Question about HP Photosmart 2575 All-In-One Printer, Scanner, Copier
Error message request to load paper when paper is loaded. Appears that it doesn't detect paper or can't pick it up.
Error message on HP 2575 All-in-one printer states load paper when paper is already loaded in tray. Appears that it doesn't detect paper or can't pick it up.
  • 1 more comment
  • s_leary May 26, 2009
    No paper to interrupt the switch.
    What's your take on this "solution" addressing the spring?
    Best Solution
    posted on Feb 22, 2008
    Asker's Rating
    yodeller
    Rank: Apprentice
    Rating: 94%, 4 votes
    This is a very common problem. Apparently HP changed the roller because of this fault.
    I've tried cleaning, I've tried making the roller rough. I tried to get HP to send me a new roller but they didn't even reply.
    HP are a rubbish company who don't care at all about customers (and their printer software (bloatware) is even more rubbish).
    BUT - the solution I found:
    The spring that holds the roller down onto the paper is too weak. I bent the end of a straightened out paper clip into a small hook then made another hook-like bend a bit further up (but kept the rest of the clip to use like a handle). the length between the two hook parts is just under 1/2 inch. Don't cut it yet - buy you will need to when it's in place.
    Hold the handle end (the bit at the bottom of this sketch) so you can fiddle about in the small space and don't loose the spring altogether.
    Find the spring that fixes onto the roller gadget, it hooks onto the printer body. Hook the spring off the hole in the printer body, and then catch the second (double) hook of the paperclip onto the small printed circuit board just by the roller (most of the board is empty - so hook it to the left end of the board).
    Then, when it's all in place cut the rest of the paperclip off.
    You can see the double hook part once I'd cut off the "handle" piece in the photo:
    and here you can see where the spring used to go, and where it fixes with the clip thingy I made.
    Of course this is what I did (when I was about to throw the printer away so it was a last chance survival idea), if you loose the spring, stick it onto something that goes sparky-sparky or otherwise kill the machine or yourself I can't take responsibility!
    I should have mentioned in my correspondence that I had already followed HP service you mention to check for functionality to no avail. Guess that leaves the Cleaning Kit option... or purchasing a competitor's All-in-One printer scanner. Any recommendations for a wireless unit?
  • Paul McGrath
    Paul McGrath May 11, 2010
    microswitch failure or IC processor not receiving signal or trash (piece of paper) interrupting the switch to function normally
    Scholar:
  • 191 Answers
I recommend you to follow the instructions given in HP web-site only to ensure the proper functionality of your product.
Please Click Here and follow the instructions to check the functionality.
If problem still persists Click here and follow the instructions to clean paper rollers using Cleaning kit.
Posted on May 26, 2009
  • laxmankumar
    laxmankumar May 28, 2009
    I don't know much about other printers. But I can suggest you the following All-in-ones for the wireless capability.
    1. HP Officejet Pro 8500 Wireless All-in-One Printer - A909g
    2. HP Officejet 6500 wireless All-in-One
  • laxmankumar
Cannon mp530 says load paper when paper is loaded
Paper not loaded error is displayed by the printer when the printer doesn't detect any paper. Here try this one.
  • Make sure that your paper is properly inserted.
  • If properly inserted and still the printer doesn't detect it. Try putting more amount of paper in the tray.
  • Be sure that there are no damaged paper in the tray.
  • Clean the rollers using a cotton buds and a clean water.
  • Now try printing again.
Hope my solution will help. Thanks for using fixya.
Jul 08, 2011 | Canon Office Equipment & Supplies
Whenever a print job is sent to my dell 3100cn laser printer, ?Load tray 1? appears in the small window of the printer. I loaded the tray several times but it doesn?t work. Please guide me through the...
You sent a paper size different of the requested by the printer. Just load the requested size or delete the spool.
Some PDF downloaded from internet has A4 or 8,5x11", maybe is requesting one of this sizes.
If you can not delete this message, delete the spool using the printer manual in the control panel of the printer.
Dec 11, 2010 | Dell 3100cn Laser Printer
HP 2575 printer - paper jam message
Resetting the product may help with some false error messages. Press power button to turn printer off, unplug the power cord, wait a few seconds, plug it back in, press power button to turn printer back on. Any luck?
Dec 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
My HP 2575 Photosmart all-in- one will not feed paper. Message says out of paper when it is full of paper
there is paper feed sensor inside the printer. make sure it is there and not broken off. the sensor is in the back center of the paper tray, and is spring loaded. if you can't find it, shake the printer with the paper tray facing down to see if a black piece of plastic falls out. the printer will also have this error when the printer cannot pick up the paper. clean the rubber roller with "rubber renew". you can use rubbing alcohol but rubber renew is recommended. the roller is often full of dust and fine paper debris.
Nov 15, 2009 | HP Photosmart 2575 All-In-One InkJet...
Hp laserjet4 printer will not print labels or envelopes
MP LOAD,
PC LOAD, or
LC LOAD
paper size,or
envelope size
The printer received a request for a paper or
envelope size not available in the printer.
MP LOAD: Load MP Tray with the requested
media. If the size is not selected in the printer
control panel, use the [MP[Paper[Size] key to enter
the requested size, or press [Shift] + [Continue] to
draw the requested size from another source, if
available.
Note: If MP LOAD remains in the display, you may
have to clear the buffer by resetting the printer.
Press [Shift] + [Reset].
Feb 12, 2009 | HP LaserJet 4 plus Printer
Blue screen: error
I do have the same problem, help!!
Apr 27, 2008 | HP Photosmart 2575 All-In-One InkJet...
2575 printer help
Pick your operating system & the HP page will load so you can download your printer software.
Click this link to get started: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&dlc=en&product=441240&lang=en&
Please vote, it matters..
Mar 07, 2008 | HP Pavilion dv4000 Notebook
Out of Paper. Load Paper Error
Check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=nz&lc=en&dlc=en&product=422000&dlc=en&lang=en
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
HP Photosmart 2575 All-In-One Printer, Scanner, Copier Logo
575 people viewed this question
Ben Johnson
