Question about Crosley Washing Machines
Drain hose to crosley washing machine, where?
Hooking up the washing machine with both hot and cold water hoses, ok, but can't locate the outlet where the washer tub drains into the drain hose. Do I need to remove the back panel to locate it? I know there has to be one, but I can't find where it is located. Please advise.
  • 50 Answers
Looking at the rear of the washer, my Crosley drain is on the left, about 4" from the floor and about 6" from the side. You might need to remove the back panel. Probably should anyway, so you can blow the dust/lint out of it
Posted on May 26, 2009
Hotpoint washing machine wf640 there isn't any water coming through when the rinse cycle is on
could be the filter at the water input location in the back of the machine. Or the screen filter at the spigot-end of the input hose....check both hot and cold. First, turn both hot and cold water off at the wall outlet.
Jan 21, 2015 | Hotpoint Washing Machines
My crosley top loader washing machine wont fill up on cold cycle but will with hot
Sounds like a bad water inlet valve, try changing the hoses from hot to cold and see what happens? may have a bad line also? u can check inlet with a multi meter
Oct 04, 2014 | Crosley Washing Machines
Water is going into the washer very slow during the rinse and spin cycle, also not carring the softner into the machine
Machine is not that old, the wash cycle water intake is ok? maybe bad water inlet valve? try seeing how it works on only cold and only hot water, change the hose lines from hot to cold and see what happens? as for the fabric thingy may have abad clogged line or a tiny hole in line and its going elsewhere
Sep 21, 2014 | Crosley Washing Machines
Amana tandem 7300
What does it mean when a washer leaks from the bottom?
The pump will have an outlet or drain hose, an inlet from the tub and may have a circulating hose outlet as well. If you have water leaking from the washer during a wash or drain cycle, check the area of the drain pump. Look for signs of a loose hose clamp or a leaking hose connected to the pump first. Washer Repair Diagnostic Leaking Water Amana Whirlpool NFW7300WW
Jan 18, 2018 | Washing Machines
Want to find out why my washing machine is leaking water
It is most likely the water pump on the washing machine. Check the hot and cold hose and make sure there are round gaskets on the inside of them and that they are tight on the hot and cold valves.
Also check the drain hose that it doesn't have any holes in it and that the hose is far enough down into the drain . If all that's ok, it's your water pump.
Jun 26, 2013 | Sears Kenmore Elite Electric Dryer 69278
MODEL NUMBER CAWS9234BQ0 CROSLEY Washing machine water leaking
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Sep 03, 2012 | Crosley Washing Machines
Sav365zaww skips the drain and spin cycle - sometimes
it could be that you have somthing stuck in the pump or outlet hose I went to a machine the other day and it had a intermitent fault like yours and it was a coin stuck in the drain hose on the pump when it washed in cold it was ok but when it was a hot wash it expanded the hose enough to allow the coin to flap up into the pump outlet hole hope this might help you
Dec 01, 2011 | Maytag SAV365ZAWW 3.3 cu.ft.
Water drains out as fast as it fills........but not all of the time top load Whirlpool
There is a chance the drain hose has buildup within it and needs to be cleared out. This will take about an hour.
Steps:
  • 1- Unplug the electrical cord on the washer from the wall outlet.
  • 2
  • Unfasten the hot and cold water hoses from the water lines after you shut off the water valves. Use a pair of slip-joint pliers to turn the hose fittings counterclockwise to remove them.
  • 3 Pull the washing machine far enough away from the wall so you can comfortably work on the rear of the machine.
  • 4 Locate the access panel toward the bottom left side of the back of the washer. Use a nut driver to remove the nuts that secure the access panel, and remove it.
  • 5 Find the water pump, which will have two hoses attached to it.
  • 6 Identify which hose is the drain hose by tracing it to the outside of the machine. The pump may also be labeled "Inlet" and "Outlet." The drain hose is attached to the outlet.
  • 7 Squeeze the clamp that secures the end of the drain hose to the water pump, using a pair of slip-joint pliers. Remove the end of the hose from the pump.
  • 8 Insert a plumbing snake into the end of the hose and twist the snake as you feed it through the hose. After approximately 10 feet of the snake is fed through the drain hose, you should see the snake and the clog come out the other end of the hose.
  • 9 Reattach the drain hose to the water pump and replace the access panel. Reconnect the water hoses and turn on the water valves. Push the washer back against the wall and plug in the electrical cord.
  • Hope this helps!
    May 29, 2011 | Whirlpool Washing Machines
    Goes back and forth from cold to hot even when rinsing
    IF UNDER WARRANTY , CALL FOR FREE SERVICE.
    IF HAPPY WITH COLD WASH AND RINCE, YOU CAN
    CONNECT BOTH MACINE HOSES TO A Y FITTING.
    CHOOSE A GOOD QUALITY 5/8 INCH BRASS Y GARDEN HOSE FITTING.
    SHUT OFF BOTH HOT AND COLD WATER TAPS.
    NOW IS THE TIME TO DISCONNECT BOTH MACINE
    HOSE AND CLEAN ANY DIRT IN THEIR SCREENS
    OR BUY NEW GOOD QUALITY HOSES. HOSES ARE AVAILABLE WITH AN ' ANGLED' END FOR USE IN TIGHT SPACES. ALWAYS USE NEW WASHERS.
    CONNECT CLEANED OR NEW HOSES TO MACHINE.
    CONNECT Y 's STRAIGHT INLET TO COLD WATER TAP. CONNECT BOTH MACHINE HOSES TO THE Y
    OUTLET. BE CAREFUL NOT TO TWIST HOSES.
    WHEN HOSES ARE ALMOST TIGHT, TURN THEM
    IN THE FITTING SO THEY ARE OK WHEN FITTINGS ARE TIGHTENED.
    TURN ON COLD WATER TAP. CHECK FOR LEAKS.
    YOU MAY WISH TO CONNECT A HOSE TO THE HOT WATER TAP FOR FUTURE USE. I USE AN OLD SPARE WASHING MACHINE HOSE. I ALSO CUT A FEW
    INCHES OFF OF IT, FOR A SMOOTH END.
    Feb 10, 2018 | Maytag MTW5600TQ Top Load Washer
    Hot water connected but does not fill into the drum? The machine will provide us with a cold wash but on the warm and hot settings the hot water dies not pull through the connection
    Turn off the water valves which supply the water to washer hoses. Switch the hot and cold water supply hoses and tighten. Turn the water valves back on and try to run a wash cycle using cold. If hot water only is entering the wash tub the water supply is ok. If this is the case you can unplug the washer and turn off the water valves. Remove the washer back cover and follow the water connection for the hot water. The water solenoid valve will have two electrical wires connected to it. Interchange the hot water solenoid wires with the cold water solenoid connection. Connect the water supply hoses hot to hot and cold to cold then plug the unit then test the washer on the cold wash. If the problem persists it could be a water hose restriction or the timer circuit could be defective. If you have hot water at the normal pressure purchase a new hot water solenoid valve. With the electrical cord unplugged be sure to restore the correct wire connections on the hot and cold water solenoid. To replace the hot water solenoid remove the hose clamp and hose to replace the old valve. Connect the unit to the water and electrical outlet. Turn on the water and test the unit for leaks being careful not to touch any electrical and moving parts. If all checks ok and the correct temperature work, unplug the unit and reassemble.
    Jun 21, 2010 | Admiral AW22 Top Load Washer
    Washing Machines Logo
    214 people viewed this question
    Top Crosley Washing Machines Experts
    Charles T Nevin
    Charles T Nevin
    Gerry Harvey
    Gerry Harvey
    Oloyede Monsuru
    Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
