Question about Video Game Consoles & Games
Replacing the back of a psp
Hi again,
I got the instructions on how to replace the front (faceplate) of the PSP, but that isn't my problem.  My problem is that I can't figure out how to replace the BACK of the PSP.  Do you have any instructions for this?  Thanks again.
Krysi S
  • Krysi Oct 23, 2007
    Solution worked great.  Got it taken apart and put back together.  I really impressed my 14 year old.  Thanks so much.
  • 709 Answers
Www.llamma.com look for the PSP page.  Be careful with the backlight cable connector, the dark colored release flips up reverse, back to front to release the backlight cable..
Pictures and tutorial on LLamma.com
Posted on Oct 21, 2007
  • Greg Stokes
    Greg Stokes Oct 23, 2007
    Hi ,
    It requires a full disassembly to change the back, be very careful, The UMD door is very delicate and easy to break when removing it. You may want to go ahead and order one. just break the old door its easier that way if you have a new door.
  • Greg Stokes
    Greg Stokes Oct 24, 2007
    Hi Krysi,
    I am very glad to hear you were successful.  How about clickin on Solved for me.
My analog stick is stuck in the upwards direction. Every time I play a game, the character in the game always moves up and in the game menus, the highlighted option always keeps moving up. I really don't...
Sony is full of it. Yes you can repair it. All you need is a brand new nub (joystick). You can find it on the net for about $5 less shipping depending on your model it is not hard to replace. On a phat (old school psp there are seven screws holding the faceplate. Once the faceplate is off there are two screws holding the nub in place. The slim is almost the same there is seven screws holding the faceplate but the only difference is the last two screws you have to take off is on the top. And once the faceplate is off it's the same two screws holding the nub in place. Replace and screw back in.
Apr 08, 2009 | Sony PlayStation Portable (PSP) Console
Tip
How to Replace Analog Joystick on PSP-2001
If your PSP's joystick won't go in a certain direction -- or characters walk by themselves, this part needs to be replaced. It is sold at the website all the way at the bottom for $16.95 and they can do this repair job for $18 more! However, it's not very difficult. Here are the steps:
Step 1. Open PSP. There are 2 screws on the top of the PSP.
Step 2. There are 4 screws behind the PSP and one on the bottom, as circled in the picture.
Step 3. Remove the faceplate and locate the PSP 2001 Analog Assembly. It is held into the console by 1 black screw, as circled in the picture.
Step 4. Remove the black screw and pry the joystick out of the PSP as shown below.
Step 5. It is important that you remove this clear silicon piece from the old joystick and install it into the new one. Its purpose is to communicate the movement of the joystick from the assembly to the motherboard. It sits between the assembly and the motherboard.
Step 6. After you transfer the piece, pry the motherboard slightly up as you slide the new assembly back in place as pictured.
Step 7. You will need to pry this piece up to slide the assembly into place so that it is seated. Replace the black screw and close it back up.
RELATED ITEMS
PSP-2001 Analog Joystick Assembly
Precision Screwdriver Set
to open PSP, PS2
PSP PSP-2001 Motherboard Silicon/Rubber
on Apr 14, 2010 | Sony PlayStation Portable (PSP) Slim...
I have bought a new faceplate for my psp and I don't know how to take off the original.
Since your replacing the faceplate only, only remove the screws on the outside border. not the two on the right side of the battery.
* The bottom silver screw (located on the bottom part, opposite the top part, which has the USB port)
* The top left black screw (underneath the battery)
* The bottom left black screw (underneath the battery and the left side of the warantee sticker)
* The top right screw (located on the back side of the psp in a hole on the outer casing)
* The bottom right screw (located on the back side of the psp in a hole on the outer casing)
Then do the reverse to put it back together.
Dec 18, 2008 | Video Game Consoles & Games
Psp Problem
THESE STEPS WILL VOID YOUR WARRANTY!!!
You will need:
1 Fairly Small Screw Driver
Something Soft to protect your screen (Optional)
Something sticky to hold your small screws (Optional, but recommended)
Ability to remember where you removed screws from =D
1. Flip your PSP on the front side (screen side).
2. Unscrew the two screws on the outside opposite of the battery.
3. Open the battery panel, and unscrew the screws under the battery.
4. CAREFULLY, take off the faceplate and make sure your L/R buttons are properly secured and clear from dust/dirt.
5. Check the 'Home', 'Start', etc., buttons for anything that may "jam" them.
6. Reassemble your PSP by screwing the screws back into their proper areas.
AGAIN, this will VOID any warranty you have and I AM NOT responsible for any damages to your PSP!!!
Sep 18, 2008 | Sony PlayStation Portable (PSP) Console
Cracked psp screen
Youll have to open it up and look if the screen is cracked or the cover, the screen is behind the clear perspex of the outer case.
If its the screen then this will help:
http://cgi.ebay.co.uk/LCD-SCREEN-REPLACEMENT-For-PSP-SHARP-W-BACKLIGHT-Tool_W0QQitemZ200215724197QQihZ010QQcategoryZ127746QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Otherwise you ll need a new case:
http://cgi.ebay.co.uk/SONY-PSP-FACEPLATE-PSP-FACE-PLATE-REPAIR-PARTS-black_W0QQitemZ180232659514QQihZ008QQcategoryZ127746QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Apr 15, 2008 | Sony PlayStation Portable (PSP) Console
Psp button problem
try taking off the faceplate and replacing the buttons. to do this, remove all the black screws out of the back, and the silver on the bottom. take the battery out, under there is two more black screws, one is hidden under the warranty sticker tho so if its still under warranty, i recomend you take it in. if not, rip the sticker off and take out the screws. the face plate will just pop off, leaving you free to re-adjust the buttons or replace them.
Mar 09, 2008 | Sony PlayStation Portable (PSP) Console
Psp
Hi knighty1,
go to http://www.psptree.co.uk/store they have replacement parts for almost everything PSP related!
Please rate if at all useful, thanks!
Nov 29, 2007 | Sony PlayStation Portable (PSP) Console
Psp "R" Button problem
Hi Erikthug22,
You will have to open up your PSP to get to the contacts of the R button.
  1. REmove the battery
  2. Remove 4 screws from battery compartment
  3. Remove 1 screw from front edge under the PSP logo.
  4. Remove 2 screws from back on opposite side of battery.
  5. Lift the faceplate from the edge above the LCD slightly.
  6. Lift the front faceplate edge under the Home/Start button.
  7. You need to be very protective of the little screw hole that is under the PSP logo of the Faceplate..
  8. Do not touch the LCD screen if you can help it. If you do use a lint free cloth and windex glas cleaner to remove fingerprints and lint. Same thing for faceplate window.
  9. REmove the R button
  10. lift the rubber pad/frame behind the R button straight up.
  11. Clean the back of the rubber piece with a Q-tip and Rubbing alcohol.
  12. Clean the contact pad that is behind the rubber pad/frame.
  13. Press the rubber/fram piece back into place carefully.
  14. Put your R button back on.
  15. Be sure your LCD sreen and inside of faceplate window are clean.
  16. Refit the faceplate.
  17. Reinstall screws.
Nov 04, 2007 | Sony PlayStation Portable (PSP) Console
Psp joystick problems
Good day all
I recently ran into this same problem of a PSP joystick "jumping" or hopping around. Since I'm an electronics engineer I was determined to get to the bottom of this annoying problem, I read all the posts on the site and none helped, but the problem turned out to be much easier fixed than I first anticipated.
First of all I assume that you know how to take the PSP apart and take out the joystick module as well. The Joystick module connects to the PSP mainboard by means of 4 contacts, seperated by a spacer conductor that appears like a rectangular rubber, be careful not to lose this during the process.
Here is why the problem occurs, when you have a faulty joystick module, one or more of those 4 contacts don't connect to the main board anymore, so the when the PSP is trying to measure the resistance to determine the joystick position, it reads a varying value, i.e. the contact is floating.
This happens for mainly 2 reasons, dirt or a faulty module, as stated in the previous posts, the contacts could be dirty, but this can usually easy be seen, and this wasn't the problem in my case, I had a faulty module, but luckily all is not lost.
Here's how to fix a faulty module in most cases. Remove the joystick module from the PSP completely, put that little rectangular rubber on the 4 contacts (clear in my case) aside and keep it safe. There is metal clasp on the bottom of the module, you can simply pop it off with a screwdriver, by slightly bending the clasps on the side and taking it off. Now you should be able to see a VERY SIMPLE mini circuit board with tracks on, on the bottom of the module, you can indeed pop this off too. On this you will see tracks where the joystick sliders move. Put the circuit board aside too. Now look at the now completely open joystick module, you will see the two sliders each having a metal part, each of these metal parts has 2 very small contacts that run on the circuit board tracks that you just removed, most times these small contacts get bent inward and they can't make contact with the circuit board tracks anymore. Just bend them slightly outward again, so that when you put circuit board back, they touch the tracks on the board nicely. Put the circuit board back, it just slips back on, put the metal clasp back, put the rubber back in over 4 contacts on the module and voila, if all goes well you will have a nice working joystick module again. Put it back in the PSP and test it to see if it worked. In my case it worked 100% and saved me a few bucks. Hope this helps everyone. Let me know if it worked.
Oct 16, 2007 | Sony PlayStation Portable (PSP) Console
THE POWER SWITCH
If it's under warranty send it back, if it's not then do this. Order a replacement power switch online, ebay is pretty good for psp parts. There's 5 screws holding the front cover of the PSP together two on the right that are recessed, you'll need a long skinny precision screwdriver , there's two more under the warranty stick behind the battery and one more in the middle of the silver metal piece. The power stick assembly is a separate board that plugs into the psp and a easy repair. Just be careful once you remove the faceplate one dust particle and you'll be taking it apart again to clean the inside of the screen.
Jan 17, 2007 | Sony PlayStation Portable (PSP) Console
Video Game Consoles & Games Logo
62 people viewed this question
Top Video Game Consoles & Games Experts
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
