Question about Toshiba Computers & Internet
Hi I have a Toshiba Satelite M45 that appears to have a graphic problem. I have hooked up to external monitor but still get coloured lines and ghosting on screen. can the video card be replaced or is it onboard. Thanks, Phil.
  • quokka24 May 26, 2009
    Thank you for your help, showing the diagramme was a big help.
    cheers, Phil.
  • Toshiba Master
  • 13,433 Answers
Hi
looking at the Toshiba satellite M45 service manual.
appears it has a Removable VGA board
Hi
if the picture is unclear try
http://users.turkuai.fi/users/niohtone/vga.jpg
Now where to get a replacement? that's somewhat of a mystery. Try contacting Toshiba, also www.pchub.com and also check on ebay, I just did and couldn't find one from ebay.
Posted on May 26, 2009
I connected RGB from toshiba m45-s169 to tv. Had a signal but now cant get it back. Tried updating video driver. Help?
You can switch to an external monitor, TV or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Oct 23, 2012 | Toshiba Satellite M45-S169 Notebook
I have a Toshiba Satellite M45 and the monitor no longer works. there are some lines on the screen (left) and the rest of the screen is black.
Can you tell us please, what - recently - happen to the lap? have it been shocked, dropped down ,,, ?
To test, u can plug external monitor in the VGA-port, turn ON the laptop, after a minute, toggle the display once, or twice, or 3 times to change the display path to the external monitor.
Tell us your results
Good Luck
May 13, 2011 | Toshiba Satellite M45-S2652 Notebook
Vertical lines appear on screen
Hook a external monitor to the video output on the back of the laptop, if okay! you have a bad LCD on the computer or the video cord from the motherboard to the screen is loose. But if both displays show the same problem, it is the video graphics card on the motherboard.
Feb 02, 2011 | Toshiba Computers & Internet
I have a toshiba satelite A-55 S1063 my screen started flickering and the screen goes off why?
Usually it's because the lcd is no longer working. You can try hooking your computer to an external monitor to see if you get video. Make sure the computer is off and hooked up to the monitor before powering on the computer.
Let us know what happens!
Nov 25, 2009 | Toshiba Satellite A55-S1063 Notebook
Vertical lines are appearing on my toshiba laptop
first try to hook it into an external monitor if it looks good,I would have to say you have a damaged cable on your monitor.if you are comfortable taking it apart you can try to reseat the ribbon cable on the mobo.you can usually find an online manual for disassembly.
Apr 23, 2009 | Toshiba Satellite 2455-S305 Notebook
Vertical line in imac 17" core 2 duo intel 2006 model
Attach an external monitor (you may need to buy an adapter to try this) and turn on Display Mirroring in the Display preferences.
If the same symptom shows on the external monitor, then you've got a video card problem. If not, I'd say you're screen has some kind of damage of failure.
Sorry, but either one is likely going to require a trip to the Apple Hospital.
At least with the display problem, you could use the external monitor until repaired.
Mar 16, 2009 | Apple iMac G5 Desktop
Karaoke
hi, you can connect a video monitor or beam your laptop with the external VGA output fn + f5 and you can select the preferred output, but everything you do on the laptop, will appear in another screen
Mar 13, 2009 | Toshiba Satellite A215-S4747 Notebook
Screen problem.
Does your LCD look like this or similiar? (below) If it does, there should be a female plug similiar to the picture also below.
Hook smaller end of cable to your laptop, the other end to your external monitor. Turn on your laptop. If the vertical lines are not present then its probably your LCD, which will more than likely have to be replaced. If lines are present, then like tom19511 said it may be the video drivers. I've had this same problem with my Toshiba Satellite p35 5 times already. Toshiba had to replace my LCD each time. LCD's are more expensive than an inverter. Good luck, I hope you get it fixed.
Dec 13, 2007 | Toshiba Satellite P35-S611 Notebook
Random screen freeze
You are going to need your WINDOWS CD: http://www.updatexp.com/scannow-sfc.html
Dec 03, 2007 | Toshiba Satellite M45-S265 Notebook
Computers & Internet Logo
27 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
