Question about Canon i475 InkJet Printer
Will not feed paper claimes feeder is blocked-need CD
I need a CD for my canon I475D class B printer i can not get it back on line. it will not feed paperno matter what it says "passege blocked" when there is nithing there" friends tell me "I need to reset it" however I've lost the CD...i'm living in north carolina and I can't find one anywhere?... ghettopoet@earthlink.net
  • 152 Answers
We have a Canon Image Class MF5900. When we put items through the feeder on the top of the machine to feed through for either copying or scanning we get the copies/scans but they also have line through...
Yes, this machine has what the call a scanning glass.Its the small thin glass where the paper goes down through the doc feed.its on this glass. A real close visual or take a clean piece of paper. Wad it up a and clean glass with that paper. It works. But if you don't have a line when you print or from the platin.(glass,main).its on that reader glass.
Feb 13, 2015 | Canon Office Equipment & Supplies
Feeder in my canon mg5250 is not working properly. It seems to feed one side and twists the paper and then sticks.
Did you check, nothing is in the paper feeder? Could be just a little piece of paper or a staple is blocking proper functioning of the feeder.
Keep the paper try clean and take care you never drop or leave anything in the printer, that does not belong there.
Mar 08, 2014 | Canon Pixma Mg5250 Imageclass Inkjet Scan...
Canon MP730 Paper feed is not working correctly.....keeps jamming and feeds the paper incorrectly
There are two feeders on this MP730. There is the sheet feeder on top and there is the paper feeder on the back. You can have problems with both.
The sheet feeder on top.
If the problem is things go through somewhat sideways, and if this is the problem, stuff some postit notes between the back grey thing and the feeder tray to eliminate this problem. Add or subtract to the wad to make it right.
If the problem is it does not grip the sheet, what I used to do is to help it through by one sheet at a time, painful. I got frustrated with this so for scanning, I have a Snap Scan 1500, which is faster and better.
The paper feeder.
A small piece of paper left in the paper infeed path can cause a major problem. You cannot have anything in the paper path that will skew the paper, so you must get any little bit of restriction out of there.
As the printer gets older, you will have to produce your own guides to prevent this skewing, as the guides on the printer do not do this well. I use clamps and wooden guides to keep things in line.
May 25, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
My printer won't feed paper. All of a sudden my printer quit feeding the paper - the error light comes on and states that there is no paper in the feeder - but there is paper in the feeder
Check the paper feed switch, you have a choice to feed paper from the back or the cassette under the paper exit. Either put paper in both or select the proper source by pressing the feed switch.
Dec 30, 2009 | Canon Pixma MP500 All-In-One InkJet...
The printer will not feed the paper into the machine
Hmm, this is too general symptom too troubleshoot. But never mind. Printer cannot feed the paper for several reasons:
Auto sheet feeder (paper feeding mechanisme) is faulty;usually generate error message on the monitor or/and error code on LCD display
Paper end did not reach paper sensor because the paper not set properly or another material block the paper path.
To find out more about this error,please check the following article exclusively for Canon printer.
Paper feed error
Paper jam error
Source: Canon Inkjet Forum
Oct 10, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper out canon pixma ip200
Either you have selected the wrong feeder, it can feed from the back or the front tray, the little green light shows which tray is selected. If you have paper in both, the feed roller may need cleaning since it gives that error if paper doesn't get picked up.
Sep 01, 2009 | Canon PIXMA iP2000 InkJet Printer
Top feeder not working MF6550
One or both of the ADF hinges are bad. The ADF cover doesn't close all of the way causing feed failure of the original and shading on the side of the copy because the scanned original is not fully contacting the **** exposure glass on the front operators side.
Feb 27, 2009 | Canon imageCLASS MF6550 All-In-One Laser...
Not feeding
Have you still getting the problem, have you done cleaning of Cartridge, its nozzle and Contact strip.. then cleaning of Printer roller or carriage rack.. Do a Service of it or get it done by Technician.
Also check the feeder tray.. to grab paper one by one by printer.. Manually
Take all updates for printer and OS.
Oct 31, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon Printer PIXMA MP500
Check in the printer driver properties window on the computer. It sounds like the Paper Source is set to "Auto Sheet Feeder". You need to change this setting to "Paper Feed Switch" so that you can select the paper source from the printer itself.
Jul 24, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon i475D Printer
Try cleaning the rollers where the paper feeds in, a cotton bud with metho works on my printers
Apr 15, 2008 | Canon i475 InkJet Printer
Canon i475 InkJet Printer Logo
89 people viewed this question
old marine
old marine
