Question about Palm Treo 650 Handheld
Mike don't work
People can't hear me when I am talking on my treo.  Think the problem is the internal mike.  Where can I purchase one if you think I am on the right track.
Thanks,
-aj-
  • busy1961 Dec 17, 2007
    Dear Mic problem: Not sure when you posted your problem but I just went
    thru the samething with my mic on my 650 and I found a website:
    www.performancepda.com. They sell the mic for $15. Hope this helps.
    Problem Solver:
  • 11 Answers
Try using it with a plug in headset to make sure it is the mike. If calls work with plug in then you are probably right, parts like the mike are difficult to get try googling pda parts or smartphone parts maybe you will find someone who has these.
Kevan
Posted on Nov 18, 2007
Mike is not working but there is some problem with my mike i can not hear the voice of incoming call. i have given the mobilr for service he is saying that your both mike is ok . for that you have to...
hi :) i u cant hear people talking,that not mike problem. mike problem is people cant hear u talking. i think your speaker was spoil already,that why u cant hear the voice incoming or ringing.u better send for check again :)
if my solution useful,please voted me.thanks..
Jul 30, 2010 | LG Shine KE970 Cellular Phone
Key mike no hears me but shows meter
You didn't mention if you hear the other radio. If not, here's a common problem and solution.
That's usually a defective amc stage that produces RX audio and TX modulation. It's an integrated circuit that will require a tech fixing it. You will have a transmitted carrier with no modulation, and no sound in your speaker. However, make sure you have a good mike plugged in first, and substitute a known good mike to verify it's not the mike.
However, if you hear them, and they see your signal, but no talk (modulation), then the problem is usually your mike. Try another one in this case. Thanks, Bill
Jul 27, 2010 | Cobra 19 Ultra II CB Radio
Trying to wire a 56 for a tristar 120. any ideas?
I think you are talking roadking 56, take the end of mike apart, you will need a 4 pin mike end,solder,steady hand,or small clip vise like I use,it takes just a little dab of solder for each wire,don,t over do it,trim each mike wire one eight inch back,slide the mike end on the cord,do not forget the plastic insulator,then solder the white (audio) to pin 1. then solder the shield and red together to pin 2,then solder the black (receive) wire to pin 3, then solder the blue (transmit) to pin 4. Then put it back together. ..hope this helps..
Mar 28, 2010 | Radio Communications
W300i speaker stopped working, other side cannot hear my voice
Hi, my w300i speaker (mike) stopped working, my voice cannot be heard on the other side, but, when I connect the handsfree, things become fine.
Seems, the internal mike has got a problem, please suggest a remedy?
is it mandatory to get the mike changed, something similar had happened a year back and that time, they had said, that since the mike is a part of the board, the entire circuit board needs to get replaced.
Any idea, how much the board (circuit) will cost in Mumbai, India?
Mar 25, 2009 | Sony Ericsson W300 Cellular Phone
Micrphone
in the sys tray bottom right look for the sound icon and double click on it ..it may be hidden ,if so click the arrow to reveal more...the master volume will come up ...here you can see if you have internal mic and can alter levels and add other via properties from options.if you dont have internal mike get pc mike ...just plugs in jack socket to use voip.(can talk in chat rooms or make net calls.
Jan 10, 2009 | HP Compaq Presario V2000 Notebook
Ge headphone
Try another microphone or headset with a microphone that you know is working. If the replacement works, the new GE has a bad mike or connector. Return it for a replacement.
If they both don't work, you have a computer problem to resolve.
Hope this helps :)
Apr 01, 2008 | GE (JASHO98334) Headphones
Mic troubles
Most shotgun mikes are only going to provide a mono output. In some cases there are two internal pick ups and the output would be stereo. A good example of this would be the Audio Technica AT822 which almost looks like two mikes joined together. I have a Sennheiser MKE300 and I modified the plug in order for the signal to be fed to both channels (double mono) I'm not familiar with your Sony mike and I would think that it would feed both channels, either as stereo or double mono, but perhaps it is not designed to do so. And being a hot shoe connection it wouldn't be possible to alter it until the editing stage. However, having said all that, the other problems you describe indicate a faulty mike. The low signal level indicates a lack of power to the mike, which in your case should be provided by the camera (unless there is a place for a battery in the mike, but I doubt it). I don't think it should be tinny either. I have had some issues with my Sennheiser picking up too much camera noise and handling noise but the audio of the subject is quite good. So, if you want a suggestion ... Take the Sony mike back - if you can. Buy a good quality shotgun (not the Sennheiser MKE300!) that has a standard plug on it (XLR or 3.5mm). Buy an external recording device (I use a minidisc and/or an Edirol R-1) This will give you greater control over mike placement and provide redundancy ( I recently recorded a wedding with a broken mike cable -I didn't find out until the editing stage that the camera hadn't recorded usable audio)
Sep 15, 2005 | Sony Handycam DCR-TRV19 Mini DV Digital...
Palm Treo 650 Handheld Logo
44 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
