Question about Sharp LC37SB24U 37 in. LCD TV
Limited cable channels
Since cox communications went digital earlier this month, our sharp television ( model lc37sb24u) has not been able to get all of the cable channels that it had prior to this change. Do we need to do a software upgrade in order to receive the channels or do we have the latest software since the television was purchased less than 6 months ago?
    President:
  • 1,077 Answers
There isn't a software upgrade available for your TV yet. So, the TV has the latest software right now.
I would try making the TV search for more channels.
Press Menu on the remote,
go to SETUP,
then go to CH SETUP,
then make sure the AIR/CABLE option is on CABLE,
then go to CH SEARCH and select " Analog & Digital Search Start ".
The new channels should show up after the scan is done.
If this doesn't work, the TV may need some type of new converter/cable box from the cable company.
If you need a copy of your manual, you can go here:
http://www.sharpusa.com/products/support/options/1,2310,,00.html?model_num=lc37sb24u&s_func_disp_id=27&x=37&y=10
Posted on May 26, 2009
19" Element HD Digital LED TV Model ELEFW195 Does not scan Digital Channels just Analog Channels.
Auto-channel search can't find digital channels - Community ...
community.insigniaproducts.com/...channel...can...digital-channels/.../13...
Aug 6, 2010 - When I ran the auto-channel search it could only find 4 analog ... Notgetting Digital Channels on NS-26L450A11 ... I've plugged the cable from the wall into the TV, and preformed the auto channel scan, with "cable" selected.
Troubleshooting Guide for Digital-to-Analog Converter Boxes
https://www.fcc.gov/.../troubleshoo...
Federal Communications CommissionIf you aren't receiving digital signals on your analog TV, you can purchase a ...antennas are designed only for reception of either VHF or UHF signals (but not both). ...The channel scan will automatically search for digital broadcast channels ...
Antennas and Digital Television ' Federal Communication
Jan 13, 2016 | Televison & Video
TV only detecting channels 2-13 should be detecting 2-63
Go back to the initial set up procedure for your Sharp TV and do a search for active HD channels. They will be decimal numbers such as 13.1.
Jan 13, 2014 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a sharp crt tv model:25c-bs370,although i'm using cable signal which more than 100 channels,still the channel it receive is limited only to 35 channels...how to rechannel the unit?my tv came...
Hi,The Television from japan have no lowband channel,It can be rechannel but the channel additional is onlly the lowband channel it maybe add only 2 channel.So the best things you do is to buy and install a channel converter to your TV.A channel converter is 100 plus channel thats why you can use your cable to japan television.To install the channel converter you need to set your television to Video setting and use RCA connector and plug it to video/sound input of your TV and video/sound output of channel converter.The cable connected plug it to channel converter.
Jul 11, 2011 | Sharp Televison & Video
My wife thought it was hooked to a cable box for high number channels and pushed 707 on the remote TV sig went out. TV powers up but no menu no signal just a power light and the background is on but no...
Hello
have you tried pushing 003 on the remote or the AV buttons?
All I can think of is that you must the get tv BACK ON the right channel or AV Input.
Hope you have a better day
Nov 25, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
How to attach additional speakers
Click HERE to download required owners manual free copy for Sharp LC37SB24U
Jul 31, 2010 | Sharp LC37SB24U 37 in. LCD TV
My sharp LC37sb24u power light just keeps blinking. I have tried to unplug it.
The sharp tv have a very common problems,couple years the Main Tuner signal board have problems or dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish Main Tuner signal board for the replacement.
Apr 05, 2010 | Sharp LC37SB24U 37 in. LCD TV
One channel fuzzy
Tis is an ongoing problem I seen increase alot over the past few months. From what I can gather, all the channels being broadcast over going from the analog to digital, there's no big suprise to anyone. However, the change from analog to digital is changing at a faster rate, so when you look at the TV some channels will be fine and others will have grey lines, fuzzy picture. The only solution-you need a TV with some kind of digital tuner. On the TV itself if the (TV has one) it will say "SD" or "ED" which stands for standard digital or enhanced digital.
Jan 25, 2008 | GE 27GT277 27" TV
Audio Problems with Sharp Aquos T. V.
Just talked to a fellow at Audiotronics regarding Sharp Aquos.
This is a widespread problem with audio on their TV's, The tech. said there may be a full recall regarding this problem!!!
Nov 10, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sound loss
There is a software issue with the cox cable box. You television will only react to the input it receives from the box. Get cox to replace the box and not to tell you it is a problem with the television. Scrivitron
Jun 20, 2007 | Toshiba 35AF44 35" Rear Projection...
Sharp LC37SB24U 37 in. LCD TV Logo
349 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
