Question about Mackie SWA1501 Subwoofer
Need to plug wires back in
I took the Orange and yellow wires of the board off and forgot which one plugs in on the top and which one plug in on the bottom Thanks, Steve
RED on J4-1,2
BLK on J4-3
YEL on J4-4,5
Posted on Oct 30, 2009
I have took all the leads off from coil to plugs and forgot the set up on suzuki gsx600f Hreg
If you are sitting on the bike the left coil has an orange/white wire on the top and a white wire on the bottom.The HT leads go to plugs 1 4.The right coil has an orange/white lead on the top and a black/yellow wire on the bottom.The other HT leads go to 2 3.It doesnt matter which HT lead goes to either plug as thboth HT leads on the same coil fire at the same time (wasted spark system).Hope this has helped or you have already sorted it out.
May 14, 2010 | 2008 Suzuki GSX-R 600
Wiring internal board of labtec computer speakers
The shielded wires are for ground, so they get connected together. Plug the wire into the PC and run some music. Then touch each wire to the others. You only have a couple of combinations to try...red-to-green and white-to-yellow, or red-to-yellow and white-to-green, . You can do this while the PC is one and music playing until you get sound thru the speakers. There virtually no current running thru the wires and you can't hurt the PC by doing this.
If the speakers use an external power supply, have it plugged in and working when trying these connection options.
Sep 07, 2009 | Labtec LCS 1040 Computer Speakers
Speaker wire colors
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Aug 10, 2009 | 1991 Ford Tempo 4 Door
Need main wiring schematic for 2000 ultra classic speedo,speedo reset ,tacho, wiring wires got pulled out of plugs need help.thank you
Looking at the plugs on the meter side of the harness: for the speedometer there is a three position plug. Pin #1 is Orange, Pin #2 is White/Green and Pin #3 is Black. for the Tachometer there is a six position plug, Pin #1 is Orange, Pin #2 is Pink, Pin #3 is Black/Yellow, Pin #4 is Green/Red, Pin #5 is Yellow/Red, Pin #6 is Black
Jul 19, 2009 | 2000 Harley Davidson FLHTCUI Electra Glide...
How do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
That little fella is only turned off by unplugging it. If all those little lights in America could be turned off we could do with one less nuclear power plant. If unplugging it is not an option, my wife's solution is to cover it with a piece of black tape.
Jul 08, 2009 | Vizio L32 32 in. LCD HDTV
Forgot the manual to wire carrier fan coil - took care of the thermostat -but need to wire fan coil
Carrier wires are as follow Red black green whiteyellow. R common Black ground Y cool O or orange Reverse valve G fan W heat. The white on the Air handler depending on your electric backup heat has two wires together connected to white. Orange connects to orange on the condenser. Unless you have terminal board the everything is marked. Ruty
Jun 06, 2009 | Carrier Heating & Cooling
Red wire missing
the power wire goes above a blue wire or next to (white/orange) and (green) in top row if there is a space there
yellow should be above black
(white/orange) should be above (blue/yellow) i think
than red over blue
hope this helps
Jan 11, 2009 | Pioneer AVH-P6400CD Car DVD Player
Digital clock
Here is a wiring diagram of the radio by wire color:
Radio Constant 12V+ Wire: Green/Yellow
Radio Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Green
Radio Illumination Wire: Light Blue/Red
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: Blue
Radio Amp Trigger Wire: Blue (Same as Antenna Trigger)
Front Speakers Size and Location: 5′ x 7′ Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers SIze and Location: 5′ x 7′ Rear Deck
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
Aug 14, 2008 | 1988 Ford Mustang
Wiring toggle switch royal 9512x
Did you get wiring diagram for Orca 9512X shereder swithc.
Wiring is as follows.
Looking down on switch from the back with the forward facing the feed. and control on top
Top left has two yellow wires one to bottom right of switch other to control box/board
Top right has orange going into control box/board
middle left has black going to motor
middle right has red going to motor
bottom left has smaller red going to control box/boafd
bottom right has yellow from top left.
Hope this helps. I'm still trying to find a manual for mine.
Jun 10, 2008 | Office Equipment & Supplies
Wiring a new radio in 1991 ford explorer
Right Front:
Right Rear:
Left Front:
Left Rear:
Right Front:
Right Rear:
Left Front:
Left Rear:
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Mackie SWA1501 Subwoofer Logo
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
