Question about Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I have blinking yellow light on my toshiba tv
The cable went out then the tv shut down I tried to power it back up and all I get is blinking yellow light. I checked the owners manual and said it should reset. I don't have any money right now I will have to check back with you
  • 5 more comments
  • wgrady May 26, 2009
    I have disconnect the A.C. power and I change the batteries in the remote control.
  • wgrady May 27, 2009
    the model # for the toshiba television is 42rv530u
    after powering the tv back up I get three blinking ligths real fast I try to power it back on and I get nothing.
  • wgrady May 31, 2009
    I get 3 blinking lights then it stop i have unplugged my television and i still get the 3 blinking lights what am i to do
  • Justin Rubsam
    Justin Rubsam May 11, 2010
    The tech manual on this one says that there are a few different yellow blink codes. A fast blinking yellow light after restoring the AC power (or after power outage) is normal, and in an ideal situation should STOP blinking after a while at which point the TV is 'booted up' and should power on.
    Is this blinking light a constant 'fast blink', and if so, does it stop blinking after a few minutes of being plugged in... or is it blinking three times, stopping, then blinking 3 times again?
  • Justin Rubsam
    If you post an exact model number I'll look it up in the database to see if there have been any other recent instances of this problem with this set. Model number will be on a tag on the back.
  • Justin Rubsam
    Have you tried unplugging the AC power for about 10 minutes and retrying?
SOURCE: Doesn't power on - Amber LED Blinking
Here's how I fixed mine...
Look inside the back of the TV just above the power cord - there are two small LEDs, one green and one yellow (no need to open the case - you can see them through the cooling slots). In my case, the green LED would light for a few moments after plugging the TV in, then the yellow one would light and stay lit.
Go to the Toshiba site and download the latest firmware upgrade.
Copy the firmward upgrade to a SD memory card using your PC (SDHC cards larger than 2GB don't appear to be supported by the TV, so use a smaller one). I copied *both* the zip file as downloaded from Toshiba, and the contents of the zip file. That is, I expanded the zip file and copied the contents to the SD card as well.
There's a metal cover over the SD card slot on the back of the TV. Remove it (a single screw)...at one point, Toshiba has directions on the firmware download web site.
Unplug the TV and insert the SD card. Plug in the TV again, and in my case, those little LEDs stayed green. I saw none of the instructions on the TV screen - rather I just let it sit for about 10 minutes, then I unplugged the TV, removed the SD card, and plugged the TV in again. Viola - the TV works.
I'm thinking perhaps Toshiba uses a type of memory that requires battery backup, and if the TV is unplugged for an extended period of time, it's necessary to re-flash it.
Posted on Jun 21, 2009
techman
  • 3130 Answers
SOURCE: TV auto shut off-power indicator light blinking-won't turn back on
You could have gotten an electrical surge that put your set into a shutdown condition and unplugging the set and letting the Microprocessor reset will fix this problem if it dosent blow out the main power regulator as you still or might I say have a regulator IC problem. IF THIS PROBLEM HAPPENS AGAIN MORE THEN A FEW TIMES WITHIN A SMALL TIME FRAME I WOULD HAVE THE SET LOOKED AT BEFORE THE REGULAOR BLOWS SOMETHING OUT!!!!
Posted on May 14, 2006
techman
  • 3130 Answers
SOURCE: Standby Light Blinking
Already answered this thread.
Posted on Apr 09, 2008
Slinteriors
  • 8617 Answers
SOURCE: toshiba projection tv
your set has a problem with the power supply causeing the set to shotdown. You can get a manual called Toshiba shutdown circuits and power supply troubleshooter that takes you step by step to diagnose your model its available at this link they email it to you almost instantly after purchase and they also provide free tech support in case you need further help. heres the link.
http://servicemanuals.vstore.ca/
Posted on May 12, 2008
charcois
  • 763 Answers
SOURCE: TV shuts down with Red Light blinking
it must be your tv was heated on long usage.
sir, try to go to your nearest expert technician. they have tools to use on fixing your tv's hardware. or see if your tv has a warranty to send it back to the place what youve bought it. hope that helps!
CHARCOIS
Posted on Aug 09, 2008
Toshiba 46 inch regza yellow light blinks and picture wont come on but I have full audio
Most likely the power supply board needs to be replaced. It could also be the T-con board or less likely the display itself.
If you don't know what you're doing, DON'T OPEN THE TV UP TO FIX IT, THERE ARE HAZARDOUS VOLTAGES ON THE POWER SUPPLY BOARD, EVEN WEEKS AFTER THE TV IS UNPLUGGED!
If you don't know how to do it yourself, find some local Electronic repair shops, get quotes, try to find reviews on the shops.
Sep 21, 2016 | Toshiba Televison & Video
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
Wont turn on but yellow light is flashing
I followed the steps at the following link and it worked for me. I have a 2007 Toshiba Regza 42HL67, but the firmware applies to many models as documented in the readme file at the location found via the link below. I used a 1gb SD card formatted FAT16, copied the unzipped files and folder to the card (wasn't sure if it required the top level folder or only the files under the top level folder so I copied both to the root of the SD card), unplugged the TV, inserted the card, plugged in the TV, waited 2.5 minutes, unplugged the TV, removed the card, plugged in the TV, yellow light flashed 3 times and went out. I turned on the TV and it has worked normally since last night.
http://www.benjammin.net/www/pages/techtips/Toshiba-Regza-42HL167.html
Jul 23, 2010 | Toshiba REGZA 47HL167 TV
TV will not turn on Yellow power ind. Light blinks three times tried to reset no luck took to repair shop diagnosed with bad SEIN module internet post suggest bypassing Sein module but I don't know where...
TV will not turn on Yellow power ind. Light blinks three times...
cc46e8cd-c98d-439a-bc78-207613c68534.png 76bab8a5-e5dc-4d5d-9d56-589661460254.png
Jan 13, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Picture loss after picture begins to flash. blue and yellow light
Most likely the lamp is dying. Try replacing the lamp before calling a repair tech. What does the Owners manual say about the blink lights?
Oct 01, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Blinking yellow light ,no picture or sound.
You have done all you can do. If you had a power outage, when the power came back on a it surged and probably caused a Power Supply problem or something in the micro controller to fail. Either way it 's not good. I would call Toshiba and let them guide you to a Service Facility that can check it out. Depending on your Homeowners Insurance, repairs could be coverd or unit be replaced depending on cost to repair.
Sorry I am not able to help further,
skyassoc
Jun 22, 2009 | Toshiba 65HM167 65" Projection Television
Power problems problem on
I would try a power drain:  Unplug the TV's power cable so the TV is not grounded to the house.  Then press and hold in the TV's own power button for one minute to drain the capacitors. Plug the TV back in and see what happens.  If the TV will still not turn on, I would say you have a problem with the TV's mainboard as a dead power supply will not light any LED's for you.
Mar 24, 2009 | Toshiba CN36X81 TV
Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
1,173 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
