Question about Refrigerators
Whirpool bottom mount fridge not defrosting 2 years old
Freezer is fine so far. Fridge section is not as cold. Don't hear defrost running. Some build up of ice is now visible in the bottom freezer. Had it serviced about 2 months ago for same problem. Defrosted manually and was told a ice of ice may have been in the line.
  • 50 Answers
Inside back cover of fridge should be a schematic. If this not computer controlled, there is a defrost timer in there somewhere. It will have 120 V AC coming to it, on to the heating element then back to 120 VAC return. If fridge has a ice maker, it also controls the water valve, filling the tray. Frequently the defrost timer fails, could also be wiring or the heater, but this is unlikely
Posted on May 26, 2009
My bottom freezer gets cold but the top part (fridge) does not. Why? I have an older first addition style
Its defrost problem.When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
May 19, 2011 | Amana ABB1927DE Bottom Freezer...
What should I check if the refrigerator is not cooling/working, but the freezer works fine?
first off what kind of frige and model number,the freezer feeds the fridge so no cold air is being blown into the fridge section from the freezer,open the freezer door,if you don't hear the fan blowing you could have a bad evap fan motor,put your hand on the back wall of the freezer,if there's ice or like snow on it you have a defrost problem,bad defrost thermostat,heater,timer or board depending on the machine,this is why i need the model number,also on some machines there is a damper that opens and closes to let the cold air into fridge section or the door was left open and the air vents are froze up,most common on bottom mount freezers,look at the freezer ceiling and packages,if you see frozen water droplets on the ceiling or packages it's a sure sign the door was left open.hope this helps.
May 03, 2011 | Refrigerators
Freezer working but not fridge
most likely a defrosting problem in the form of a bad defrost timer or element in a unit that age. One way to prove it is a defrosting problem is to remove the contents of the freezer section un plug the unit and place a fan on it for about 2 hours. This will make a water mess so be prepaired for it. Then plug it back in and load it up with the frozen food you removed... If it works fine for a few days then you have a defrost problem. After the test run here .. if it is in good shape still I would have have it serviced.
Jan 16, 2010 | Refrigerators
Freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
Jul 08, 2009 | Refrigerators
Whirpool fridge is warm, freezer is working
Check the back wall of the freezer compartment for ice buildup. Sounds like you have a defrost issue.
Feb 22, 2009 | Whirlpool GB2SHDXP Bottom Freezer...
Freezer working fine, but no cold air to fridge
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control unit
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 29, 2008 | Whirlpool GB9SHKXL Bottom Freezer...
Freezer cold but not frig. section
Switch off frig and let it completely defrost.
Jun 27, 2008 | Maytag MTF2155GRQ Top Freezer Refrigerator
Fridge on top of freezer is not chilling
if you have a french door (also known as bottom mount, freezer on bottom) and your fridge sections(cold air blows from freezer to refrig) is not cooling try this
1. ensure you hear the fan running, its it not, thats it(most likely fan motor
IF fan is running check these things
1. ensure refrig section light shuts off by holding down the switch
2. ensure door shuts
3. clean conderser coils (usually accessed from front through base grille)
4. check for icing in vents, freezer section contain them at top or back, and for a bottom mount the refrig sections vents are under your BIG drawer. if iced try a hair dryer from distance. or empty food into another fridge unplug open doors, and plug back in two days later this should defrost all ice build up
May 02, 2008 | Refrigerators
FREEZER WORKING - FRIDGE NOT WORKING
Ok, got it sussed! [well here's what I did anyway]...
Quite simply, I turned off the fridge-freezer at the mains overnight and in the morning, broke and chucked out the ice chunks that had lined up in the bottom of the freezer section and then turned it back on. I returned that night to see that it was working fine again! Hallelujah, I got my fridge back!!
So it seems that all it needed was a good long defrost, so far so good! I hope this solves your problem.
Jan 07, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
Refrigerators Logo
74 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
