now thats a lot of power to drive a single 12" sub speaker . your amp is 1800 watts , per channel is around 500 watts , if BRIDGE thats around 1600 watts rms for ONE channel , if your sub can handle that kind of wattage fine , but it will not blow the amp , what it does is shuts down , some kind of protection mode , it will come back on after a minute or so. I suggest to use one channel in stereo mode , or purchase another sub to use the other channel. i hope this helps AJ
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Subwoofer
Hi yeahonda,
Your Kicker L7 Ohms may be too low for the MA Audio Mono block amp. The MA Audio Amp is probably 2 Ohm Stable. The kicker will either be 2 ohm or 4 ohm Dual voice coil.   To eliminate the low ohms as a possible threat to causing the map to go into Protect, Wire the kicker Voice Coils in Series.  This adds the ohms, so that you either have 4 or 8 ohms.
I am using the following codes to show wiring. VC1+ stands for the Kicker  Subs Voice Coil #1 Postive post. AO+ is the MA audio Amp output positive.
AO+ to VC1+
VC1- to VC2+
VC2- to AO-
This shopuld give you 4 or 8 ohm depending on the 15" L7 setup.  Crutchfield does not carry the Kicker  L7 in 15" They do  have the L5 in 15".
If you know how to read a Volt Ohm Meter, set it to OHMs 20 and measure across VC1+ to VC1- and you should see between 1.5 and 5 ohms..  Do the Same with VC2+ to VC2-.  you should see the same voltage. Also read from the Voice coil metal housing to VC1+ , VC1-, VC2+, and VC2-. and you should not read any ohmage to the case. The meter should say OL, or -1.
Good luck.
Oct 15, 2007 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Sony XM-1252GTR Car Audio Amplifier Logo
442 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
