Question about Craftsman Grinders
Need manual or pdf for manual
I need pdf manual for a craftsman old bench grinder mdl# 319.190622 thanks for help james
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    James,
    Went to the Sears site and found the grinder:
    319.190622 Grinder
    The owner's manual is no longer available from Sears. (It is listed near the bottom of parts list.) I will try to find a PDF file, but it will be difficult at best.
    Wayne
I have the manual you are looking for
Posted on Jun 24, 2009
How do I operate bench grinder?
A murphy, A bench grinder must be used with a lot of caution and respect while using this equipment, Check the attached links,instruction and guides, Good luck work safe.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
OSH Answers Fact Sheets
Pedestal Bench Grinder Safety
Bench Grinder Basics
Mar 21, 2016 | Bench Grinders
My craftsman bench grinder running for 5 min blows the breaker
Feel the power cord when that happens. If the power cord doesn't get pretty warm, and the grinder itself doesn't get awfully hot, then I'd suspect the breaker - they get old and trip too easily.
Apr 24, 2014 | Craftsman Grinders
My grinder starts slowly and takes time to build up to speed. It is a model 612 and does not appear to be a capacitive start motor. All I can see under the base plate is a relay. Thanks for your...
Hi and welcome to FixYa, I am Kelly
Inside your grinder either the stationary switch or the rotating assembly that actuates the stationary switch has failed.
Download this pdf file:
http://www.baldor.com/pdf/literature/CA506_0806_WEB.pdf Then go to page 9
The rotating assembly is this part number: (most common failure)
34RS2060SP
You must remove the end plate / cap to change this part.
The statonary switch rarely fails unless the rotating assembly damaged the contacts when the rotating assemble failed. When the rotating assembly fails you often find a spring and flyweight loose inside the grinder during disassembly. Should your stationary switch have failed try and get a number off of it so you can get the right switch. Otherwise you have to use NEMA code / Body type numbers.
Thanks for choosing FixYa,
Kelly
May 06, 2011 | Baldor 612 6" Bench Grinder 3600 Rpm Stamp...
I have an old Craftsman bench grinder that I got at an auction. I need a capacitor and the one on it has no markings. It is a 1hp model 319.19063. Sears Parts direct says that it is no longer available and...
this is a "Split-Phase"motor it uses only a run capacitor and a typical capacitance rated MFD rating will be between 80 and 290 MFD, go to www. grainger..com and they will have your part,and even if its an older unit and the model/serial/number is available take it with you & they will have a replacement capacitor available in the correct size/dimension/mfd/etc
Apr 24, 2011 | Baldor 8" 1 Hp Electric Bench Grinder
I have a Craftsman Commercial 1/2 HP Bench grinder. When I turn it on It just hums. It doesn't turn. Can you tell me what is wrong and which part I need to change? Thank you, Marlan PS: I have misplaced...
The motor has a high spot on the armature causing the motor to stop rotating. The humming noise is the fields full of current which is making the armature to react to make this noise. For the money purchase a new bench grinder which is an easier fix than dumping money into your old one here
May 05, 2010 | Grinders
Model 397.19471 need switch but can not find. please help? 8 inch bench grinder
Call the Sears Craftsman help line they will have the parts you need
Apr 02, 2010 | Craftsman 10" Bench Grinder
I need a replacement switch for a craftsman 1/2 HP bench grinder model#397.19441. I have no owners manual or parts list. This grinder is several years old.
this switch is no longer available from Sears, so I suggest making a wiring drawing and taking the switch to a local electrical supply house and try matching it up with a replacement. It seems to be a simple on/off type switch and I would think that you should have no problem. Let me know if you do and give me the information on the switch and I will try some other sites I know.
Dec 28, 2009 | Craftsman Grinders
Craftsman manual for Model 21126 6" grinder
What do you need a manual for? It's a grinder, grind something!!
Sep 09, 2009 | Craftsman 6" Bench Grinder with Lamp
Open Questions:
Grinders Logo
736 people viewed this question
Top Craftsman Grinders Experts
Jim London
Jim London
Lawrence Oravetz
Vernon Taylor
Are you a Craftsman Grinder Expert? Answer questions, earn points and help others
