Question about HP DeskJet 670c InkJet Printer
Print Spooler Problem
Print spooler wont work, i start it everytime and my printer still cant be added or be found
  • bigmig65 Oct 27, 2007
    Still doesnt work! darnit!
    Scholar:
  • 84 Answers
Click on start
click on run
Type services.msc
A box will open up
Make sure all items below are set to automactic
To make the changes double click on each item
change to automatic if diabled. Then click apply when you are done.
Restart the computer and try testing your printer again.
Printer Spooler
LexBce Server
Remote Procedure CallRPC)
Hope this solves your problem
Posted on Oct 21, 2007
  • annette best Nov 07, 2007
    Try re-installing your printer software/driver.
I cannot print my documents, everytime I click the printer "print spooler is not running". I already restart my printer as well as my computer. And I also tried to reinstall my printer but it doesn
Click Start.
Type services.msc in the start search box and press enter.
Right click on print spooler and click on properties.
Check if the startup type is automatic. If it is not then change it to automatic.
Check if the service status is stopped.
If yes then click on the start button.
Try to add a printer and print a test page.
If you need any technical help on printer then you can reach at here
Jan 25, 2013 | Office Equipment & Supplies
Printing sitting in queue wont print
The print spooler may not be working.
Start and stop the print spooler Windows XP
To start and stop the print spooler open Computer Management, click Start, click Control Panel, double-click Administrative Tools, and then double-click Computer Management. In the console tree, click Component Services.
Under Console Root click Services (Local)
In the details pane, double-click Print Spooler. Do one of the following depending on the task you want to do:
Click Stop to stop the service.
Click Start to start the service. When you try to install a printer and get an error message "Print Spooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the General tab then select these items - Startup type select Automatic Service status click Start Then click OK
Aug 28, 2012 | Brother MFC-290C Printer
Print spooler subsystem stopped
To start and stop the print spooleropen Computer Management, click Start,click Control Panel, double-click Administrative Tools,and then double-click Computer Management.In the console tree, click Component Services.
In the details pane, double-click Print Spooler.Do one of the following depending on the task you want todo:
Click Start to start the service.When you try to install a printer and get an error message "PrintSpooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the Generaltab then select these items - Startup type select AutomaticService status click StartThen click OK
May 12, 2012 | Office Equipment & Supplies
Actually my computer has a problem.everytime i want to print some documents is shows an error named spooler subsystem application error..i have canon LBP 2900B printer. plz help me out
Print spooler is no less than the main master of printing proceeding. Print spooler is a linking section between your PC and printing hardware. Print spooler is the only master of print province of your PC office. Print spooler can inkle nothing and encounter an artificial virus threat which will cease your printing operation and compel your print spooler down on the count. Sometimes to solve print spooler problem it is enouph to clear print spooler, but in most cases you won't get rid of it.
To get rid of it there is a tool named printer spooler fixer.
The link to get that is below.Just copy it and paste in your browser
http://www.printer-spooler.com/download/fix-wizard/PrinterSpoolerFixWizard3.exe?key=FixWizard
Jan 07, 2011 | Canon LASER SHOT LBP-2900 Printer
Brother printer dcp-135c cant add to computer
Right click on your My Computer icon. Go to Manage. From there, expand the Services and Applications section. Select Services. On the right hand side, scroll down until you see the "Print Spooler" entry. Doubleclick it. If the "Startup Type" is anything but "Automatic" change it to that. Then click the "Start" button, then "Apply" then "OK". You should be working now.
Aug 10, 2009 | Brother MultiFunction Center MFC-440CN...
Printer is not working.
Hi Surenderpdsi
It sounds as if the printer spooler needs re-starting.
This is the path to the printer spooler service,
Windows XP Path (category view)
Start – Control Panel – Performance and maintenance – Administrative tools – Services.
Windows Vista Path (category view)
Start – Control Panel – System and Maintenance – Administrative tool – Services.
Once in Services both XP and Vista are the same.
Look down the list till you find Printer Spooler.
Once found, right click your mouse on Print Spooler and select Properties.
In the properties box that open the service status should read “Started” if not click on start.
If it says the spooler is started click stop, wait till the spooler has stopped then click start.
This will re-start the spooler and should fix your problem.
Hope this helps,
MK Support.
Mar 15, 2009 | HP DeskJet 3745 Printer
In Printer Properties choose PRINT DIRECTLY TO PRINTER
Feb 03, 2009 | Brother Multi-Function Center MFC-240C...
Print spooler
To prevent the spooler from stopping, which is usually caused by invalid printer drivers left on a computer.
Go into "Printers and Faxes" delete all printers which no longer exist by right click --> delete
To restart the spooler :-
click start --> run
type net spooler start click ok
or
click start --> run --> services.msc --> click ok
scroll down to print spooler --> right click on it and select start
Jan 30, 2009 | HP xw6600 Workstation with 650W 80 PLUS...
Everytime i try to print it says that the print spooler isnt working. can you help?
You need to start the Print spooler service, this is in the control panel, under administrative tools, under services - then find print spooler and either start it or restart it.
Robin
Sep 16, 2008 | Office Equipment & Supplies
Try this:
Start the computer in safe mode then delete all the files and the folders in the following two folders: • C:\Windows\System32\Spool\Printers
• C:\Windows\System32\Spool\Drivers\w32x86
Start Registry Editor. To do this, click Start, click Run, type regedit in the Open box, and then click OK
Locate and expand the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86
View the list of subkeys. There should only be the following subkeys: • Drivers
• Print Processors
delete any other in this list
Locate and then expand the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Monitors
View the list of subkeys. There should only be the following subkeys for the default print monitors: • BJ Language Monitor
• Local Port
• PJL Language Monitor
• Standard TCP/IP Port
• USB Monitor
delete any other in this list then restart your computer.
Good Luck
May 24, 2008 | HP PhotoSmart C4180 All-in-One Color...
HP DeskJet 670c InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
