Question about Refrigerators
Not cold - Refrigerators
  • lucedavid May 26, 2009
    freezer works fine, the refrigerator barely cold, settings are normal
    model ctb1720arw magic chef
  • Refrigerators Master
  • 13,433 Answers
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
* Is the refrigerator completely dead? If so, see “It's stopped completely.” scroll down to it, below.
* Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
* The compressor
* The Thermostat
* The overload, relay, or capacitor
* The defrost timer
* The condenser fan motor
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
* Wiring
* Thermostat
* Defrost timer
* Compressor
* Overload and/or relay
If you are unable to troubleshoot the problem from here, you may need to contact a qualified appliance repair technician.
Posted on May 26, 2009
Toyota rav4 diesel starting problems from cold it take a long time to start up when i leve it over night..
Its cold start issues:----
Go through the list of help links mentioned below:----
Click the link :----
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
Low idle when cold out side?
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
Ford explorer 4.0 will not idle when cold?
http://technoanswers.blogspot.in/2012/02/ford-explorer-40-will-not-idle-when.html
Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
Car won't start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
These will help.
Thanks.
Dec 06, 2012 | Cars & Trucks
99 contour starts easy idles smooth, cold but dies when you start to pull out runs well when warm
These will help.
Thanks.
Dec 06, 2012 | 1999 Ford Contour
2006 nissan navara wont start in cold weather
These will help.
Thanks.
Idle fluctuates when cold 93 bonneville
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
Hi, my washing machine isn't working in cold/cold mode but will work in hot/cold and warm/cold. Meaning that water will not come out at all. I even started it in warm/cold and tried to switch it over to...
My bet is that your cold water screen is plugged...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 31, 2010 | Frigidaire Washing Machines
Cold water Washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Apr 07, 2009 | LG WM-1832C Front Load Washer
Kenmore front load washer: no cold water problem
that's odd.
if you choose cold/cold then check your hose orientation. you could have put the hot water to the cold solenoid.
or the wires have been interchange, the hot water wire was plug to the cold solenoid and the cold water wire was plug to the hot water solenoid.
or hot water is still flowing to your cold water line.
if the cold water solenoid is the problem, then there should be no water at all going to the tub.
try to experiment, try to switch to hot/hot and see what would come out...
tnx 4 using fixya,
drcool
Oct 02, 2008 | Kenmore Energy Star 44092 Front Load...
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
