I got this black srceen error on this pretty old tosh laptop. i get get pass this black screen. pls help i wanna know what i can do. im fixing it for a friend.
thanks alot for your help!!!!!!!
PXE-E05: The LAN adapter's configuration is corrupted or has not been initialized. The Boot Agent cannot continue.
The machine is attempting a network boot. You need to enter your BIOS setup program and change the settings to disable network boot or set it as last in the boot order (depends on the specific BIOS of the machine).
Is the network adapter built into the laptop or is it a PC Card adapter that is being used? If it is an adapter, try removing it and starting the computer without it. Another possibility is to change the amount of installed memory by adding or removing a SODIMM from the system and try booting again. Many systems don't like it when the amount of memory detected at startup and the amount saved in the CMOS don't match and it will prompt you to enter BIOS setup prior to attempting to boot the computer. This may allow you to get in there and change the boot settings.
thanks for the info.
how would i get to it though?
i press F12 and try to go in the bios and it just wont let me, the message comes out again
thank you for letting me know about whats going on
