Question about Casio EXILIM ZOOM EX-Z850 Digital Camera
Memory Card influence?
Very strange problem, when I put the mode in Snapshot, the LCD is black. It works, but when I try to take the picture it goes black. I can still take pictures but I can't see it on the LCD. All other modes work perfectly fine. Any suggestions? I've tried different memory cards to see if any difference, and all has the same result.
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Posted on May 22, 2008
When my zte warp got wet i took it apart but forgot to take the memory card and sim card out. my screen goes from black to rainbow fuzz. What do I do to fix this?
Not a easy fix...Water can do strange things to a phone.May or maynot work properly again.Try putting it rice.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/vincent_b45a16d93e2343f1
Jun 18, 2014 | ZTE Warp
My Leica Digilux 2, recently purchased and never used before, doesn't appear to be taking pictures. It reads all memory cards (residule photos previously taken) however when taking a snapshot, the display...
Does the menu in the camera work?
You may need to activate some Postview function in the menu. If the camera takes pictures, you should be able to view them in playback mode. There could also be a Preview mode, which requires pressing OK before storing pictures. Preview/Postview should cancel each other though...
Apr 13, 2010 | Leica Digilux 2 Digital Camera
No image when taking a picture with Canon Powershot SD1000
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Feb 19, 2010 | Canon PowerShot SD1000 Digital Camera
How can i get the pictures of my camera onto a memory stick?
You will have to load them to your pc then transfer to the memory stick
Oct 12, 2009 | JVC GR-D23E Mini DV Digital Camcorder
LCD screen is black-cannot take photos
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help: http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 16, 2009 | Kodak EasyShare CX7330 Digital Camera
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
Shooting mode shows nothing.
I just had this issue with my camera (my 15 year old son solved it for me ;-) ).
The viewfinder was active in "record" mode and the LCD was "active" because you could see a little back light but no image. The "playback" mode would let me review pictures in the LCD though so I know it is capable of showing information.
If you push the display key/button a couple of times you can see the picture move from the viewfinder to the LCD and have just a picture and or a picture and information.
So try setting the camera to "record" mode (lens comes out) and then push the "display button" which is on the back of the camera just to the right of the LCD on the lower right side several times and see if the LCD starts to work.
It could be that somehow the display button was pushed by mistake.
Bill
Dec 07, 2008 | Canon PowerShot S3 IS Digital Camera
Problem
Two things to try...
A) If you have a card with some photo's on it then put it in the camera... Will the camera display the photos from the card in view/play mode? If so then the screen is working but the sensor in the camera may have died (the but that captures the image).
B) Try taking a picture with the camera (go through the steps to take one even though you can't see anything on the screen). Then put the memory card in a reader or a friends camera and see if the picture did get taken. If so then the sensor is still okay and the fault may be with the display.
If the display will show images from the memory card but doesn't show anything when in picture-taking mode but the camera does take pictures then the camera has a fault that isn't either the sensor or the LCD. It could then be an electronic failure or a problem with the mode selection switch.
Hope this helps to figure it out.
Cheers,
TS
Jan 04, 2008 | Panasonic Lumix DMC-LZ3 Digital Camera
DSC-W100 not taking pictures
possible ribbon from CCD image to main board not seated properly
Nov 29, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
Casio EXILIM ZOOM EX-Z850 Digital Camera Logo
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
