Question about Compaq Presario 5000 PC Desktop
My Compaq Presario asked for login information. After I typed it in and the computer loaded, the screen went blue. I turned it off because it wouldn't respond. When I turned it back on, it let me open a webpage and then vertical stripes appeared and a pattern filled the page. The computer started beeping. Now, the computer won't come on. Any suggestions?
  • 700 Answers
Base from your statement I can only say only in general. If that not ask a login pass before. This could be a viral activity in your system. It could be a faked alert. Or just a features of your unit.
Either way if this is not a viral activity blue screen mean a driver and hardware conflict. Beeping means memory or video card loose contact or dirty, or fail already.
But to sure I will have your harddrive to be scan by antivirus or antimalware thru another computer, first. Then troubleshoot the unit without the harddrive just using a plain bootable DOS disc. For this you can isolate which one is faulty, a hardware failure, viral, or driver hardware confict. And also OS problem.
Hope I give best possible solution.
Posted on May 26, 2009
COMPAQ presario cq57 has a blue screen and white curser
This means nothing specific, try to load Last known good configuration, by holding F8 key right after power on, until it shows Windows boot options. You should also check memory, hard disk drivers and viruses, but this is much longer explanation, so ask if needed.
Dec 01, 2012 | Compaq Presario Notebook
I have a presario cq61 and have forgot my password can u help
Try starting the computer in safe mode. Turn on the computer and once the COMPAQ screen clears press F8 a few times - don't hold down the key however. Winodws stops loading at teh Startup Options screen (black, text only). From that menu use the cursor keys and ENTER to select "Safe Mode". Once Windows loads (it may look humungous!), login as the Administrator (which should now be visible). Use this account to reset your forgotten user password. Restart once complete - the computer will automatically start normally.
Apr 14, 2011 | HP Compaq Presario CQ61420us Notebook
Compaq Presario SR1000 won't boot up completely :(
Hi Thanks for your question
I would suggest to enter "safe mode" and then do system restore again. To do this you need to follow these steps.
1.Turn your PC on and press F8 on start up. This should take you to the screen asking what you want to do. 2. Choose safe mode from the list and press enter. 3. Once safe mode loads you should be asked if you want to restore your system to previous state. Just press no to run system restore and follow steps (you already know how to do this)
Shutting your computer down without closing operation system properly may cause start up issues like this one.
I hope this helps you. Good luck
May 26, 2010 | Compaq Presario SR1000T (568657) PC...
Blue screen compaq presario vista
yes look first try to reinstall the operating system if the problem is still your harddrive must be crashed
Oct 24, 2009 | Compaq Presario C700T Notebook
My Compaq presario f572us notebook screen turns black upon normal startup. The screen does not turn black if I start-up in the safe mode. It only when i attempt to start windows normally. Everything loads...
i also have a compaq presario f572us that's been having similar problems. when i went onto the hp website i saw that apparently they've been having similar problems with this type of computer as they offer free repairs for 2 years after you bought it. you should probably check if this works for you too
Oct 23, 2009 | Compaq Presario F572US Notebook PC
System driver problem
load WinXP professional on your computer, and this will solve your driver problem. good luck
Sep 08, 2009 | Compaq Deskpro EN 6500+ Model 6400 CDS PC...
When XP Media Center starts installation, computer freezes
Leave the CD in and restart and see if that completes the install.
Feb 18, 2009 | HP Compaq Presario Media Center SR1750NX...
Wrong battery detected.
hmmm..interesting....you may need to download the system drivers, usually for bios or other utility programs. the compatibility issue with batteries, is based on the make/model being loaded into the listings from the sysadmin for your operating system.
www.hp.com
Feb 25, 2008 | Compaq Presario R3000 Notebook
Mymonitor is black and the on button from the monitor is green and is flashing
i havent seen this question asked, and believe me i have searched. i have compaq presario, windows xp media edition 2005, 64 amd processor, model # SR2017CL, with HP 1703 17" monitor. Prob-put computer in hibernate mode other evening, without turning it off. when i woke up, screen had diagonal lines going across it. i rebooted, well manually restarted, since comp would not respond.
Message comes up white with black writing, essentially, prob with active desktop, restore or turn off. i tried to turn off and screen went back to diag. lines. looks like the horizontal hold of a tv screen is asque. tried adjusting monitor to no avail.
tried a few more times, was fine for a few mins then went to same thing. now when i turn monitor on it blinks red, blue, and so on.
just whole screen that color. so i am at the point where i dont
know if its the comp or the monitor. (i am quite a newby)
ty for any help you can give
ellie
Jan 30, 2008 | HP Pavilion F1703 17" LCD Monitor
Compaq Presario 5000 PC Desktop Logo
104 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
