Question about Kenmore Dishwashers
Problem - Continuous Blinking LED in DELAY HOURS 4 and no other keys function except CANCEL/DRAIN.
Kenmore Elite Ultra HE - 665.1315K701 Problem - Continuous Blinking LED in DELAY HOURS 4 and no other keys function except CANCEL/DRAIN. Noticed water in base of tub when doing dishes, so prior to selecting a new cycle I simply hit the CANCEL/DRAIN button. The pump worked and emptied the tub basin. When it stopped I tried to set up a new cycle and no response from any button but the CANCE:/DRAIN. Now power cycling the device makes the DELAY HOURS 4 LED blink continuously. The CANCEL/DRAIN button will stop the LED, but then all is dark and no response.
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
SOURCE: blinking lights on kenmore 665
key pad need to be change
Posted on May 09, 2008
  • 171 Answers
SOURCE: Kenmore 665 Ultra Wash FH141493
Hi daryano
I'm Harvey the Master Plumber
You want to know how to get the delay to work?
Most models work this way: Washing dishes the first time sets the favorites and the next time you start it the favs come on automatically provided you haven't changed the settings. So after the first use just hit delay and nothing else and when the dalay time is up it should work fine.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 11, 2008
  • 1214 Answers
I suspect for either of these units that the timer control boards are bad.
Posted on Jan 24, 2009
  • 1632 Answers
SOURCE: My Kenmore ULTRA WASH dishwasher model #1603* does not respond
replace timer/program module Vitally
Posted on May 18, 2009
My kenmore dw just stopped running thru cycles except drain
Hello, With the information you supplied I'm going to assume the light is blinking 7 times and pausing then blinking 7 times and so on. With the door cracked open hit the following button combination: -high temp wash
-heated dry
-high temp wash
-heated dry Then close the door and hit cancel. The pump will run for a few moments and then you should be all set. Hope this helps Mike
Nov 19, 2009 | Refrigerators
Electrolux dishwasher delays before starting
  1. To cancel the delay.press the delay pad again when the delay is counting down. The indicator light will go out and the cycle will start or resume immediately.
  2. To cancel the delay and the cycle, press Start/cancel once to drain and turn-off the dishwasher.
  3. Press Start/cancel twice to turn-off the dishwasher without draining.
Aug 31, 2009 | Electrolux EDW5505ESS Built-in Dishwasher
Kenmore elite dryer 110 8772 He5 lights up, will not start no error codes. Brand new del today! Worked when tech tested it
MANUAL DIAGNOSTIC TEST
The washer must be empty and the control must be in the OFF state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
-Close the door.
-Select any one key (except STOP) and follow the steps below, using the same key (remember the key):
Press/hold 4 sec's.
Release for 4 sec's.
Press/hold 4 sec's.
Press/hold 4 sec's.
Press/hold 4 sec's., release
NOTES:
-Press the same key to advance to the next failure code.
-At the end of the procedure the program will loop back to the beginning. This is a continuous loop.
-To cancel out of the Manual Test Mode press STOP.
Exit Condition Control Action To be Checked
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 01, 2009 | Kenmore Elite 45986 Front Load Washer
Four hour delay light flashing
I have a kenmore elite dishwasher and the 6hour delay light is flashing and no other buttons work when I push them.. whats wrong?
Apr 11, 2009 | Kenmore Dishwashers
Jan 24, 2009 | Dishwashers
I need to cancel a washing cycle in the middle of the cycle.
usually pressing PAUSE/CANCEL twice cancels the cycle and shuts it off allowing you to then re-start the cycle. If not try unplugging it and see if it resets to allow you to start cycle again.
Dec 07, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
I had the same flashing light problem first the normal wash flashing light then the others. I tried shuting of the breakers but nothing. I tried resetting the panel by pushing normal wash and heated dry simultaneously and nothing. So I took the six screws holding the front panel out and unplugged the ribbon type wires and plug and unplugged it several times to help make a better contact and I was able to get it to work right away. This may not work for all but I worked for me. It is very easy to do and it's worth a try if you're having the same problem. It took me less then 10 minutes.
Oct 16, 2007 | Dishwashers
Dishwashers Logo
155 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
