Texas Instruments TI-30XA Calculator Logo
Posted on May 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
ENTERING LOGS WITHOUT A BASE OF 10
I DONT KNOW HOW TO ENTER LOGS INTO A CALCULATOR WHEN IT DOESNT HAVE A BASE OF 10
Anonymous
Level 2:
Sniper:
  • Expert 69 Answers
  • Posted on May 26, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
69
Questions
6
Helped
56437
Points
268
(log(X))/(log(Y))
X= the base you want
Y=# you are using
I want to know how to enter basic logs into the calculator: Example. Log3^9=2 How can you enter this into the calculator?
The 30XA only has logarithm functions for base e and base 10. However, you can calculate the logarithm to any base by using the relationship logb x = log x / log b = ln x / ln b
To calculate log3 of 9, press
9 LOG / 3 LOG =
or
9 LN / 3 LN =
3helpful
1helpful
Confused
Press LOG for common (base-10) logarithm or LN
1helpful
How to enter a different log base (other than base e or base 10) into the Texas Instrument TI-80 silver
The TI-83 doesn't have such a function built-in. Use the relationship logb(x) = log(x)/log(b) = ln(x)/ln(b).
6helpful
How do i enter pH on a TI 30 calculator
This post answers two questions
  1. How to obtain the concentration knowing the pH?
  2. How to obtain the pH knowing the concentration
If you are not interested in the theory, jump to the examples at the end of the post.
As you well know the pH is the negative of the log in base 10 of the H+/H3O+ ion concentration. If we use [H+] to represent that concentration, then pH=-log[H+].
To obtain the [H+] you need to calculate the antilog. You write the definition in the form log[H+] =-pH and then calculate 10 to the power of each member. The equality remains valid as both members are treated similarly. Thus
10^( log[H+] ) = 10^(-pH)
Since raising 10 to a power is the inverse function of taking the log in base 10, 10^(log(x))=log(10^(x)) = x (they are inverse of one another), you are left with
[H+]=10^(-pH)
Your calculator has a function [10 to x] accessed by pressing the [2nd] function key. To use it you must enter the negative value of the pH, press the [2nd] function key then the [10 to x], then the = key to get the result (concentration)
Examples
1. Let the pH=5.5, what is the H+ concentration?
With [(-)] being the change sign key, then
[H+]:[ (-) ] 5.5 [2nd][10 to x] [=]
The result is 0.000003162 or 3.16 x 10^(-6)
Calculating the pH
Shortcut:
For all H+/H3O+ concentrations of the form 1.*10^(a) where a is an integer number between 0 and -14, the pH is the negative value of the exponent.
Concentration =10^(-3), pH=3
Concentration=10^(-11), pH=11
For other concentrations such as 3.567*10^(-8), one cannot use the shortcut above, but have to calculate the log of the concentration
[H+/H3O+] = 3.567*10^(-8)
pH= - log(3.567*10^(-8))
This is keyed in as follows (to minimize the number of parentheses)
8 (-) [2nd][10 to x] [*] 3.567 [LOG] [=] (-)
Here you have two (-) change sign, the first is entered after the exponent of 10, the other at the end of the calculation to take the negative of the displayed result. You may notice that it is entered in the reverse order of the defining relation - log(3.567*10^(-8)).
To verify your calculation, the result is 7.447696891 or just 7.45
If you have a problem with the first (-) try entering it before you type in 8.
Hope it helps and thank you for using FixYa
And please, show your appreciation by rating the solution.
1helpful
I am asked to find the log of 6.02 X 10 to the 23rd power> How can I find 10 to the 23rd power?
Why complicate matters for yourself?
You were asked to calculate log(6.02x10^23), let your finger do the calculating.
I checked the claculator manual and you have to enter it all at one go. Pay attention to the key strokes. You will not do it in such a laborious manner
23[10^x] [=] gives 10^23
23[10^x]*6.02 [=] multiplies 6.02 by 10^23 to give you Avogadro s number.
To find its logarithm in base 10, you have to enter the number then press [LOG] . When you press [LOG] you are calculating the log of the last result. You obtain 23.77959649.
If I had given you the key strokes directly you might have not understood why I do things this way. Now the actual key strokes you enter
23[10^x] * 6.02 [LOG] [=]
If you are only looking for your result, you are done. You can ignore what follows.
If you know the rules for the logarithms, you can do the calculation more easily. log here is log in base 10
Rule 1 Log(a*b)= log(a) + log(b)
Rule 2 Log(c^n) = n* log(c)
Rule 3 log(10)=1
Thus applying the rules
log(6.02*10^23) = log(6.02) + log(10^23) first rule applied
= log(6.02) + 23*log(10) 2nd rule applied
= log(6.02) + 23 3rd rule applied
= 0.77959649 + 23= 23.77959649
Hope it helps
1helpful
How can I use the Log function on my calculator?
Hi ;
for log base 10 use the the "log" key
example :
log(2) + log(3) = log(6)
enter 2 press the log key you will get 0.30102999 press the '+" key than 3 log you should get 0.47712125 for it Press the "=" or enter and you should get 0.778151250 for a answer than press inv or 2nd log and you should get 6 for a answer
and that all there is to it
6helpful
How to find anti-log
If you know the theory skip this and go to Application
Let y=10^(x) 10 to the power of x
Take the log of both tems of the equality. You get
log(y)=log[10^(x)] where I used square brackets for clarity. But from the general properties of logarithms
log(b^(a)) = a*log(b)
Applied to our expression above
log(10^x)=x*log10
But since we are using log as log in base 10, log_10(10)=1
so
log(y)=x
We thus have two equivalent relations
y=10^x <----> x=log(y) The double arrow stands for equivalence.
If y is the log of x, then x is the antilog of y
Application: What is the antilog of 3.76?
antilog of 3.76 =10^(3.76) = 5754.399373
Take the log in base 10 of this number and you recover 3.76
You enter it as follows
10[^]3.76[ENTER/=] gives 5754.399373
And log(5754.399373)= 3.76
Hope it helps
44helpful
3answers
How I can get the log base 10 number in a TI 89
"♦" "7" will give you log base 10 for the texas instuments TI-89 Titanium
1helpful
I need to know how to put an exponent in square root form
To get an exponent press 2nd then LN or LOG
LN is natural logs, so entering 1 then 2nd LN gives you the natural exponent of 1 which is.2.71828....pressing LN gives you the natural log of 2.71828.... which is 1
LOG is logs to base 10, so entering 1 then 2nd LN gives you the 10 to the power 1 which is.10, pressing LOG gives you the log of 10 which is 1 again
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
