Question about HP Compaq FP 7317 17" Flat Panel LCD Monitor
Flickers until all monitor area turns gray - just like tv without signal
Ibm 17" monitor flickers at first then goes gray all over -- just like the black and white tv when it can't receive any signal.
  • 3 more comments
  • k_obial May 26, 2009
    tried my old crt monitor and pc boots normally
    hi... at first yes, i could see everything normally and the problem starts gradually up until i could not see anything on the screen. once this happens, even if i remove the computer from the monitor, the problem is still there. probably after a few hours, it will normalize but will come right back. brought it to the shop for repair but it isn't re-occurring on their end??? please help.
    would it help if i plug it to an avr first instead of plugging it direct to the ac outlet?
  • Frank Zhang
    Frank Zhang May 11, 2010
    could you see any nessages show on screen when flickers?
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Do you have another monitor to try on the computer to make sure that your computer is booting up properly and to be sure if the original monitor is good or bad.
  • 191 Answers
Your monitor has some hardware that is not stable, you need do follow steps
1) open monitor check DC power supply board, there could be any capacitor swelling need to change, this cause DC filter fail.
2) check the panel cable, clean and reseat it between main controler board and LCD panel.
3) check and reseat the DC cable plug between power board and controler board,
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
Posted on May 26, 2009
  • Frank Zhang
    Frank Zhang May 26, 2009
    but it still got some components near fail, if you do not aording my steps do check, or change your avr adapter. it will be a severe trouble in future, this is my advise. because white screen means DC supply wave higher. etc...
  • Frank Zhang
    please take a rating it should help you a lot.thanks.
  • HP Master
  • 2,404 Answers
Sounds to me like bad caps on the power board or main board.
The monitor is faulty for sure. Bring it back to the shop and tell them the problem is still happening and ask them to leave it on connected to a computer overnight since it takes a while to happen. They should see it happen and then troubleshoot it further.
Lg tv gray screen main menu screen flickers
tats something in the board its self youll have to take that to a tv repair man
Dec 06, 2013 | LG Televison & Video
My IBM ThinkVision monitor flickers the correct display then blacks out. The light goes green a moment, then goes amber with the blackout. I think it may be stuck in the Energy Star/Power Saver mode. Is...
skeltonh, Have you connected your L170 to a different "known-good" PC that has ALL power-save and screen saver modes disabled? Have you connected an old monitor to your PC to see if it will act same way as the L170? 12fixlouie
Jul 31, 2010 | IBM ThinkVision L170 17" LCD Monitor
When I turn my computer on the monitor constantly flickers on and off. After about an hour this stops the the screen goes black about five times, but after that it works fine?
You need to download the latest graphices drivers and get the update for the BIOS.
If the screen flickers in the BIOS screen as well that means the sys has to be repaired for the screen.
Feb 06, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
My hp vf15 monitor flickers on and off when it is plugged
17-inch CRT?
Ask your friends -- one of them probably has a "surplus" 17-inch CRT that they will _love_ to give-away to you, to replace yours.
Or, look on CRAIGS LIST for a used 17" LCD screen, for $30 to $40.
Jan 14, 2010 | HP Pavilion MX75 17" CRT Monitor
My flat screen Samsung monitor flickers on and off and goes to black for a few seconds before flickering on and off again. I tried taking out the cable connecting it to the computer and it still flickers...
Yes probably your monitor should be check by a technician. Try to see the warranty for you monitor if its still catch the warranty service for it, they may replace it. Bring it back to where you bought it.
Oct 31, 2009 | Samsung SyncMaster 713BM 17" LCD Monitor
Ibm thinkpad t43 backlight inverter issue
Did you say the the video output flickers on and off when you connect an external monitor to the video output. If the inverter is faulty this would not affect the video output and the external monitor would not flicker but if the external monitor flickers it would point to a video card problem.
Jun 13, 2009 | IBM ThinkPad T43 Notebook
Flickering monitor
this problem many caused by bad inverter. If invertes not function, it won't feed back a good signal to tell mainboard that LCD backlight is working, so the mainboard turn off the display.
To fix this problem, it is need a qualify technician and inverter's part.
Send it to LG, they will not charge you expensive. LG have a great service.
May this help.
Oct 09, 2008 | LG Flatron L1750S 17" LCD Monitor
Hi, I have a problem with
The high voltage (HV) flyback transformer is a very possible cause of this. This could be repaired by a qualified technician, but the cost may not be worth it. New 17" monitors can be acquired for free sometimes (think craigslist)
Mike
Mar 31, 2008 | Computers & Internet
Monitor flickers!!
I have also same problem with LG Monitor 700E, LB(in). I want circuit diagram/systematics of this monitor in PDF or any other format. Thanks in advance.
Dec 01, 2007 | LG Studioworks 700S 17" CRT Monitor
HP Compaq FP 7317 17" Flat Panel LCD Monitor Logo
340 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
