Question about HP Photosmart C7280 Printer
Error 0xc18a0301 hp photosmart c5180 Ink system failure Unable to print refer to printer documentation. Error 0xc18a0301 turn power off then on again Hello Joe I just came across this site and I was wondering i fyou can help me I have a similar problem with my HP Photsmart 7280 with the ink error message..Oxc05d1381 can you please tell me what to do to fix the problem. I would appreciate it very much.. Alina
  • Ali0968 May 26, 2009
    Thank you all for your help.. Laxmankumar I try doing that as well an nothing.. I did this step a few times..
    if you think of anythign let me know....Thank you so much for your promt respond.
    Alina
  • Paul McGrath
    Paul McGrath May 11, 2010
    First, be sure the ink cartridges are properly installed and you have 'reset' the printer. If there is any ink/dirt on the electrical contacts of the cartridge, they will interfere with proper communication with the micro-computer in the printer.
    Scholar:
  • 191 Answers
Hello Alina,
Please Click here and follow the instructions to resolve this issue.
Regards
laxman
Posted on May 26, 2009
  • laxmankumar
    laxmankumar May 26, 2009
    Hi Alina,
    Before concluding this as a hardware issue Please Click here and follow the instructions and check the functionality. If same error message displays then perform the steps given below.
    Bypass the surge protector
    If the all-in-one is plugged into a power strip, remove it from the
    power strip and plug it directly into a wall outlet and see if the
    message still appears.
    Power Cycling
    1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
    2. Wait 30 seconds.
    3. Plug in the power only.
    4. Repeat steps 2-4 two more times.
    5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
    6. Restart your computer and check the functionality.
    ==== Partial Reset ====
    Press and hold # and 3 button on the unit while plugging in the power cord.
    Note: For models that are not fax capable, press Plus (+) instead of #.
    Regards
    laxman
  • laxmankumar
    laxmankumar Oct 13, 2009
    Hi Alina,
    Please perform the steps given below and let me know the results.
    1. Unplug the power cord from wall outlet.
    2. wait 60 seconds.
    3. Press and hold # and 7 while plugging in the power cord into wall outlet.
    4. Check if the error message exists.
I have an error message on my HP Photosmart C5180 All-in-One printer stating: Ink system has failed. Unable to print. Refer to printer documentation. Error: 0xc18a0201
Hi!
Ink System Failed is displayed becuase the printer head can not communicate with the main board of the printer and this can happen due to print head failure there is nothing you can do except repairing the printer.
Aug 10, 2010 | HP Photosmart C5180 All-In-One InkJet...
Ink system has failed. Unable to print. Refer to printer documentation Error: 0xc18a0201
I have a HP photosmart C5180 all in one. It has an error message that says....Ink system failed unable to print refer to printer documentation error OXCa0501. By chance would you know what to do to fix it? Thanks
May 25, 2010 | HP Photosmart C5180 All-In-One InkJet...
I have an Hp c5180 and I am unable to print.
Look here: http://www.out-of-warranty.com/ink-system-failure-error-0xc18a-hp
Oct 04, 2009 | HP Photosmart C5180 All-In-One InkJet...
Hp c5180 printer: While printing a job, the
it sounds like the printer is malufunctioning...it might be a problem with the printer head..see where the printer opens for the ink.. look at the yellow space for the ink.. remove the ink and take a cotton swab full of alcohol and clean it then let it dry and place the new ink cartridge there and restart the machine..see if it gives the same eror..if it does consider replacing the device
Jul 12, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error 0xc18a0301
Error: 0xc18a0301 fix from HP tech support:
Let us perform some steps to isolate the issue and find a fix for it.
Please perform the following steps and let me know the message that will be displayed on the printer.
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
Screen says "support" R0631M
Press and release the right arrow button until the display says “System Configuration Menu”.
Press and release the “OK” button.
Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
Display should say “Hardware failure status: Clear. Press OK to clear”.
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
Is the error message still being displayed on the printer?
Print a self test page to check the functionality of the printer.
Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
Ink System Failure on HP Photosmart c5180
Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. However there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
Dec 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
Ink system failure
hp photosmart c7288 all-in-one
ink system has failed unable to copy receive faxes or print refer to printer documentation error oxc19a0002
Nov 25, 2008 | Office Equipment & Supplies
Ink system has failed. Unable to print. Error:0xc18a0301. Turn power off then on again. Problem continues. Hp Photosmart C5180 All-In-One
Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
Nov 13, 2008 | HP Office Equipment & Supplies
HP Photosmart C7280 Printer Logo
1,113 people viewed this question
Seeker5211
Seeker5211
