Question about Dell Inspiron XPS Gaming Mouse Pad KU170
Key pad doe not work
My keypad of dell xps laptop is not working , kinda froze and when starting am getting a symbol numeric 9 with a lock sign...plz help
  • mariner_73 May 26, 2009
    thx for helping out ..but still is frozen the numeric 9 with a lock sign only appears while the laptop is starting up for a few seconds and then dissapears and when the laptop settles down it's all frozen.
  • 15 Answers
This means the number lock is on - in the upper right hand corner of the keyboard is a series of 4 keys.  Far right is delete, then (from the right) insert, Prnt Scrn, and Num Lk.  Hit the Num Lk key, and the number 9 with the padlock should shut off.  Your keyboard should now work normally.
Any more problems, let me know!
Posted on May 26, 2009
  • nathanl May 27, 2009
    OK, that wasn't made clear from your post - from what it sounded like, the 9 with the padlock icon was staying on consistantly.  So sorry about my misinterperetation.  Question - does your mouse still work, or is everything locked up?  One thing you might try to isolate the problem is booting into Windows Safe mode - press the F8 key while the computer is booting up (continually press it, as some computers are different as to when you can do this), and you should get a boot screen.  Make sure you boot into windows safe mode.  If the keyboard then works, it is a problem with the driver - if you have the original dell disks that came with the laptop, then you should be able to do a restore from those disks.
    Good luck with your problem!
Numeric keypad
1.Hold Fn (bottom left corner key on your keyboard beside "Ctrl") and press F11 key once (or find symbol that looks like "lock with number 1 inside" )
OR
2. Find key on your keyboard called "NumLock" and press once.
Mar 17, 2014 | Dell Inspiron Computers & Internet
No number lock or schroll lock Keys
Your laptop computer may have a numeric keypad integrated into the
keyboard. The keypad corresponds to the keypad of an extended keyboard.
• To type a number or symbol, press and hold <Fn> and press the desired
key.
• To enable the numeric keypad, press <Num Lk>. The 9 light indicates
that the keypad is active.
• To disable the numeric keypad, press <Num Lk> again.
numeric keypadSource(s): http://support.dell.com/support/edocs/systems/xlob/dtg/en/en_dtg.pdf
Feb 25, 2012 | Dell Inspiron 1545 Notebook
Number pad does not work
  1. Find Alt code.
    Numeric Alt codes for symbols are listed in Alt codes list. Check for Alt code of symbol you want to input.
  2. Enable Num Lk.
    You may need to simultaneously press ["FN" and "Scr Lk"] keys. That's the combination for "Num Lock" on some laptops. Look at the picture - the "Num Lk"/"Scr Lk" button is highlighted there.
  3. Hold down "Alt" key.
    Some laptops require you to hold both "Alt" and "FN" keys.
  4. Input Alt code of symbol on Keypad.
    Do this while holding "Alt" button pressed. Type Alt code on your laptop's numeric keypad. It's highlighted on the picture.
  5. Release all the keys.
    After you release all the keys alt symbol should be entered. If all this stuff didn't work - check if you have really enabled the "Num Lock" first. Remember that green indicator should shine near the lock symbol on your laptop's keyboard. If that wasn't the case - try simultaneously holding "FN" and "Alt" keys instead of just "Alt". That just might work.
Feb 15, 2012 | Toshiba Satellite P105-S9722 Notebook
What do the lighted icons stand for at the top of the keyboard? One looks like a locked padlock with a 9 in it. What does it mean?
That is your number lock key is turned on, which means that your 9 key keypad is ready to use. If you press the number lock key on your keyboard the light will go away but your 9 key numeric keyboard won't work until you press the number lock key again.
Jul 29, 2011 | Computers & Internet
My keyboard seems to be locked and will not respond to anything including the mouse pad on my Dell XPS notebook
Press fn key and whichever function key at the top of your board that has a lock symbol on it at the same time. You're in keylock and this will disarm it.
Jan 28, 2010 | Dell Studio XPS 16 Notebook
Cant get the at button to work even by pressing shift or not,every other key function works.
You may have a bad key, or a key with something under it.
Try this:
Turn the netbook upside down so that the keysj face the floor.
Bang on the back side that way you would to burp a baby.
Then, take a vacuum cleaner and **** out the spaces between the keys.
If this doesn't work, you may have to make an @ symbol manually by using the ALT key. (ALT plus 64). This should work in most Word Processing programs.
  1. Make certain that the Num Lock key has been pressed to activate the numeric key section of the keyboard.
  2. Depress the Alt key.
  3. While the Alt key is depressed, type the proper sequence of numbers (on the numeric keypad) of the ALT code from the table above.
  4. Release the Alt key, and the character will appear.
  5. On a laptop computer, there usually is no numeric keypad. So, instead, depress the Fn (function) key, then the Alt key, then the numerical code sequence. The numbers are on the fronts of certain keyboard keys: M=0, J=1, K=2, L=3, U=4, I=5, O=6, 7=7, 8=8, and 9=9.
http://www.tedmontgomery.com/tutorial/altchrc.html
Nov 13, 2009 | Acer Aspire One AOA110-1113 Netbook
Where is the equal sign.
Usually the = sign is substituted with the * sign on the number pad.This symbol is above number 9 on the right side number pad.
Sep 15, 2009 | Targus USB Ultra Mini Keypad Keyboard...
British Pound symbol
If you have Windows XP, click on Start, Programs, Accessories, System Tools, and choose "Character Map" - you should see and be able to copy the symbol to the clipboard you need from there.
Good Luck!
Mar 23, 2009 | Dell Latitude D600 Notebook
Lock 9 light is on
The numeric keypad functions like the numeric keypad on an external keyboard. Each key on the keypad has multiple functions. The keypad numbers and symbols are marked in blue on the right of the keypad keys. To type a number or symbol, hold down <Fn> and press the desired key.
  • To enable the keypad, press <Num Lk>. The keyboar2.jpg light indicates that the keypad is active.
  • To disable the keypad, press <Num Lk> again.
Mar 20, 2009 | Dell Latitude D410 Notebook
Ican"t type numbers can you please help
From Dell user manual:
The numeric keypad functions like the numeric keypad on an external keyboard. Each key on the keypad has multiple functions. The keypad numbers and symbols are marked in blue on the right of the keypad keys. To type a number or symbol, press <Fn> and the desired key after enabling the keypad.
Jan 13, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron XPS Gaming Mouse Pad KU170 Logo
896 people viewed this question
Alun Cox
