Question about RCA TruFlat 27F520T 27" TV
The tv keeps shutting off just after minutes of turning it on. We can wait about 5-10 min before turning it on again but then it only stays on for a few minutes.
The TV will be for a few minutes and shut off then we have to wait 5- 10 minutes to turn it on again and it only stays on for a few minutes before it shuts off again. Heelllpppp :0) Casey
This sounds like a heat related problem, which could be a faulty chip or a cold (bad) solder joint on one of the PCBs (printed circuit boards). Due to the lethal voltages present inside a CRT type television, it is strongly advised to have this repaired by a qualified technician. however, if you or someone you know is technically inclined, you can try to fix this yourself. Cold solder joints can often be spotted by visible cracks in the solder joints. a through inspection of all the boards could easily identify the problem which can be resolved with a quick tap with a soldering iron and perhaps a little extra solder added to the joint. if that yields nothing, another method is heat/cold stressing the boards while the TV is running. With the TV on, spray small areas of the PCBs with cold spray (or a can of compressed air duster turned upside down) until the tv shuts off. then heat the last sprayed part with a hot air gun (or a hair dryer) until you can get the problem to repeat regularly. inspect the area causing the problem and you will probably find the culprit.
Posted on May 26, 2009
Sound goes off after 15 Min
Assuming it is not hardware but soft settings...
1) Check and make sure that your TV does not have the timer set.
The Timer feature allows you to set a day and time for the TV to turn on automatically and the device and channel to display when it switches on. If the TV is already on at the requested time, the TV automatically tunes to the channel you designated in the Timer menu.
When the Timer turns on the TV, the following message is displayed: "Press a button for the TV to stay on." Press any button on the remote control within five minutes if you wish the TV to remain on.
Note: The TV clock must be set before you can use the
Timer feature (see preceding page to set the clock).
On/Off
Press down arrow / up arrow to enable or disable the Timer.
2) If not working, try SYSTEM RESET. Press SYSTEM RESET button on the front panel with pointed object (e.g. straight paperclip). TV turns off, green LED flashes for about 1 minute. When it stops flashing turn the TV on again. All settings other than Parental Lock need to be set again using the manual.
3) TV RESET. If all else fails for soft error. Your manual describes this last resort for soft type error. It could be hardware problem needing more expertise.
Manual can be viewed on a computer at
http://www.audiolabga.com/pdf/V32-V32L_Service_Manual.pdf
Aug 05, 2014 | Mitsubishi WD-62531 Projection Television
POWER
Trouble is in main power supply and likely puffed up filter capacitors on that board---common issue in a lot of sets.
Let me know if you have questions.
Mar 13, 2012 | Panasonic Televison & Video
TV comes on, but shuts off after 3 minutes. I must wait at least 5 minutes to get it to turn back on again. TV will ONLY stay on if DVD drawer is OPEN!
dvd is overheating its circuit. Keep the tray open to dry up condensation. then leave TV on standby to keep moisture out.
Dec 07, 2010 | Toshiba MD13N3 13 in. TV/DVD Combo
Rca projection tv wont stay on but about 1 min then powers off and wont turn back on for about ten minutes then shuts off again after a min or so
Possibility Fan Cooler Issue Check at the back if your hear the fan going if not your fan cooler is burn out .... The Thermistor will shut off the TV automaticly to the unit for Over Heat
Sep 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Zenith 52'' dlp tv won't turn on
after an hour tv shuts off and you have to wait to turn it back on
Jun 12, 2009 | Zenith Televison & Video
Sony TV keeps shutting down ever 5 mins
Could be loose connections on the board where the solder is expanding as it heats up causing a loose connection or something in the power supply or horizontal is over heating and your tv is going into shutdown protection . Good luck
Mar 03, 2008 | Televison & Video
Tv turns off after 15 minutes of use
For bobby11 and luis, it is the power supply. Part Number EAY34797001 in the 42" and EAY34796801 in the 32". This is a known problem, and somebody should start a Class Action against LG over this one. Part is available online and easy to swap out for anyone with the most basic knowledge.
Jan 16, 2008 | LG 42LC7D-UB Television
On / Off problem
YOUR ON/OFF BUTTON ON THE FRONT PANNEL IS STUCK
SOME HOW (PRESSED IN ) TY SOME WD40 ON IT . SEE IF THAT WORKS.
Dec 12, 2007 | Samsung TXP3275H 32" TV
RCA TruFlat  27F520T 27" TV Logo
414 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
