Question about Frigidaire FD38NGDC Grill
Need instructions for starting my Frigidaire gas grill
I cannot remember how to light my gas grill. Can you provide me with instructions?
    Problem Solver:
  • 8 Answers
Ok turn on gas tank wait a couple seconds then turn on the burner to high and push egnighter till it goes click click and lights if no click click use a seperate lighter ..
Posted on May 27, 2009
You may want to verify that the batteries are good in the ignighter prior to starting the process. To get to the batteries, simply unscrew the push button on the ignighter and the batteries will come right out. Needs two AA.
Posted on Nov 23, 2009
Brinkman grill 3 burner pro series 8300 won't
To restore gas to the burners, follow the instructions below.
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
Jul 04, 2011 | Brinkmann Grilling
I have a Weber gas grill, and I just replaced the propane tank, yet when I ignite it on the Start/High setting, very little flame is produced. This is the first time in 5 years or so that I've...
Don't worry, you'll be grilling in no time, if you follow these instructions:
1. Turn the gas tank valve OFF.
2. Disconnect the grill's hose from the propane tank and wait 5 minutes.
3. Reconnect the hose to the tank and open the tank's gas valve VERY, VERY SLOWLY (Slow Motion, slow).
Once the valve is fully open light one burner and turn it to HIGH. Has the flame height returned to normal? If so, light the remaining burner and turn it to HIGH. Do both flame heights look normal?
If so, you solve the problem! Remember to always turn the tank valve ON Very, Very Slowly.
Hope this helped you. Please let me know and Happy Grilling!!
Jun 16, 2011 | Weber Baby Q Grill
Turned gas on, tried to start, wouldnt start. Though gas was out, went and bought new gas. Tried to start and no fire started.
Jimmy, I'm sure you're frustrated, but there is an easy solution to solving the problem.
1. Turn the tank valve OFF.
2. Disconnect the hose from the tank and wait 5 minutes.
3. Reconnect the hose to the tank and open the tank valve VERY, VERY SLOWLY (Slow motion,
slow).
4. Once the valve is fully open, light the burner farthest from the tank first and turn it to HIGH.
Did the burner light and the flames height look correct? If so, light the remaining burners
the same way. Now are all the burners lit and the flame heights look correct? If so, you
just solved the problem. Remember to always turn the tank valve ON Very, Very Slowly.
In the unlikely event, that the above didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. As the one that's on there now is locked up permanently . You can find one at any home center or hardware store that sells gas grills and accessories. They run about (+/-) $30.00.
Hope the helped you to troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Jun 14, 2011 | Weber E-210 Grill
I have a grill Frigidaire FD27LKEC 27 it is running with natural gas and I would like to convert it to propan. Is there a convertion kit or what do I need to change.
At one time, there was a conversion kit available to convert your model from Natural Gas to Propane Gas. Unfortunately, it is no longer available and has been removed from the retail market. This, usually happens, when a problem resulted from a conversion of one gas type to another.
May 23, 2011 | Frigidaire FD27LKEC (LP) Grill
How do I start the fire?
It's really not difficult, but must be done safely. I assume you may have misplaced the Owners Manual, so I have provided a link to it, that you can download and print for future reference. As you read over the Owners Manual, you will note, that starting on page 7, the instructions for lighting and using your grill safely and successfully, start there.
This may not be the same exact model you have, as Charbroil makes 2- Commercaial Stainless Steel models. But, they operate the same way.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/463247311%20english_80dfc074-6_.pdf
Hope this helps you enjoy your gas grilling experience. Happy Grilling!!
May 12, 2011 | Char-Broil Commercial Stainless Steel...
I am trying to selll a Fiesta Optima grill for my friend who developed memory problems. he can't remember if it was working or not. i don't know how to start these grills...so i need some...
Linda, my best advice, because I can't see the grill to steer you in the right direction, is for you to contact Fiesta's Customer Service Hotline (800) 396-3838 and they can provide an Owners Manual to you. Either in a download format by email or FAX. In addition, having the Owners Manual adds more value to the grill for a potential buyer.
Hope this helped you. Please let me know. Thanks.
May 06, 2011 | Grilling
I would like to order a Ignoter Button for my Frigidaire Gas Grill. FD27LKEC
At one time, Sure Fire Heat was making the Frigidaire Gas Grills for Frigidaire. They should still have parts available or interchangeable parts. Contact them at 800-229-5647
Mar 19, 2011 | Frigidaire FD27LKEC (LP) Grill
Need to know how to reset the LP Gas flow for a Webber 300 BBQ
If you just installed a new, full tank of propane and turned it on and the burners wouldn't light.
Turn the tank off, disconnect from the grill hose (you'l hear a whooshing sound and smell gas, but that's alright). Wait several minutes and reconnect the hose to the tank. Turn the gas valve on very very slowly, until it's full open. Now, try lighting your grill.
Remember, you will need to turn the tank valve on very very slowly every time you change tanks or turn the tank off after grilling.
What happened was this ... When you turned the tank on quickly it locked up the grill's gas regulator. Doing what suggested usually solves the problem. Oh, one other thing ... be sure your tank is not empty. The grill you have uses a lot of gas.
Feb 02, 2011 | Weber Grilling
Can use gas for my liquid porpane grill
Yes you can as long as your home uses LPG. You can not use 2 regulators. If your outside line is after your home regulator you need to eliminate the regulator on your grill. LPG products operate on 11" of water column, that's about 1/2" PSI.
Thanks for using Fixya
Jerry
Mar 30, 2009 | Frigidaire FD26LPDC (LP) Grill
Need manual or instructions for starting
The manual can be found in the support section of the weber website (www.weber.com)
Jun 22, 2008 | Weber Gas Go-Anywhere Grill
Frigidaire FD38NGDC Grill Logo
223 people viewed this question
Top Frigidaire Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Frigidaire Grilling Expert? Answer questions, earn points and help others
