Question about KitchenAid Refrigerators
Hissing noise in freezer
Kitchenaid side by side refrigerator with freezer making a hissing noise. Further investigation and I can see water dripping onto a horizontal metal component which can be seen thru a grate in the inside back of fridge. As water hits the metal it makes this hissing spitting noise.
  • gcpg May 26, 2009
    Thanks, I really appreciate the feedback. Sometimes it is hard to tell what is normal and what isn't
  • 4 Answers
When you observe this is your compressor quiet? Then most likely your refrigerator is in defrost mode. The water is coming off the evaporator (think of a very cold radiator) as the defrost heater element warms. This element is similar to the electric heating element in the bottom of your electric oven. the water hits it and it will hiss. This is part of the normal operation of a refrigerator. The defrost cycle usually lasts from 20-30 mins and will occur 4-6 times a day. If you are having trouble with frozen food melting then re-freezing, or the temps are on the warm side, you might need to have your defrost timer or defrost termination switch looked at.
Posted on May 26, 2009
There is a coil or something at the bottom of freezer that is red and the water is dripping of making a noise
Welcome to FixYa.
Not to worry, this is the automatic defrost cycle...specifically the heater element, the way the fridge keeps from frost/ice building up on the evaporator.
It defrost's by way of a heater which does heat to a point to melt the frost, subsequently you'll here the water dripping on the heater and "hissing" typically ( usually 10-20 min. depending on the frost accumulated and the bi-metal thermostat tolerance...the part which insures it shut's off ).
Anyway, I hope that re-assure's you this is normal and perfectly fine.
Hope this has addressed your concern or inquiry. Thanks for visiting "FixYa" for assistance today, please take a moment to rate the info provided to you.
Regards,
Macmarkus :)
May 20, 2011 | GE GSS20IEP Side by Side Refrigerator
Inside of freezer on the bottom on the back lit up red as though on fire, heard a hissing sound as though water was leaking on hot surface. whats happing?
It's defrosting. Depending on your make and model, it'll do that a couple of times a day. There is a heating element behind that panel that's on a timer. The element looks like a bake element in an electric range, sort of. It's doing what it should be doing. The hissing is the frost/ice being melted off of the evaporator and dripping onto the element. All normal.
The end.
fil
Mar 01, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Side by side refrigerator is making a sizzling noise at the back bottom of the freezer
The sizzling in your case means that it is working....it is just water dripping from the cooling coil onto the hot element that defrosts it...
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 18, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Why is my Samsung two-door fridge freezer leaking water into the bottom of the freezer compartment. What is the solution. I have defrosted it for 24 hours without success.
Hello there
You said you' ve defrosted it for 24 hours, that is good and it is the first step, Now clean out the drain system on the freezer side. The ice melts and become water it should drain out onto the drain pan underneath . But because the drain is plugged and the water can't running down the drain so it running out the drip pan onto the bottom of your freezer compartment. You may need to take out the back pannel on the freezer side to get to the drip pan below the freezing coil.
Hope this can help you to solve the problem.
Dickson
Nov 04, 2010 | KitchenAid (KSRD22FKST) Side by Side...
I have a model ED2CHQXKB05, series SR4452983 from November 2004. Freezer on the left side. The freezer drips into a vented area in the back: I can see the drips when I open the door, and each drop makes a...
What you are describing is the normal sounds it makes when it goes into defrost. The frost melts, and the resulting water will fall onto the heater which then makes your hissing noise. You dont mention that there is a problem, such as not cold or water leaking on your floor, so it sounds like all is working as it should. But you also mention you taped IT ( what is it?) to the wall in a circle.
Oct 12, 2010 | Whirlpool Freezers
We have a Kenmore side by side refridge serial #55251 that was making a hissing sounds. We looked at the bottom of the inside freezer and there appeared to be an element that was very red and water was...
Your fridge is fine it was in defrost mode during this an element heats up to melt any frost and ice in the freezer. But yes the hissing sound does sound alarming but is perfectly normal. hope you have a nice day
Aug 15, 2010 | Kenmore Refrigerators
Kitchenaid Refrigerator dripping water
i have a kitchenaid top / bottom refrigerator water drips in top part only not freezer. what is my problem?
Dec 31, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Refrigerators Logo
2,278 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
