Question about Orange Udg Sling Bag Trolley Deluxe Black
Broken wheel and Handle
Hiya, I'm trying to get my UDG record trolley bag fixed. 1 wheel has blown out and the handle has also snaped off at the top. Apperently Smasonite do repairs but I can't find any contact details anywhere online in Australia. Anyone that can help me with fixing it myself or finding a repair centre I would be a legend! Cheers Jerry
  • jeremy469 May 27, 2009
    Smasonite in Susex st Sydney said they'll take a look at it even though they haven't even heard of UDG.
    Thanks for the ideas but getting the parts (wheel and extendo handle) is gunna be tricky for anyone not in the biz. But they may have some random subsitute that'll work fine.
    Cheers and I'll keep on looking...
  • Michial Gueffroy May 11, 2010
    Do you have a local shoe maker or tent repair place that does luggage repairs?
How do I open a Behringer KXD15 keyboard amp to replace a broken handle?
Looking at pictures on line, you'll nee to remove the electronics panel - take out the screws around the rear edge at the back & the 3 at the top, behind the handle / in front of the panel. I would expect the panel to come out thru' the rear..... Be aware of the speaker lead - could be a bit short so you may need to disconnect it. Once the electronics panel (mixer & amp etx) is clear you should be able to get your hand inside / under the handle & undo the bolts. There's a possibility the if the handle is held on with bolts then there could be "blind" or "Tee" nuts under, so undoing the handle screws may be all you need to do? Take care though, because if they're normal nuts they could drop off into the gubbins! Good Luck!
Jan 14, 2017 | Behringer Music
My handle has broken on my gmx212, how much for a replacement handle??
Call Behringer customer support and they will give you a list of phone numbers of dealers that sell these parts; they will quote you a price.
I did this to get the slide switches for the FX board of the GMX212
Sep 14, 2011 | Behringer V Tone GMX212 2X60 Watt Stereo...
The fan is making a lot of noise. How do I fix it? How does it come apart?
You would need to purchase a replacement fan (you can't repair broken ones). Most peavey mixers disassemble by removing the 2 screws that secure the top handle and then the six xcrews along the top and bottom of the back.
Jul 03, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
How can I do a multi track recording by listening to 1,2 or 3 tracks already recorded whilst recording the fourth?
im guessing the same way u got the 1 2 3 on there? not trying to be a smart *** but if u recorded 3 already do a 4th unless it cant handle it.
May 20, 2011 | Boss Micro BR Digital Recorder
Line in audio from external source i.e. blu ray, or Mac always using xlr in's, records over modulated. Even when using comp or limit general setting. Do I need to use a pad to knock the signal down?
Yes, you need to pad it down. This recorder is likely to accept around a -50 Db and the other sources you mentioned are probably +4 Db. Using a limiter and compressors will result in distortion as your inputs exceed the range those can handle. I would use about a 40 Db pad trial to start. That is a voltage ratio of 1:100. Make yourself a voltage divider with say a 100K and a 1K putting the inout across the series combination and taking the out to the recorder across the 1K.
May 04, 2011 | Samson Technology Zoom H4n Handy Recorder
Behringer's Ultrabass BXL3000 - problem with the DI out, which I think it a loose wire. How do I get into it to find out?
You will PROBABLY find the 4 screws on the sides that screw into the chassis and then get frustrated that it will not come out... MANY of the Behringer things HIDE the other screws as the ones holding the handle... The trick is to get at them... The plastic end covers over the handle have ridges that snap under a metal plate that is over the handle. Carefully pry out the plastic near the handle to release these ridges... pry SIDEWAYS a bit... The ridges snap into small cutouts in the metal... what a pain these are. Use a small 1/4 inch screwdriver with blade vertical right where the handle comes out to bend the plastic outward... Dont reach in very far as the blade will catch the metal... just far enough to catch the plastic cover edge... it is scary. The two handle screws usually go into nut-plates that are a part of the amp chassis.
The DI consists of two sections of an op amp and is truly driven differentally. There usually is a couple of 120 ohm series resistors and a couple of hf bypass caps near the connectors
Feb 07, 2011 | Behringer Ultrabass Bxl3000
I need replacement part broken LCD boss says part not available must buy complete sw. ie. main circiut board 120.00 i am able to handle the fix but can't find part HELP
Most of the LCD's in these are specially made for the manufacturer of the units... It is UNLIKELY you can find a source for just the LCD... They seem to have specific patterns for the use they were made...
Suggest you try to find a busted unit that the LCD is OK on... maybe Ebay... to rob one off...
Nov 23, 2010 | Boss Micro BR Digital Recorder
Maybe stupid question....is it possible to record 8 separate mono tracks on this thing? I cannot seem to select only track 5, 6, 7, or 8. When I try to record onto 5, for example, it is impossible to not...
I believe you have to adjust the levels DURING the bounce operation... I don't think you can do that after.
I would consider using a computer based editing program to handle more than 4 tracks...
Aug 30, 2010 | Fostex Mr 8hd CD 8 Track Recorder with CDr
1st trk cuts off when i try to rec the 3rd trk
You may be running out of available memory. Some sounds MAY require more memory. Cymbals would be one fo example.
Jan 18, 2010 | Akai Mpc2500 Music Production Center
Orange Udg Sling Bag Trolley Deluxe Black Logo
111 people viewed this question
Top Orange Music Experts
Vito Vacirca Jr.
Are you an Orange Music Expert? Answer questions, earn points and help others
