Question about Mtd 22" White Outdoor Self Propelled High Wheel Mower
Self propel won't allow the mower to back up freely. works fine moving forward.
I have an MTD front wheel drive 21" cut 6.5 HP honda lawnmower. The front wheel self propel won't allow the mower to reverse freely. Is this an adjustment to the drive unit or do I need to replace the front wheel drive transmission?
moretons
  • 155 Answers
SOURCE: I need an owners manule for an old mtd yardman 6.5
try the mtd website
Posted on Jul 25, 2009
SOURCE: Honda HRB 216 self propelled mower Cable Broke for self propelled
there is a panel in front of the gear that completes the curve of the blade path that you can remove with a single bolt on the outside of the mower between the wheel and the deck
Posted on Aug 07, 2009
vincob
  • 718 Answers
SOURCE: my craftsman self propelled lawn mower no longer
if it is a belt driven drive check the belt for tension or break. or check the cable that engages the drive wheels.
Posted on Sep 04, 2009
rwvanlue
  • 486 Answers
SOURCE: MTD front wheel drive self-propelled 21
Yes it can be fixed. Try some basics first.
1) Check under belt drive cover for excess debris
2) Belt and Idler pulley condition
3) Control cable operation
a) rusted, frozen, broken, disconnected
Posted on Dec 04, 2009
eugbug
  • 479 Answers
SOURCE: The self propelled just quit working. The front
Drive cable or drive belt could have broken
Posted on Sep 04, 2010
The right rear wheel intermittently locks up on my lawnmower when going forward stopping forward movement temporarily, until I move it backwards to "unlock" it. Any ideas?
There is an excellent 3 part video that may help you to fix this problem. Please see the 2nd and 3rd videos:
https://youtu.be/Vk_tpjKlbjM
https://youtu.be/DdiewLxTQDc
Things you can try:
(1) Remove casing over rear wheel drive assembly and perform a test run to assure all parts are moving as expected
(2) Lubricate the shafts with lightweight motor oil where the shaft penetrates into the gear box of each wheel
(3) Remove each rear wheel, inspect gears for damage and free movement. Grease up each drive gear and the shaft.
(4) Inspect gears on each wheel for damage.
(5) If none of the above fixes the problem, try swapping out the front wheels to the rear wheels provided the front wheels can accommodate the gearing on the rear wheels
(6) If this doesn't work try replacing the small gear assembly on the right rear wheel
These steps are illustrated in the videos.
Good luck and hope this helps.
Oct 11, 2016 | John Deere JA65 Self Propelled Mower
What is the sprkplug gap for a 6.5 briggs &statton
Contact MTD if your manual doesn't cover this, or buy a shop manual. Or go to the Briggs & Stratton website.
May 20, 2014 | Mtd Yard - Man 160cc, 21" Self - Propelled...
How to remove rear drive wheels on old MTD 21
Daren Ingold's suggestion works only for the right rear wheel on my 19+ year old MTD Yardman 21" self propelled mower. The ratchet spur on rear left wheel is held on by a bolt in the center of the axle and a spline. Remove the center bolt and washer. Pry the ratchet spur off the spline by using three medium blade screwdrivers wedged between the wheel and the spur gently tapping the three screwdrivers in succession until the spur is half off the spline. It will come off easily after that. Remove the spur, noting direction, and remove the wheel and replace it with one of the front wheels (they're all the same design) if it is in better condition and use the rear wheel for the front. Good luck ever finding a new replacement for this particular wheel. My mower is 19+ years old but runs perfectly otherwise. Stored in dry basement.
Sep 23, 2012 | Mtd Yard - Man 160cc, 21" Self - Propelled...
How much oil should i put in my kawasaki yard-man 6.5 hp 21"cut lawnmower?
Fill it to the line on the dipstick no more.They usually do not take more than a quart. Good Luck..
Mar 31, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
MTD front wheel drive self-propelled 21". Self-propelled does not work. Can it be fixed?
Dec 03, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Self propelled Yardman won't engage - cable problem I think???
are you in vero beach if so you can email me and i can fix it tj_gunter@comcast.net
May 21, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Blade too close to ground
move them foward to raise wheel height. you can confirm by moving to full foward posistion on front wheels then adjust down to get height you desire.and repeat with back wheels and set accordingly. hope this helps..chris
May 12, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Mtd 22" White Outdoor Self Propelled High Wheel Mower Logo
460 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
