Question about Ryobi Factory Reconditioned 18" 40cc 2-Cycle Gas Powered Chain Saw #ZRRY10532
I am having a problem with the oiler,getting oil to the bar&chain.
I have a McCulloch Timber Bear 18" bar. I am not getting any oil to the chain.I have checked everything and all seams to be clean. the primer pump was hard to push,but works easy now but still no oil to bar and chain. I drain the oil tank and all the oil was clean. the filter inside also looks clean. help!
  • 46 Answers
Pump is probably gunked up! pour a dab of oil on it between cuts if you really have a task you need to finish up! then crack the case to the saw open and take a looksee
Posted on May 26, 2009
How to adjust oiler on mcculloch timber bear
some saws dont have oiler adjustments and if it worked before it dont need adjusting some things you need to check are you using the correct viscosity of oil have you checked the chain bar is clean and free of sawdust and dirt especially where oil enters the bar. after you reassemble ,start the saw and hold it 2 inches from the ground and rev the engine up and down several times watch for oil sling before you cut wood if you have trouble after all this try motor oil instead of bar oil
Feb 12, 2015 | McCulloch Garden
What kind of oil do I put into my toro expand it chainsaw?
CHAIN OILER See Figure 18. ? Use Premium Bar and Chain Lubricant. It is designed for chains and chain oilers and is formulated to perform over a wide temperature range with no dilution required. ? Remove the cap and carefully pour bar and chain lubricant into the chain oiler tank. ? Replace the cap and tighten securely. ? Check and refill the chain oiler tank every hour when using an electric power head or every time the engine is fueled when using a gas power head. NOTE: Do not use dirty, used, or otherwise contaminated lubricants. Damage may occur to the oil pump, bar, or chain.
Sep 01, 2011 | Toro Garden
Oil pouring out of mac3516,chain oiler
You have my condolences.
Your saw is here, which one?
Chainsaws 32cc-35cc-38cc Anti-Vibe
I chose "22-600035-18" as an example , it follows (more detailed print - may not be your saw):
http://www.ordertree.com/modelinfo/MCC/22-600035-18-Mac-3516-IPL-211318-01/139.22-600035-18-Mac-3516-IPL-211318-01.1.59.1.html
On this block of saws the oil pump is under the flywheel and there are many hoses. Please use the IPL to identify and locate oiler parts. I hope you find a burst hose. There are oil pump repair kits listed. Unless the pump has an obvious crack or hole I would not attempt to change it until I had exhausted all other possibilities.
This works for older MCs but MTD (this one) saws often deviate from the explanation. It will give you a little guidance if you try to locate a different IPL.
http://www.fixya.com/support/r3558917-mcculloch_chain_saw_ipl_illustrated_par
The IPL (exploded parts list) for your saw is the only detail for the oil system is sketchy at best. Oiler components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
McCulloch IPLs (all)
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
I know it is not plugged but this may also be helpful.
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL).
These are very difficult to work on, most saw shops will not attempt a repair. I hope the chainsaw Gods smile on your undertaking. Good Luck. If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa HTH
Lou
Mar 22, 2010 | McCulloch Garden
How do you adjust the automatic oiler on a eager ****** 3.7 chain saw.
I cannot find an Eager Beâver with 3.7 CID (60.6cc). Provide a model number and we can dance, without it I cannot answer your question. Reply below please. Is it a Timber Bear?
Mar 11, 2010 | McCulloch Garden
Chain oil pump does not work when pumped. Eager ****** MAC 100 series
Your Eager Beâver model number is 600016. There are many prefixes and suffixes. The one below I used when repairing a similar problem with my Mac 110 (earlier version of your saw). Both the automatic and manual oilers work now.
I get the best results for new McCulloch parts here:
This is a little complicated so I am going in small steps.
M & D Mower
http://www.m-and-d.com/parts.html
Click “Illustrated Parts Diagrams ON LINE”
Click “Click Here for Parts Lookup”
Changes to “Select OEM” Window reads “Briggs & Stratton ▼” Click the arrow and select “McCulloch Power”
Click “Gasoline-Powered Chain Saws”
Click “18-600016-27”
There is a shipping and handling charge from M & D (about $9) if all parts in same container only one fee.
See “General Assembly” print
Item 33; pn 85557; Oiler body; most likely failure, on bottom of Item 31
Item 31; pn 217755; manual oiler piston; It pulls through the top of the tank. I ordered a new one but got Item 36, they were the same pn, I complained, seems they fixed it.
See “Powerhead Assembly” print
Item 07; pn 219989; oil pump assembly
Item 04; pn 217168; pump/bar pad connector (hose)
Item 05; pn 217167; pump/oil tank connector (hose) The new one was to long, I used the old hose. I have an earlier model.
Item 17; pn 110653; O-ring
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 06, 2010 | McCulloch Garden
I have two mcclloch timber bear chain saws 3.4 and I'm looking for two throttlelinkage rodsthe one from the carb. to the trigger
I found a 13-600041-34 Timber Bear IPL here:
http://www.ordertree.com/modelinfo/MCC/13-600041-34-TIMBER-BEAR-07%2F90-to-Current-IPL-211627/139.13-600041-34-TIMBER-BEAR-07%2F90-to-Current-IPL-211627.1.59.1.html
On the "General Assembly" Illustration, item 71, is a "Rod, Throttle". An Internet search for McCulloch 214504 returns many sites showing this part in stock.
I make no claim this is your saw or this is the part you seek. I defer to you to ensure applicability.
McCulloch IPLs
There are also
13-60041-35 and -36 (often part of serial number). I saw no other prefixes used with 600041. Again I am human and do err.
In a pinch a piece of hobby store piano wire and a couple pair of pliers can probably be used to fabricate what you need.
If you have additional questions you can reply below and I will help further, HTH
Lou
Feb 05, 2010 | McCulloch Garden
Mcculloch em300s electric chain saw stopped oiling the chain. I noticed the oil had all flowed out in storage shed and when I refilled it and used it I noticed the chain and bar were dry.
This is a little complicated so I’m going in small steps.
Click “Electric Chain Saws” The model number of your saw is probably on a tag affixed to the bottom. The tag also displays the serial number.
If it is a 300S the hyphen is the bar length.
I looked at the 300S-16 (same oiler parts as -14)
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw’s oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Item 15 has a filter on the bottom check it first, insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out (clean or replace, difficult to determine serviceability). If good I’d look closely at item 17. I can’t get enough detail from the IPL but that is the logical culprit.
Oil systems on all Mac Electrics appear pretty basic. Good Luck
Lou
Nov 08, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
I have a McColloch 16 in chain saw MS 1635 AV.
remove side cover,bar & chain.above bar mounting studs find a oblong channel that lines up w/ the small holes in the bar.clean everything,sawdust gets packed in the holes.if it leaks oil out the bottom,you need to replace the oil feed line fom the tank.
Sep 21, 2009 | McCulloch Garden
I need a manual for a McCulloch Timber Bear Model#60013414 chains
hi,
i believe this is the manual you are needing it is on ebay Item number: 150322102913 rtcurve.gif
good luck.
Mar 29, 2009 | Garden
Ryobi Factory Reconditioned 18" 40cc 2-Cycle Gas Powered Chain Saw #ZRRY10532 Logo
266 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
