Question about Canon i475 InkJet Printer
My I475 D printer will not intake paper it says "passage blocked" a friend looked at it and said I need the CD and it needs to be reprogramed however I've ;ost the CD can I get another one some way?
  • 241 Answers
If it says passage blocked then there is a piece of paper stuck in it somewhere. Look closely for a paper jam.
Posted on May 26, 2009
When I command my eoson stylus photo 1410 to print, the ink unit system blocks the carriage unit just before it picks the paper producing a loud noise with paper light blinking & ink flow into the waste...
we don't send mails.
But scrutinise the printer, to check nothing has fallen in. Even a paperclip can block free passage of the printer head.
Eventually disconnect the printer from the mains and try to move the head careful from one site to the other. Use a bright light to see if anything is blocking the head.
Nov 26, 2014 | Office Equipment & Supplies
Quantum 4hp powerpro
you have a blocked primer passage take off filter huosing blow dirt out of passage and out of prmerball it might be bad enough to rebuild carb
Jul 05, 2014 | Garden
Virtually refuses to print CD's. Have re-whitened the blocks on the CD tray and still refuses, just "jams" every time
You will need to check the rollers insiode the printer and the full printer path, cd paper is thicker than standard paper and will take less to block it, also look for stickyness on the print rollers
May 10, 2011 | Epson STYLUS R230 InkJet Photo Printer
Obd 2 code reads p 15 18. There is no code number to relate to the problem. Do you have the answer? [ check engine light on 1999 ford taurus]
code p1518= intake manifold runner control (IMRC) malfunction (stuck open)
the intake manifold has two runners per cylinder, feeding each of the cylinder heads
the IMRC assemblies are located between the intake manifold and two air passages for each cylinder.
one air passage is always open and the other passage switches from means of a valve plate.
below 3000 rpm, this valve plate is closed to improve low speed performance.
above 3000 rpm, this valve plate opens to improve high-speed exceleration.
the valve plates are opened and closed by the IMRC deactivation by the powertrain control module
(pcm) if your car or truck is not affected by the error code, the pcm may need to be reprogrammed
so that the error does not come up again. or you can connect an obd2 scanner and reset ever y time
it comes up. good luck!
Feb 10, 2011 | 1999 Ford Taurus
Service Error 6A00. Printer won't print at all
This is related to your printer's carriage, please check the paper passage and make sure nothing's blocking the passage. If this doesn't help, try inserting a hard paper through the carriage, perhaps the mechanism that controls the paper to pass through is stuck, so try your best to move it. Good luck. Thanks for using FixYa.
Jun 10, 2010 | Canon PIXMA IP5200 InkJet Photo Printer
When i try to print something it keeps saying carriage jam how do i fix that?
It means something is blocking the paper passage. Check whether there's any paper or something obstructing the passage of the paper, if so clear them. Good luck. Thanks for using FixYa.
Jun 10, 2010 | Office Equipment & Supplies
Code p0400 keeps coming up after changing the egr valve and sol.
It may be that the passage to the exhaust is blocked also.
Aug 14, 2009 | 1996 Nissan Sentra
The printer will not except the paper
hi evason.
is there any paper blocking the passage to where the paper feeds ?
or paper jammed any where ,
riz.
Jun 29, 2008 | Lexmark Office Equipment & Supplies
Canon i475D Printer
Try cleaning the rollers where the paper feeds in, a cotton bud with metho works on my printers
Apr 15, 2008 | Canon i475 InkJet Printer
Canon i475 InkJet Printer Logo
old marine
old marine
