Question about Garmin GPS Devices
Garmin Nuvi 300. Map on SD card - can't unlock
Dear Sirs,
I have a Garmin Nuvi 300 purchased in Ireland.  The Nuvi came with maps for Ireland and England pre-installed.
Am now in South Africa and purchased SA map on SD card.  Now I have gathered from my reading on the Internet that these cards should be "Plug and Play" with no installation or unlocking requred but with the card inserted in the slot I get a message that the Nuvi can't unlock the maps.
I do not want to remove the internally installed map of Ireland and UK as I shall be there again next year.
Can you help please?
I should mention that the pre-installed maps are internal i.e. there was no SD card in the external slot when I bought the unit.
Would be very grateful for help/advice.
Thank you.
  • 24 Answers
SOURCE: Tomtom one cant unlock maps
well,then there is only one way, that definetly works, ttsystem patcher, if tomtom company doesn;t want to help, we can do it our self ;)
there are lots of warez about ir ;) in ;)
Posted on Mar 01, 2009
SOURCE: Nuvi 200w map download and sd card
Guys and or ladies... I know that you have to create a folder named "GARMIN" in the sd card so the maps can be recognize. Maybe this solves your problem. Let me know if it works.
BR from Spain,
Posted on Apr 01, 2009
SOURCE: Can't unlock maps on the SD card
I am still waiting for the promised free solution suggestions
Posted on Jun 13, 2009
  • 4090 Answers
SOURCE: Maps on SD card not recognized by Garmin C330 GPS
I dont thinki the 330 handles 4Gb SD cards I think 2Gb is the maximum that is why it isd taking so long and runds out of space so cannot properly load the maps.
Posted on Jul 22, 2009
  • 13 Answers
Posted on Jul 31, 2009
SOURCE: Garmin C510 wont install download Europe maps to Unit
Take a look at the Garmin support page - there is a Question " Why do I get a not enough space message on my Nuvi2xx when trying to update my mapping?"
It tells you how to remove the unused voice files to free up space.
I have a Nuvi 255WT and deleting the voice files alone was not enough, so I set about removing a lot of other stuff *** NOTE THAT IF YOU FOLLOW WHAT I DID, DO IT AT YOUR OWN RISK **** it worked for me but there is always the risk of deleting a file that the device needs.
Also I was stupid and didn't try and save the files to a directory on my MAC before deleting them, from the satnav - worth a try so that if you can do that you have a chance of recovering one that you delete if you want it back.
First I also removed the un-needed text files - leaving only the 3 British-English files
Then I removed all of the POI files that were clearly examples/samples
Then I removed all of the Vehicle files except the one I was using
Then I removed all of the large ExtData files - now that was the one that caused me the most worry as I wasn't certain what they were there for!
This gave me a bit over 140Mbyte of free space which was enough to install the 2010 update for all of Europe.
Now I don't know whether the C510 has the same amount/less/more memory than the 255WT - so this may or may not work for you.
I didn't have an SD card available, which is why I went this far. I am going to get one and see if I can find out how to load the maps onto that.
cheers - Jeremy
Posted on Dec 01, 2009
0 characters
1 Points
Need to know how i update the maps card for it
The latest version of Garmin Express provides the ability to install a map update directly to an SD card.
The SD card installation option will only appear when updating a compatible device that does not have sufficient internal memory for the largest allowable map region. When using the SD card installation option, critical files are loaded to the SD card so it must remain in the device after the update to ensure full functionality. For the largest size SD card a device can use, refer to: What is the largest size Secure Digital (SD) card that an automotive device can accept?
The SD card support during the map update will only function with up-to-date software. It may be necessary to update the device's software with Garmin Express prior to updating the maps. These devices do not support the SD card option:
  • Nissan 700
  • nuvi 295
  • nuvi 300 series
  • nuvi 500 series
  • nuvi 600 series
  • nuvi 800 series
  • nuvi 805 series
  • nuvi 5000
  • StreetPilot series
  • zumo 450
  • zumo 550
  • zumo 665
For devices that do not support using the SD card with the map update application, any maps that do not fit in the internal memory can be installed to the SD card manually, using these instructions:
Try the may help.Under support.
Garmin United States Home
Nov 09, 2015 | GPS Devices
How to access maps on sd card
Same map name on internal memory and sd card can be problem.You can also try to upgrade your software with garmin web updater,but be sure that your battery is fully charged before doing an update.
Jul 27, 2014 | Garmin nuvi 1490T GPS Receiver
How to format the sd card for nuvi 1390t
I found the solution on my own. My PC is a Win 7 64bit machine and I was using Google Chrome Version 18. When I tried the download again using IE, it worked fine. I now have 3 full maps on my Nuvi 1390 (i in the internal memory and 2 in the SD card) and can access each one without a problem.
May 10, 2012 | Garmin nuvi 1390T Car GPS Receiver
I have 2010 maps on a SD card for my Nuvi. Does
If you already have a map on your unit, you will have both maps. You may have to enable the map on the SD card. At the main menu, press the wrench symbol, then the map icon and then "map info". You should see all of your maps that are available to your unit. Make sure that the square boxes next to each map are checked. Thats how you turn on/off (selct) each map. If the SD card map isn't working, make sure it has a unlock code assigned to the map or it won't work on your unit. Also, the map file name on an SD card is different than the name on your unit. - Jim
Jul 21, 2010 | Garmin Nuvi 660 GPS Receiver
I need to install map update 2009 data card
If the map is on a SD card, just plug it into the SD slot on the side of your Nuvi with the power OFF. Then turn on your Nuvi and at the main menu, press the wrench symbol, then the map icon and then "map info". Uncheck your old 2008 map and check your 2009 map and you should be ready to go.
- Jim
Jan 18, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 610
Oct 27, 2008 | Garmin Nuvi 610 GPS Receiver
Garmin Nuvi 300 - SD problem
I believe your current location is somewhere in UK/Ireland, which means the Nuvi's last/current satellite fix is not anywhere within Spain/Portugal. If you need to use the maps features of that country where you're not physically there with the Nuvi, the Nuvi must be in Simulation mode first. Fold down the antenna to switch off GPS (not device) and enter Simulation mode.
Then, scroll the map screen (combinations of zooming out, browsing, and zooming in to the spot) until you find the location you want to simulate (it must be within the maps coverage). Then, tap 'Set Loc' at the bottom of the screen. At this point, as far as the Nuvi is concerned, this is the GPS location where you are at. Then you may proceed with Address Search, etc. using the other map's database.
Jul 26, 2008 | Garmin Nuvi 660 GPS Receiver
Each map is locked to the unit serial number. The only way to get the map to work on another unit is to buy the maps and register the map serial number and you will receive a unlock code from garmin.
Go to the following link to unlock the map
May 22, 2008 | Garmin nuvi 350 GPS Receiver
The Nuvi 350 does have an SD cart slot in the side, which will allow you to purchase maps of other countries on an SD card, and use them in your unit. Garmin has a list of available maps for purchase on their web site.
Feb 11, 2008 | Garmin nuvi 350 GPS Receiver
GPS Devices Logo
1,483 people viewed this question
Top Garmin GPS Devices Experts
Tom Chichester
Jonathon summesfield
Bill Gilhooly
Bill Gilhooly
Are you a Garmin GPS Device Expert? Answer questions, earn points and help others
