Question about Nikon COOLPIX L20 Digital Camera
Dropped camera in sand
I dropped my brand new Coolpix L20 in the sand while it was on. Now it doesn't work at all (it powers up but won't focus on anything; then won't power down). Did I kill it or can it be fixed? If fixable, would it be too pricey or better to buy new again at $115?
  • 744 Answers
Hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Posted on May 26, 2009
Lens error, how do we check the gears
Posted on Jul 25, 2010
Lens error for coolpix l3. The lens won't retract and the camera won't work. took batteries out and put new ones in. nothing is working. is there a way to reset the camera?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Sep 29, 2011 | Nikon COOLPIX L3 Digital Camera
Some stupid person has dropped and then kicked my brand new Samsung camera and now it won't turn on and the lens is stuck out :( When I try to turn it on it makes a weird beep and won't turn on and...
You should try to get that stupid person to buy you a new camera if the following doesn't help. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Jul 09, 2011 | Samsung Digimax S730 Digital Camera
Dropped camera while it was turned on - now "lens error" appears on screen & can't turn off camera or view pictures
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Dec 25, 2010 | Nikon COOLPIX L20 Digital Camera
Battery door won't stay closed
www.thefotogeeks.com sells battery doors for the Nikon L20.
Mar 31, 2010 | Nikon COOLPIX L20 Digital Camera
My Nikon Coolpix L20 will only delete one picture, and then the screen says "please wait" It's been over 20 mintues, and just yesterday it worked. It hasn't been dropped or anything.
This might be a file error on the memory card.
This happens sometimes.
Save what you can from the card then format it in the camera a few times.
Hope this helps.
Feb 04, 2010 | Nikon COOLPIX L20 Digital Camera
I dropped my Nikon COOLPIX L20 camera. After that the shutter didn't open or close well. I need to help it manually. any advice?
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 01, 2010 | Nikon COOLPIX L20 Digital Camera
Pictures are all grainy and blurry. At first all pictures were great but now they are all out of focus and grainy. I don't think any settings were changed but am not sure.
Most likely causes:
The camera was dropped or damaged.
Flash is turned off when it is needed.
Lens is dirty.
ISO setting set to high.
Best bet is to take it to a camera store and let a professional check it out.
If this helps please vote for my solution.
Nov 27, 2009 | Nikon COOLPIX L20 Digital Camera
My nikon coolpix s210 has a lens error. I turn it on and the lens comes out. It make a err sound and seems like it cant focus. it goes back in and says lens error until i turn it off. I need it. I cant...
if its brand new, then you can replace the lens array for free of service charges in the case you have all the documents. it generally happens if you have dropped the camera.
Jul 09, 2009 | Nikon Coolpix S210 Digital Camera
Broken Nikon L20 LCD Screen
door where the battery goes broke
May 29, 2009 | Nikon COOLPIX L20 Digital Camera
Nikon COOLPIX L20 Digital Camera Logo
401 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
