Aiwa LX770 Turntable won't start
I inherited it from my late brother in-law, I would to upload his record collection to my PC. I have sound cables cord for the sound card. There is another cord with a mini plug I am not sure what is for. I have power but can not get it to play.
It's a bit after Jim's post, however I had what appears to have been the same problem with my LX770 after it had been stored in the loft for quite a few years. I found the problem to be caused by the tone arm mechanisms stalling - The band that was associated with lifting the arm had turned to a black gunge and was not allowing the motor to rotate, also the motor associated with moving the arm backwards and forwards was struggling to turn. I cleaned the tone lifting pulleys and replaced with a small elastic band (for a temporary fix). This was a little fiddly as you have to take off a spring and a couple of gears to get the new band in place. I cleaned the runners and cleaned off the grease on the worm gears associated with the arm tracking (as I suspected it may be more viscus than originally installed), lightly oiled the tone arm tracking gears. It still seamed to take an amount of helping the tracking arm gears until they were able to move freely. With the tone arm mechanisms working properly the whole unit now seams to be working.
Top tips if you attempt this: WARNING - If the unit is plugged in, the transformer and high voltage wires are live regardless of whether the on button is on or off on the front of the record deck. PLEASE do not take any of my comments as recommendation you should ever do anything with the unit plugged in! Remove the little stylus carrier before you start taking the player to pieces - saves damaging it! Remove the record mat and aluminium platter before turning the unit upside down. Manually push the tone arm to about 0.5cm from its furthest travel - so you can remove the tone arm mechanism plate. May be a little stiff as the wires have to slide of the pulleys for the tone arm to be pushed. To access the tone arm mechanisms, remove the main bottom plate (and greasy spring), then undo the screws which hold on the rear undertray. With the decks buttons toward you, you should then be able to lift the rear tray slightly and tilt the tray towards you to expose the tone arm mechanisms. You shouldn't need to remove the circuit board with the control buttons on the front of the unit.
After getting it going, I found that I needed a Phono preamp to get the signal strength necessary to use the deck for transferring vinyl to my PC.
Good luck
Posted on Jan 30, 2011
  • tshed Jan 30, 2011
    PS I believe that the cord with the mini jack is for use with syncro start for recording with a tape deck or similar - This shouldn't stop the record deck from working if it is not plugged in to anything.
I am trying to play a record on my Aiwa LX-120 turntable but after scanning the record the arm won`t go down.
I'm not certain that you are meant to disengage the FG lock since this means that the turntable has achieved the correct speed. The problem you have is that the arm won't go down.
I don't know to much about the workings of this direct drive turntable. But I can say you can get the service manual free on-line if that helps.
May 01, 2015 | Aiwa Audio Players & Recorders
I have an AIWA PX-E860 but am unable to find my manual. Can I record albums onto CD's without buying any extra equipment? Thanks!
If you can connect the turntable to a computer and when it's playing hear the sound from your computer speakers then no you don't need anything else. However you will need software to record it and put it on a CD. There are free software out there, but I wouldn't recommend downloading it, as it could be full of nasty things that you don't want on your computer. There are some cheap software packages on places like Amazon, such as Sony Sound Forge or my personal favourite Magix Audio Cleaning Lab.
Aug 17, 2013 | Aiwa PX-E860 Turntable
Aiwa turntable px-e860: Hi, I've inherited this timetable from a friend and it's worked fine until recently but now here's the problem: if I push start, the arm lifts up, moves to the record...
Hi, I;m not familiar with that exact model however the problem you are describing is commonly caused by the automatic operation at some point not being allowed to complete its full operation. Ie the tonearm has been returned manually to its rest position before reaching the end of the record. Try this. With the player not powered up lift the tonearm across to the record run off groove and sit it there. You may feel some resistance which is normal as the mech has to eswt itself. Now turn on the power and turntable. The arm should automatically return from there to its rest. Try auto operation after that. Let me know how you go. Cheers John. styluscity@gmail.com
Oct 10, 2011 | Aiwa PX-E860 Turntable
Do i need a record turntable with a biult in amp for my aiea Z-L30
Do you mean AiWa Z-L30?
Generally speaking, if a device doesn't have an input specifically marked "PHONO" it does not have the requisite PHONO preamp for an old-school turntable.
Aiwa plays a word-game on this device and labels an input "Phono" while specifying on page 20 of the manual that you should use a turntable with a built-in EQ Amplifier. In other words, the input should have been labeled a second "AUX IN' as it will accept any sound device that has a Line Level output, not just Phono.
So yes, you need a self-PRE-amplified TT with this product.
http://www.retrevo.com/support/Aiwa-Z-L30-manual/id/1076ci560/t/2/
Feb 13, 2011 | Aiwa Z-L30 Shelf System
I have an Aiwa PX-E80K turntable. Whenever I start the turntable, the tonearm raises moves across, drops on the outer edge of the vinyl then then turntable stops. The belt is still attached. Anyone able to...
I suspect the belt is that slack that when the arm weight is on the record, the belt slips around the shaft of the motor. Does it start up again when the arm is lifted up? If it does then you need a new belt.
Jan 09, 2011 | Aiwa Audio Players & Recorders
Can you still get the px-e860 turntable? The one I have won't make any sound thru the speakers
Judging by my own experiences with hifi gear on eBay there is little on the face of the planet that ever really becomes UNavailable.
Wouldn't an attempt to resolve the issue work, too?
Describe your setup (preamp, amp, whatever) and if it has ever or never worked.
This unit can work through its own preamp with any audio equipment or with old-school gear already having an internal Phono Preamp. There's a switch to select which one.
Apr 08, 2010 | Aiwa PX-E860 Turntable
Does turntable have a magnetic cartridge?
Styli supplier "me.and.lurch" on eBay informed me that my AIWA turntable already had a pre amp built in.
Apr 10, 2009 | Aiwa PX-E860 Turntable
No sound from speakers when turntable playing records
hi,, please check your RCA cable...or replace it possible...
Mar 12, 2009 | Aiwa PX-E860 Turntable
357 people viewed this question
 Grubhead
Grubhead
