Question about Sharp 25N-S100 25" TV
MY TV CONNECTOR AT THE BACK BROKEN OFF
MY SHARP TV CONNECTOR HAS BROKEN OFF, CANT CONNECT MY CABLE BOX TO THE TV HELP
  • 57 Answers
You can hook it up thru av input..what i mean is the red white and yellow wires hook wires into the OUTPUT on box and the input on tv then change tv to the input u hooked them to..for example if u hooked them into av1 then turn tv to av or hiy input on remote
Posted on May 26, 2009
How do I tune my Sharp tv to channel 3 so the cable will work?
Go to the Tuner setup screen and select cable instead of air. Then put the TV on Channel 3 and connect the cable box to the antenna connector on the TV.
Jul 04, 2014 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
I cant get my sharp gaa667wjsa to go to channel 3 or 4 so i can connect my convertor box
On the tuner type setup menu page select cable then set the TV to 3 or 4 and use the antenna connector on the TV.
May 19, 2014 | Sharp LC-32SB24U 32 in. LCD TV
Antenna input on back of tv broken off
if your converter box has rca output toy can hook it up that away. Or you can look on ebay for a new main board. very easy to replace. be sure at all time to unplug tv while back cover is removed.........hope this helps
Dec 01, 2013 | Sharp Televison & Video
Cable snapped ouit of back of tv
YOu may be ble to if did not brake the nipple ompletly off the tuner. YOu will need to take he back off the t.v. and take the tuner out of the t.v and look at it to see if i could be saudered back inplace. if not you will need to get a new tuner and sauder it back in.
Sep 22, 2009 | Televison & Video
The cable connector running from tv is loose.
cannot be tightend. the coax connection is soldered in place. if you use a cable box or vcr you could use composite input and get a better pict. use the vcr or cable box to bypass tvs tuner
Jun 02, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquos LC-46D64U need to replace broken tuner
actually you dont need the tuner you just need the rf connector itself which you can easly pick up at a radio shack for a few bucks. you can DIY it will take a bit of soldering and time. First take the broken connector to radio and look for a close match, longer leads better you can always cut to fit.
remove board from tv and un solder the tuner. if solder does not seam to melt apply some fresh solder and then unsolder. pop the tuner lid of carefully both top and bottom to gain access to the circuit. cearfully remove any remains of the old connector. Now find the hole where the last part was and insert new RF connector adjust and cut the lead if nessary and resolder to circuit. place both caps back on and resolder tuner to board.connect board to ther circuit and test.
Mar 17, 2009 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sharp vcr problem
The way to connect them is as follows:
1. Connect the cable from the wall to the cable input on the cable box.
2. Connect the cable box RF output to VCR RF input (VCR must be on channel 3).
3. Connect the RF output from the VCR to the RF input on your TV (TV must be on channel 3).
After all the connections are done, leave the VCR and TV on channel 3 and use the cable box to select the channel you want to record programs from.
Good Luck.
Jul 10, 2008 | Sharp VC-A410U VCR
VGA to SHARP flat sreen tv
1. vga to vga cable
2. vga to dvi cable
3. vga to dvi cable, then dvi to component cable
Your tv must have 1 of the following:
- vga connector
- dvi connector
- component connector
Feb 24, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Female coax connector in tv bad?
If your cable converter box has audio/video connections on the back of it,you don't need to worry about using that RF coax connector. Just hook it up the same way your DVD is hooked to the TV input jack. Get a 3-wire cable (yellow-red-white)hook it to the same colors on the back of the cable box and hook the other end to an unused input on the back of the TV. Then select that input with your remote and watch TV.
Aug 30, 2007 | Sharp 27J-S100 TV
Sharp 25N-S100 25" TV Logo
340 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
