Question about Marantz Audio Players & Recorders
Audio distorsionado en canal izqierdo
Hello I am a technician of chili am repairing an amplifier marantz model pm 750dc who presents audio distorcionado in left channel, I change the transistors of exit, the transistors driver, the condensers electrolytic and the constant fault I need help
    President:
  • 1,348 Answers
The input selector switches if they are dirty can make the amplifier sound like it has a blown channel.
compare voltages from the left and right channel and make sure they are identical as well as the power supply,typically + and - 65vdc .check the regulators for the pream,they run panel lights off the same circuit + - 14vdc
Posted on May 26, 2009
En modo bridgeable a cuantos omhs es estable y cuantos watts rms arroja
Amp is not powerful enough to power the subwoofer. You will burn out the amp.
Oct 11, 2012 | DHD NTX-2126 XLR Car Audio Amplifier
I have a MARANTZ PM 151 Integrated Amplifier thats about 20 years old. I have not used it for a few years now and when I tried it recently it will only play from one speaker. It worked fine before I put it...
Hello
Long time storage may have make electronic contacts to get poor and fungus infected. Your set need a whole service. During service they will clean all the contacts and rectify repairs if any. Get it serviced. OK.
Jul 11, 2011 | Audio Players & Recorders
Sound probem of marantz amplifier at right side.
sure it is not the speaker?
switch them and check
Mar 02, 2010 | Audio Players & Recorders
The fuse keeps blowing in my marantz pm-57 amplifier. It says it takes a T 2.5A 250V fuse. I can only find 2.5A 250V fuses. What relevance is the ''T''.
Goo day sir, the T on the fuse has nothing to do on you marantz fuse blowing up, chances are you amplifier is shorted, check you IC amplifier/power transistor for shorts. Check also your speaker impedance. usually they are 8 ohms. You can use a technician's multitester device to check the impeadance. An imbalance or mismatch speaker can cause a fuse to blow and destroy your amplifier. hope this helps.
Jul 31, 2009 | Marantz PM-15S1 2-Channel Amplifier
Marantz Pm-7200 left channel weak compared to the right
hmmm. Let's start by swapping the wires you are using for your speakers. Double check the wire connections first, then take the left and place iton the right and vice versa.
May 05, 2009 | Marantz PM7200 2-Channel Amplifier
Can I remotely control speaker outputs on the Marantz PM 8003?
HI...
You need an 8 ohm stereo "L-pad"
Try partsexpress.com
or
mcmelectronics.com
Dec 21, 2008 | Marantz Audio Players & Recorders
Marantz PM-48 connecting to TV
look on the back of the TV and there should be L/R audio outputs (white & red), connect this to a spare input of your amp via a connecting lead eg. AUX or any other input except PHONO.
hope this helps.
Oct 19, 2008 | Marantz PM-68 Amplifier
I have a marantz integrated stereo amplifier PM-57 and it keep cutting out regularly. its sounds like a relay is clicking in and out. what can i do?
please disconnect loudspeaker one by one until the problem is goen -and fix the bad one by change the cabel first and the speaker second if all above does not solve the problem send your amp to service center to repair.
May 27, 2008 | Marantz Audio Players & Recorders
Marantz pm 7200
Could be a power supply failure or a Power "On" switch failure.
Kev
Feb 23, 2008 | Marantz PM7200 2-Channel Amplifier
112 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
