Question about Nintendo DS Console
DS shuts down when I push the B and right button at the same time. I've looked at other trouble shooting guides and I have not seen the come up. Any ideas as to what the problem is? Thanks. Mark
  • Lone Nov 07, 2007
    The exact same thing happens with my DS
    Genius:
  • 1,019 Answers
don,t push the B button and right button at the same time :)
Problem Solved.
Mike @ Compurepair.
Posted on Feb 23, 2008
No live view nikon d90 camera
Push your camera's settings button (next to top button to left of LCD) and, using the left, right, up, down arrow keys, scroll down to the "Custom Setting Menu". Scroll down to "(d)Shooting/Display". Push the right arrow key and scroll down to "( c4)Monitor Off Delay". Push the right arrow key again and you will be able to choose set the delay between 4 seconds and 10 minutes.
Mar 28, 2014 | Nikon Cameras
I think its the thermostat and fan issue. temp rising water dispenser doesn't work. today between side by side door feels very warm to touch also the left side. should I unplug the refrige and remove...
i've seen this on g.e. machines,you have a bad computer board located on the back of the machine,one time my customer went to get a cup of water and when he pushed the dispenser the compressor would shut down,another thing i've seen is the fans speed up and slow down or not run at all.everything goes through the mother board,the common board is a wr55x10942 but you have to send the model number and i can look up your machine and tell you what board goes in it or call your parts store,give them the model number and they will sell you the right board.good luck.
Sep 17, 2011 | GE Profile 23.1 Cu. Ft. Side-by-Side...
I would like to get a set of instructions for troubleshooting electrical wiring. I have a 91 FXDB sturgis.
I would as well. I have never seen a troubleshooting guide for electrical wiring on a Harley. I've got a shematic for a Softail but no trouble shooting guides. What are you having problems with? Maybe I can help.
Steve
Sep 13, 2011 | Harley Davidson Boulevard 400 Motorcycles
My reliance electric hot water heater keeps shutting down. when I push the reset button it goes on and works for anywhere from 1 day to 5 weeks. Where do I look for a solution.
According to Reliance's trouble shooting guide, you may have faulty upper thermostat that is overheating, which is causing the high temp limit switch to open and shut it down. Pushing the reset switch is only a temporary solution until you find out what is causing it to shut down. Is it still under warranty? Call Reliance and find out. 1-800-365-4054
May 17, 2010 | Reliance WATER HEATER CO #9-40-DKRT 40GAL...
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . ryuuzaki182@gmail.com
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
DS lite plays some games but not others.
Chances are its the slot- 1... Have a look at my guide i've written to see if any of the tips I suggest help, if not there is a bit on replacing the slot- 1 part. I also have a guide on taking apart the DS lite if you need it. The replacement part is readily avaliable on ebay for very little money and so long as you have soldering equipment and a steady hand you should be fine.
Slot- 1 Trouble shoot guide
DS lite dismantle guide
If you need any more help or have any questions please feel free to contact me via my profile page.
Regards.
SOD69
Feb 14, 2010 | Nintendo DS Lite Console
Mits-WS-65712 Powers on for 3 seconds and shuts off
If you press the Input Button and Menu Button at the same time, you should see a LED flash a once or twice then pause then flash a couple more times. This is the Error Code. If you do this, it would help me determine where the problem is.
Jul 23, 2009 | Televison & Video
I need to know where I can find a trouble shooting guide for a Trane mod0944 module for a blower motor (mot09675)
Trane is very picky about being a Trane dealer before they will even talk to you. But as far as trouble shooting a module there no guides. If the flame comes on then the fan does not shutting down the furnace it could be a fan relay failure or the fan module failure. The modules propose is to allow the furnace time to heat up before bringing on the fan so as to not blow out cold. Or the fan motor it's self could failing
Oct 03, 2008 | Heating & Cooling
*ist DL/DS start up time?
It's about the time it takes to lift the camera to the eye. I have no figure to give you. A tip though: Levae the camera on. After a few minutes it turn itself to a wait status (the delay can be set in the menu). Then you save power. When the next pcture opportunity is seen just lift the camera to the eye, halfpress the shutter button and you are on the go again. I haven't seen a single complaint here about the startup time amd would say it is a non issue.
Sep 08, 2005 | Pentax *ist DS Digital Camera
Nintendo DS Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
