Question about Kenmore Freezers
Compressor will come on for approx 3 sec and then go off with click and 8-10 sec. later try again
I have a 18.1 cubic ft. Kenmore and when i plugged it in today it ran for about 3 sec.and then shut off with a click and about 8 sec.later it tried again. any suggestions ?
  • valleypump May 26, 2009
    thanks a million for the response . can I get that from a sears store or should I just order it from sears.com ?
  • 6,784 Answers
The start relay device on the compressor is faulty. replace this start device asap.
Posted on May 26, 2009
  • Michael Masters
    Michael Masters May 26, 2009
    you could order it online at sears parts direct or run to the store.
  • Michael Masters
    i would order online, the store may need to order as well. you can cut out the middle man and order yourself.
Kenmore 7.5 freezer stopped working.
Thanks for all the suggestions. I just replaced the overload relay and it does the same thing. Runs for a few seconds and the loud click from overload relay. I did notice the relay is really hot to the touch, if that matters.Coils on back are clean. I had noticed the last few months that the inside coils were frosting up quite a bit.Really had hoped it was the relay.
Dec 04, 2012 | Kenmore 7.5 cu. ft. / 212 liter Upright...
How to fix a chest freezer by kenmore
The clicking is the compressor trying to start. Probably a better bet to replace rather than try to repair with new compressor and electrics, drier and gas.
Jul 03, 2012 | Kenmore 5 cu. ft. / 142 liter Chest...
Kenmore upright freezer quit freezing would work intermitantly and then quit cooling altogether, Approx 10 years old trouble shooting advise or most likely cause would be appreciated
Sorry to read about your problem. you can have many different problems.
Here are some areas to troubleshoot
1. Bad temp control
2. Failing compressor
3. Defective start cap
4. Defective overload protector
5. Defective control board
I suggest you call a service company. for compressor issues
I have tried to help you. Please help me, by Vote/Rate my response. Thanks.
If you live in the Denver area, I can help you.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | Kenmore 16.7 cu. ft. / 473 liter Upright...
My kenmore mod#2539183511 chest freezer comes on @30 sec goes off for @3-5 sec tries again.Need diag help or wiring diagram.
a wiring diagram will not help you in this case. all 3 items below at at the compressor.
odds are you will have to have the compressor replaced.
1. Failing compressor
2. Defective start cap
3. Defective overload protector
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Jan 02, 2011 | Kenmore 12.8 cu. ft. / 362 liter Chest...
The ice cream gets to hard and we have to take the big cartons out for 2 hrs before we can scoop it. (How can we bring the tempreture up about 10 or 15 deg.?)We can't find any controls on it. We have no...
Hi, I think you have tell wrong model . Please try find out the temperature controller. Your freezer should able to adjust temperature from 0 - 18 Deg. F
Chest freezer of caravell has 2 model i.e :
1. Caravell SST-5213.7 cu ft Chest Freezer With Solid Sliding Doors
  • Durable white powder coated, baked on enamel finish
  • Solid sliding top doors
  • Cord and plug included
  • Self-contained refrigeration system
  • Temp. range 0 to -18 degrees F
  • 13.7 cu ft capacity
  • Heavy duty casters included
  • Dual drain plugs for easy cleaning
  • Environmentally friendly CFC-free R-134a refrigerant and insulation
  • 115V, 4.5 Amps
  • 51 1/2"W X 25 3/4"D x 34 3/4"H
  • One year parts, 90 days labor warranty plus 3 year compressor warranty
  • & 2. Caravell GST-5213.7 cu ft Chest Freezer With Glass Sliding Doors
  • 115V, 4.5 Amps
  • Regards, jay
    Nov 30, 2010 | Caravell 13.7 cu. ft. / 388 liter Chest...
    Compressor click
    Possibly. However it sounds like the compressor is running hot which could be the relay assembly sticking with the start windings in the circuit.
    Eric
    Jan 24, 2010 | Kenmore 14.8 cu. ft. / 419 liter Chest...
    Kenmore Upright Freezer Works Sometime
    try a new start relay and overload kit specifically for the make and model freezer you are working on. if compressor can be seen ,the numbers on it can be used to get correct oem start cap, relay ,and overload. if your unit is having starting problems that will usually fix it. if however, the stat is failing to bring it on a new stat is called for. but it sounds like it is having starting problems since you said it was off a long while then still struggled on the overload to start then finally did. if the new start components don't work then new freezer time. compressor replacement is to expensive anymore. good luck
    Oct 27, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
    Defaults to 0 deg. temp
    I would be more worried about constant power disruptions
    Jun 09, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
    Freezers Logo
    131 people viewed this question
    Top Kenmore Freezers Experts
    Charles T Nevin
    Charles T Nevin
    AJMAL KHAN
    christian nielsen
    Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
