Question about Gateway 500 CS PC Desktop
Added Memory, Now Computer doesn't Boot! HELP!
I just added PC133 SDRAM to an old, currently working gateway computer. Now it beeps 3 times on boot and does not display video. I removed the new stick and rebooted, still nothing. I even reseated the remaining to sticks, the video card, removed the battery, and tried the jumper thing with no success. Please HELP!
  • mallrats202 May 26, 2009
    Thank you for your advise. The computer is actually an Gateway ELP 500C. This is the motherboard I'm using.
    Gateway 4000742 E3600 Motherboard Intel P4 AA A63931-3
    way 4000742 E3600 Motherboard Intel P4 AA A63931-304
    President:
  • 776 Answers
Either you have defective SDRAM chips, or your CPU was damaged when you installed them .. in either case, your only solution is to have the problem diagnosed by a professional.
Posted on May 26, 2009
  • 700 Answers
Try this, clean the old memory stick with a clean soft eraser, its edge connector both sides the one that makes contact with the slot. Then reinsert it again, just the old one.
Just do it while your unit is off and unplugged to any power source. And also discharge static from your hand.
MB keeps beeping 1 long beep no boot.
Hello try to download the manual:
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=4&m=CUSI-M&os=&hashedid=n/a
Select windows xp and open the manual folder
Click on global for download.
Unzip the file and you need adobe reader to read the content.
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
This mainboard uses SD ram and it sounds like a ram problem.
If there is room for a ddr ram block you can`t use SD ram and DDR ram simultaneously.
Try to insert the old cpu again and upgrade the bios to support a bigger cpu. Not all cpu is supported.
Good luck
Dec 22, 2012 | ASUS SiS Chipset CUSI-M Motherboard
I have a dell dimension 4600. It has original memory cards installed. 2 256 MB for a total of 512 ram. I recently tried to install 1 GB memory card. When I start up computer it beeps several times,...
hello
several beeps in a system is caused by a memory issue -- If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
the specs can be found at this link
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/specs.htm
the system you have is upgradable to 4G of RAM, and this RAM must be installed in equal pairs
so if you have 4 slots to insert memory in (assuming you will retain the 2 256M) , you must install the other slots by 2 512M, 2 1G or 2 2G DIMMs -- make sure you isntall exact same DIMMs, dont mix memory makers or specs, other than what Dell specifies
memory type must be
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
i hope this helps --
Dec 09, 2010 | Dell Dimension 4600 PC Desktop
On power up it beeps 3 to 4 times and won't boot up
Open up the chassis, remove the DDR memory modules, clean out the dust bunnies
thoroughly with compressed air, and reseat the memory modules one at a time,
attempting to power on the system with each added module. Always unplug the
computer from the wall current when adding or removing hardware.
The 3 beep at startup is a fetal memory error code this may be due to either bad memory module or corruption of BIOS.
Let me know the result after performing the steps I will be glad to assist you further
May 14, 2010 | Dell Inspiron 530 Desktop Computer...
Trying to put new hard drive.when it starts up it beeps 3 times and no picture on the monitor.is the power supply bad? originaly the hard drive crashed and the trying to reinstall it kept coming up error...
3 short beeps is a base 64K RAM failure
Remove added memory
  • Additional information about determining the type of memory to use in a memory upgrade can be found on document CH000910.
Open computer and reseat memory
Swap memory location
Try another computers memory
If you have access to another computer that uses the same type of memory try using its known good memory in your computer.
If another computers memory works you know that you have bad memory. If another computers memory does not work and it is compatible with your computer unfortunately your motherboard and/or the slots on the motherboard are defective causing it to be unable to properly read the memory, which means the motherboard will have to be replaced.
Replace memory
If you've determined or believe that the memory in y our computer is bad we suggest that you replace it.
  • Information about installing and adding new hardware including memory can be found on document CHADD.
Jan 31, 2010 | Gateway Computers & Internet
Computer does not boot up
Computer has three short beeps as it starts? computer RAM (memory) related issue.
Hope this helps.
Oct 22, 2009 | Gateway GT5404 PC Desktop
Did not boot and with 3 beep sound
Remove added memory
Replace memory
Aug 04, 2009 | Computers & Internet
Motherboard beeps three times, computer won't boot up
Your computer is experiencing memory problems. Turn power off, remove and reseat the memory chips, and try it again. If not successful, try different memory chips. Also could be power supply problem
Jun 13, 2009 | Gateway 506GR PC Desktop
Laptop doesn't recognize new ram
I would guess that you need PC 133. Some manufactures that were using SDram at the time required PC133 while others would require but allow you to use PC100.
This is the requirement for your laptop from www.crucial.com
Each memory slot can hold SDRAM, PC133 with a maximum of 256MB per slot.*
Hope this helps
Apr 09, 2009 | Gateway Computers & Internet
Replaced 64k memory with 512 in gateway 5300. the system will not
so the best you can do 512 MB total
Mar 26, 2009 | Gateway Solo 5300 Notebook
Memory upgrade for P6VEM3 MB
For this mainboard, you must use 168-pin, 3.3V unbuffered PC100 or PC133 SDRAM memory modules. You can install any size memory module from 32 MB to 512 MB, so the maximum memory size is 2 x 512 MB = 1 GB. As noted on pg. 9 of your manual. Shut down your system. Remove one dimm of memory & start the Pc. Does it boot & do you have video? No? Shut down & replace the the dimm with next stick of memory. Try again. Still no video? Replace memory with old memory. Did you regain video? In most cases of installing new memory it's found the memory just wasn't seated well enough. In few others the memory did not meet the correct voltage.
prazum post back your findings.
Feb 22, 2008 | EliteGroup P6VEM3 Motherboard
Gateway 500 CS PC Desktop Logo
243 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
