Question about HP PSC 2355 All-In-One InkJet Printer
Have to re-install printer periodically.
Approximately every three months I'll try to print a document , but the printer does not receive a connection from my computer. I have to re-install the printer software. Sometimes installation requires the original CD and sometimes it doesn't. Also, there is a small message box constantly up on my desktop that says "Product Registration ... would you like to register your product?" I have registered this HP product several times over the last two years of this problem I called HP; they told me they no longer support the HP PSC2355xi product line.
  • ultimitloozr May 11, 2010
    About the registration message box, just answer No. What process runs approximately every 3 months that could be corrupting your printer driver? Interference with drivers does not "just happen." There is something else that is causing the corruption that requires reinstallation, especially if it is happening on a regular basis. That is what you need to find.
  • 152 Answers
Error E and 5
Number following "E"
Cause
How to correct
No paper. /
Paper does not feed.
If paper is not installed, load it and then press the <Black> or <Color> button. When paper is installed, check each of the following items and try printing again.
1. Confirm only recommended paper is installed.
2. Confirm paper is installed properly.
3. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
4. Clean the paper feed roller to resolve the error.
Paper jam
Remove the jammed paper.
If paper jams frequently occur, check the following:
1. Confirm there is no foreign material inside the machine.
2. Confirm only recommended paper is installed.
3. Confirm paper is installed properly.
4. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
Empty ink tank
An ink cartridge is empty.
To cancel printing, press the <Stop/Reset> button.
To continue printing, press <Black> or <Color> button.
After printing completes, replace the empty ink cartridge.
Printing with an empty ink cartridge may cause the machine to malfunction.
5
The ink cartridge(s) is not installed. / The ink cartridge(s) cannot be recognized.
The ink cartridge may not be installed properly, or an unsupported ink cartridge may be installed.
Install a recommended ink cartridge.
Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing.
If one of the ink cartridges is missing, this error can occur.
7
The ink cartridge is not installed in the appropriate position.
The ink cartridge is not installed in the proper position.
Install each ink cartridge in the proper position.
8
The waste ink absorber is almost full.
The waste ink absorber is getting full.
Press the <Black> or <Color> button to clear the error and continue printing.
Printing can continue until the waste ink absorber becomes full. If the waste ink absorber becomes full, the machine will require service.
The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations.
9
A specified period of time has elapsed without receiving a response from the digital camera. / A print mode compliant with PictBridge is not selected. / A specified period of time has elapsed without receiving a response from the digital camera.
The machine cannot communicate with the connected camera.
Disconnect the cable between the machine and the camera to clear the error.
Check the following items, then try printing again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct.
If the camera does not support either one, the machine cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge.
Please refer to the camera instructions for more information about procedures required before and after connection to the machine.
3. There may have been no response from the camera for the prescribed time.
Re-connect the cable between the camera and the machine.
1 , 4
1 , 5
The ink cartridge cannot be recognized.
An unsupported ink cartridge may be installed.
Install only recommended ink cartridges.
1, 6
The ink level cannot be correctly detected.
A used ink cartridge may be installed, or the ink cartridge is empty.
Replace the ink cartridge.
Press the <Black> or <Color> button, to clear the error and continue printing without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate.
1 , 9
Scanning failed.
Scanning a document failed.
Check if the document is placed in the correct orientation / position and try the operation again.
2 , x
3 , x
4 , x
(Where x represents a number)
Turn the machine off, and remove the power cord from the electrical outlet.
Wait approximately ten minutes then plug in the power cord and turn the machine on.
If the problem is not resolved, the machine may require service.
Feb 18, 2012 | Canon PIXMA MP150 All-In-One InkJet...
When trying to print an 11 x 17 word 2010 document that displays properly on the screen only a portion approximately 8.5 x 11 prints out of my 3 month old HP business Inkjet 2800 printer.
It may be that an updated driver is needed; that would be available from the HP website. You should be able to manually set the printer via the HP user software that came with it although it seems that Word should be able to do that automatically.
Sep 09, 2010 | HP Business InkJet 2800 Printer
HP Officejet J4580 All-in-one SerialNumberJob
open command prompt and give following commands
net stop spooler
net start spooler
repeat 34 times restart computer
Dec 16, 2009 | HP OfficeJet J4580 All-In-One Laser...
I send something to print, the printer flashes to indicate receiving data, it usually starts to print (but not always) then stops, still flashing, and after a period of time I get an error message on the...
Hello !
Try reinstalling the printer driver.
Remove your printer from Printers and Faxes.
Disconnect the printer cable.
Restart your workstation.
Reconnect the printer cable.
Your computer should see the printer and install the driver.
Hope this helps.
Sep 12, 2009 | Office Equipment & Supplies
Data light flashes , documents won't print.
this is not a network problem.because machine is receiving documents thats why light is blinking. check the paper in the tray whether they are of correct size, change the paper size from computer, or call your tech service rep it may be due to usb cable or faulty network cable, or it may be the problem of main communication board of photocopier machine.
Feb 10, 2009 | Konica Minolta bizhub C351 All-In-One...
Mono color
These models use a "3 colour" printing process. In other words, these printers do not contain black ink when the BC-05 colour cartridge is installed. To produce black print, a 3 colour printer mixes an equal amount of the three primary colours. This process is known as "composite" black.
As the ink in the cartridge runs out, one of the three primary colours will run out first, depending on the material that has been printed. After one of the three colours has depleted, this colour will be missing from the mixture required to print black, and the print will change colour. This is the indication that the cartridge needs to be replaced. Usually the remaining colours in the cartridge will run out soon afterwards.
Rate the solution as appropriate !
Feb 07, 2009 | Lexmark X7170 All-In-One InkJet Printer
Can't print on home network
Well an unisall and reinstall of the printer drivers on the network would definately solve your concern.If you want further support you can avail free online technical support on http://tinyurl.com/m7ghqz
Jan 20, 2009 | HP Photosmart D7360 All-In-One InkJet...
Lexmark 7500 wireless printer. was working, yet each day when i go back to print it is always trouble to get connected. Now i cant connect today
I had the same problem for about a week...each "new" day when I attempted to print my first document of the day I received a "printer not connected" problem type message. I had to unplug my printer each day. Then it dawned on me..........uninstall and then "re"install the printer. That was about 6 months ago and I have had NO problems since the "reinstall". TRY THAT ! ! ! !
Dec 15, 2008 | Lexmark Office Equipment & Supplies
Printing problem
Is the printer connected to a network or USB. If connected on a network there is probably an firewall blocking the print communications. Also the latest print drivers for the printer should be loaded.
Apr 29, 2008 | Brother MultiFunction Center MFC-440CN...
HP PSC 2355 All-In-One InkJet Printer Logo
82 people viewed this question
Seeker5211
Seeker5211
