Question about Dell 0JM629 Inspiron 1520 Keyboard
The screen is blank but I can see a faint image.
I have a dell inspiron 1520 laptop. The screen is black but I can see a faint image.
  • Dell Master
  • 2,404 Answers
Try reseating the cable that goes to the back of the lcd and also the other end of that cable that plugs into the motherboard. If that doesn't do it then either the lcd or the inverter is bad. Either way when you get a replacement screen for a dell laptop it normally comes with a new inverter as well. If your laptop is under warranty thru dell then you can get it replaced thru them. If you have your serial number then I can look it up and see if your system is still under warranty.
Posted on May 26, 2009
I forget my MY dell inspiron 1520 Laptop of vista basic OS's password and later on typing wrong password it also blcok the system and displays messag
Crack Dell Laptop Password
U can search the above words via search engine and get ideal suggestion from search results!
Then, there will be solutions supported:
Step 1. Access other PC which isn't locked, download the Windows Password Recovery Tool 3.0, install and run it.
Step 2. Burn a password reset disk. You can choose CD/DVD or USB.
Step 3. Connect the nearly created disk with the locked Dell laptop, config bios setting to make sure it boot from the password reset disk, reboot the computer.
Step 4. Choose the user that you forgot its password, click "reset" button to begin crack its password.
Step 5. A message box will pop up, just click "Yes", then the user's password will be cracked to blank.
Step 6. Disconnect the password reset disk, and restart Dell laptop. You will login Windows with a blank password.
Hope it helps you!
Nov 21, 2011 | Dell Inspiron 1520 Motherboard
Inspiron 1525 screen goes black, image is very faint on the screen. computer remains on. What is the problem
Sounds like the backlight for the screen has died the part isn't that pricey but having it put in will probably cost almost as much as replacing the laptop. You can always plug into an external monitor, however that is not very portable
Oct 11, 2010 | Dell Inspiron 1525 Laptop
Inspiron 1520-before finishes loading desktop screen goes black..
if it works fine in safe mode you should try a system restore . most of the time a problem that gos away in safe mode is driver related . IE software don't think you have a hard ware issue. you can call dell if you do not have the disk . 1-866-751-6079 call this number it's dell's Spanish tech support number but this is the fastest way to reach a real person at dell . just ask them to speak English and they will.
May 12, 2010 | Dell Inspiron 1520 Motherboard
As it works ok in safe mode, I suggest you check that your graphics drivers are up to date.
You should be able to download the latest from the Dell website.
Mar 20, 2010 | Dell Inspiron 1520 Motherboard
Dell 1520 , on start up screen goes black.... top right hand corner of pc is hot. backlight ?invertor?has the screen got a built in ivertor?? then maybe new screen??? help please....
Hi:
The top right corner of your laptop is where the CPU and heatsink/ fan is located. If you can hook up an external monitor to your laptop, you can toggle to it with the function key and the lcd/CRT key. If you get a good display, then you have a bad inverter or possibly the LCD, but you can't do too much more troubleshooting,
Dec 01, 2009 | Dell Keyboard for Inspiron 1420, 1520,...
I have a Dell Inspiron 1520 laptop. Fan has gone
that is absolutely right i work for the same and we charge $49 If you bought the sys. after sept. 2004. and you are out of warranty.***let me know what is the blue screen all about.and stop erros code with 0x000000** this blue screen will help us to understand the issue. and i can help you to resolve your issue.
Nov 06, 2009 | Dell Inspiron 1520 Motherboard
My screen on my dell inspiron 1520 has gone black
You've lost your desktop display.
The first thing I would do is to start the computer in safe mode. Once there, do a system restore back to the time that it worked.
I would also, just to be safe, do your disk management tasks like checking your hard drive for errors and running defrag.
Oct 22, 2009 | Dell Inspiron 6000 Notebook
LCD Screen Repalcement
thats the screen problem u should change the screen than it gonna be alright,
Oct 10, 2009 | Dell Inspiron 1521 Laptop
Dell laptop screen goes blank when ac adapter plugged in
I believe I have found the problem with the 1525 that I am currently working on which has the same problem that you describe. Ultimately I think it's a problem with the inverter in the LCD. When the laptop is powered by battery the brightness is lower than full. When I plug in the power adapter the brightness goes to "full" and I hear a faint sizzle and the LCD's backlight goes off. Same as if you hold the Fn key and press the up arrow to brighten it, it will do the same thing when you reach near the full brightness. So for now I have fixed this problem by going in the Power Options and clicked on Adjust the display brightness on the left. Slide the slider to the left on the "plugged in" part and now when you plug it in it shouldn't make it go blank. I do want to note that I hear a faint buzz coming from the LCD when I plug it in. That must mean the inverter is faulty. WAY TO GO DELL!!!!!!
May 23, 2009 | Dell Inspiron 1525 Laptop
Dell 0JM629  Inspiron 1520 Keyboard  Logo
239 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
