Question about Mitsubishi VS-45605 50" Rear Projection Television
Screen rolls maybe vertical sync
I have a Mitsubishi VS-50605 big screen tv. The picture rolls and doesn't stop after warming. I beleive something is wrong with the vertical sync after researching on the net. I need to know how to fix it. Please HELP! :) Thanx
II NEED TO RESOLVE A PROBLEM OF VERTICAL SINCRONICE I SALLBE GRETFULL TO HAVE ADJUSTMENT INFORMATION I SHALL BE GRATEFULL IF YOU COULD HELP ME
Posted on May 28, 2009
Mitsubishi VS-50605 - no vertical control until it warms up and it is now starting to flash to a black screen
Howdy,
CHECK AND REPLCE C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR) BOTH ARE ON THE SIGNAL PCB.
Good Luck, big IRISH.
Dec 29, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Rolling lines until tv warms up
Vertical output IC bad capacitors in vertical circuit 100uf 35v sometimes vertical IC needs to be resolder and that fixes problem look for poor solder joint s.
Sep 27, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Picture rolling when I first turn on my tv
A rolling picture or loss of vertical sync can be caused by several components including a bad signal board or jack panel assy. You will not be able to resolve this yourself. contact a Mitsubishi authorized service center.
michtech
Feb 14, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Picture rolling horizontally and vertically
tv needs repair c2c52 and c2po5 need to remove .both should be on the signal pcb
Nov 16, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Rolling screen
Good Day; lanniejo;
1. VERTICAL ROLLING, ALSO MAY HAVE HORIZONTAL PULLING OR TEARING. REPLACE C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. REPLACE C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
It should not be that costly, always get an estimate, if you can't repair it yourself. Don't worry about the light bulb, it should be okay, as long as the picture color is ok. Good Luck, big IRISH.
Sep 29, 2008 | Mitsubishi VS-50605 50" Rear Projection...
VERTCAL HOLD
Good Day, marvy21; try theses ideas, they will fix the TV # 3 is most common, you might start there. 1). VERTICAL ROLLING, VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE, ALSO MAY HAVE HORIZONTAL PULLING OR TEARING. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2). CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.2). CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB. 3). CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB. Good Luck, big IRISH.
Jun 10, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Whats a quick solution
The problem may be related to bad capacitors on the PIP module. This is a commom fault as vertical sync runs through the PIP board and this is the symptom of the pip board having bad capacitors the TV rolls.
Mar 02, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi big screen tv
Do the self test first find the error code. Look on here or ctechnicians.com
Jan 02, 2008 | Mitsubishi VS-50605 50" Rear Projection...
55IN TV.
1. VERTICAL ROLLING, VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE, ALSO MAY HAVE HORIZONTAL PULLING OR TEARING. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01
Oct 31, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-45605 50" Rear Projection Television Logo
561 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
